What block do I have. 10066036 - Computers & Internet
Good wrench create engine, casting # 10066036 4 bolt 2pc rear seal made in Mexico. it is sitting in a home made street rod. 1961 VW beetle on S10 frame
You won't know the year without the stamping number.
Especially since this is a crate engine and not built for a specific car or truck.
Mar 26, 2015 | Cars & Trucks
What is the h/p of this chev crate engine,casting # 10066036,what does the cvp stand for at the end of engine number 1m0216cvp.
350 Cubic inches 4.00" Bore, 3.47" stroke
8.5:1 compression ratio.
250 HP @4300 rpm
350 ft. lbs of torque @ 3600 rpm
( These Numbers obtained with a Quadrajet Carb,1 5/8" headers , and an Edelbrock Performer intake part # 2101)
Engine consists of the following parts:
Block -part # 10066034, casting # 10066036
2 piece rear main seal 4 bolt main
Crankshaft- # 3932444
Nodular Iron 1985 and older flywheel bolt pattern.
Powdered Metal Connecting rods- # 10108688
Cast Aluminum Pistons-#12514101
G.M. High Volume Pump Oil Pump- part # 12555284
Hydralic Flat tappet Camshaft- #14088839
Intake Lift-.383" Exhaust Lift-.401"
Intake Duration @ .050"- 194 Exhaust Duration @.050"- 202
Lobe Seperation-112
This cam Has a mechanical Fuel Pump Lobe.
This is a low end Torque oriented camshaft.
Cylinder Heads- part # 14034808, casting #33417369, 1.94" Intake valve, 1.50" Exhaust Valve, 76cc Combustion Chamber, 7 Bolt style Exhaust Flange Standard, 85' and prior intake manifold bolt pattern. Perimeter bolt style Valve Covers. This head is very similar to the old #882 castings from the 1970's
Will not work in 1986 and newer applications!
This engine includes Painted Valve Covers, oil pan and Timing Cover. This engine is drilled for both L.H. and R.H. dipsticks. Plugs Are included to plug the side not used.Two timing pointers are also included, a pointer for a 6" balancer and a pointer for an 8' balancer.Balancer with 2:00 timing mark must be used with this engine in order for mark to line up with the pointer.
For most stock applications with HEI ignition, Base ignition timing should be set to 10 before top dead center (with vacuum advance disconected) Total ignition timing should be around 36 @ 3000 rpm.
Spark plugs that should be used are AC Delco R45TS gapped at .045"
Oil filters used with this engine include PF25 , PF35 , PF1218 , or PF35L. The first oil filter is a 1/2 Quart type, the last three are the 1 quart type.
Generally 10W30 or 10W40 oil is used in this engine.
Does Not Include Balancer , flywheel , intake , Exhaust , Ignition , or fuel parts.
Jun 25, 2014 | Crate Powertrain Factory Surplus Crate...
How to block a bbm whatsapp contact
  • Go to Settings > Privacy Settings > Blocked Contacts. This page displays all contacts that you have blocked.
  • Press the icon_blackberry.png button, then choose Block New Contact to select a contact you wish to block.
    If it's an unknown contact you can block it from within the chat, by pressing the icon_blackberry.png button and then selecting block
Jun 03, 2014 | Computers & Internet
How can I find out what fuse makes the lights on the cluster and the a/c control panel turn on?
What engine size?prev.gif next.gif Underhood Fuse Block 4.2L Engine Except Saab Underhood Fuse Block (2002 - 2005 Early Production) gm-06-42-1628.gif
5.3L Engine Except Saab Underhood Fuse Block (2003 - 2005 Early Production) gm-06-53-1632.gif
5.3L & 6.0L Engines Except Saab Underhood Fuse Block (2005 Late Production - 2007) gm-06-53-1635.gif
Jul 12, 2010 | 2005 Chevrolet TrailBlazer
I want to block my facebook id forever!
Facebook can NOT do this for you. You must do it YOURSELF. It is very easy.
On a computer, click the little arrow on the top right of the screen next to the padlock symbol. Click Security, and at the bottom, click DEACTIVATE ACCOUNT.
On a phone or mobile device.
Click on MORE bottom right.
Scroll to the bottom and click SETTINGS.
Click GENERAL, and then ACCOUNT - Deactivate.
Your ID will then disappear and be blocked from viewing If you mean you want to post without being identified, you can't.
May 20, 2010 | Computers & Internet
10066036 what engine id code or catsing code is this
Hi wwwcowboy.
This is a basic 350 Chev block made in Mexico.
It is a good 350 crate motor.
There you are.
Take care.
May 01, 2010 | 1989 GMC C1500
Blocking a number on e530
"On the text they sent me... click options.. go down to "block adress" and add them to the block list. then go on settings, message settings, sms settings, block settings, apply block. tada." from Blocking numbers, on a samsung? on YahooAnswers.
Alternatively ask your network provider to block the number and tell them the person is harassing you.
Sep 13, 2009 | Samsung SGH-E530 Cellular Phone
Puzzles 130 Too Many Queens 5 --- 132 Princess's Escape
puzzle 130:Assuming on a chess board 8x8 that each square is numbered 1-64 top left to right.Place a queen on each of these squares 3,13,18,32,33,47,52 and 62 bobs yer uncle
Mar 09, 2009 | Nintendo Professor Layton & the Curious...
Blocking a phone number
if you want to block your own number dial *67 before you dial... to block someone else try dialing
To activate Call Block or add a telephone number to the rejection list, dial *60. If you dont know the number to be blocked, dial *60 immediately after hanging up from the call. To turn off Call Block, dial *80. Call Block cannot block calls from some cellular phones, pay phones or business lines. It also cannot block most long distance numbers.
hope this helps...please rate...thanks
Jan 13, 2009 | Uniden Cordless Phone
Computers & Internet Logo
David Payne
David Payne
