Question about Refrigerators
Mt27 cooler was working fine then it started freezing every thing unpluged re started temp knob on 2 still freezing
  • Refrigerators Master
  • 884 Answers
Thermostat sticking. Give it a tap but if it doesnt unstick you'll have to replace it...
Posted on May 04, 2017
Can i use a beverage air mt27 as a freezer
doubtful but if you turn the dial to highest cold number what is the temp only you ca tell that
Mar 22, 2015 | Beverage-Air MT27 Beverage Cooler...
I cannot understand the dual thermostat manual (" rolling " knob type) controls . They are printed in Japanese . There are 2 temp. control knobs side by side located inside the ref. compartment / lowe
Don't think it's the temp control problem, I suspect one on the defrost elements at the top is faulty, if food starting to defrost in the cycle indicates the lower element is working overtime.
Nov 22, 2014 | Refrigerators
What could cause the cooler to freeze other than a faulty thermostat?
Improper refrigerant charge. Its critical and measures coil temp and not cabinet temp. If you did add gas that is the answer. Take out all the gas, put vacuum pump on it, then weigh in exactly in ounces the correct charge, its listed on the spec. tag. Hope this helps and good luck.
Jul 17, 2014 | Beverage-Air MT27 Beverage Cooler...
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
What does the overload relay look like a Beverage-Air MT27 Beverage Cooler Commercial
Normally thermal overloads have a button like appearance on the compressor. Designed to open circuit when temp has caused distortion to the bi-metal contacts. Upon cooling will close again. Disconnect power before checking continunity on the overload terminals.
Sep 27, 2011 | Beverage-Air MT27 Beverage Cooler...
What is the temperature for the thermostat settings?
i usually set mine at 38 or 40 that way things wont freeze but stay cold.
Dec 17, 2010 | Beverage-Air MT27 Beverage Cooler...
I have a Bev Air MT-27 cooler for home use. Is it possible to have it rewired so it functions more like a refrigerator so the fan doesn't run 24/7? And if that isn't possible, could I use a timer so that...
On commercial coolers, the fans are designed to run 24/7 to prevent the coils from freezing up. If the unit only runs 4 times a day, it will not maintain proper temps. Domestic units utilize the freezer compartment air to keep the refrigerator section at temp. Totally different set ups. I wouldn't do what you are suggesting with a commercial unit.
Nov 23, 2010 | Beverage-Air MT27 Beverage Cooler...
Beverage Air
1. check for dirty condenser sometimes if its dirty enough, it'll trip the compressor.
2. if condenser is dirty, well pull out the old garden hose and hose down the condenser (turn off unit first!)(i don't want any accidents... je je je)
if you did step 2 and nothing yet, suspect faulty relay/ overload/ start capacitor failure (relay and start capacitors fail more often then the overload.
hope to he of some help today.
Jan 30, 2008 | Beverage-Air MT27 Beverage Cooler...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
