Question about Troy Garden
I need to register. I bought a troy edger - Troy Garden
3 Suggested Answers
  • 8404 Answers
SOURCE: I need the engine manual for the troy-bilt tiller
Have you considered visiting the manufacturers website to get this information?
Posted on Oct 27, 2009
  • 7 Answers
SOURCE: troy-bilt gas edger trencher won't start. Spark
Remove spark plug and pour 5mls or one teaspoon of premixed gas in the engine. Depress trottle to full with choke on "run", pull starter about 10 to 12 times If it starts and run for a while and then shuts off your carb needs servicing. If not remove muffler and look for a spark arrestor screen. This could be plugged up with soot. If it is, replace and this would have been your problem. While the muffler is off slowly pull starter rope and examine the piston if gas and oil oozes backwards as the piston moves to the top then the piston and rings need replacing.
Posted on Nov 10, 2009
How to put on new belt
https://www.partstree.com/parts/troy-bilt/edgers/tb516ec-25a-516-966-troy-bilt-edger-2011/general-assembly/
Zoom into the diagram, remove (item 45) belt cover to expose the belt and pulleys. Take note of how the belt is routed.! you will need to follow the same route with the new belt. You may need to remove the Blade guard (item 40) if the belt doesn't fit over the head of the guard. There may also be a sprung idle tension pulley, which will take up the slack in the belt once replaced. Looks pretty straight forward.
Apr 19, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
Starter rope is loose on lawn edger
remove the recoil housing and wrap the chord round the spool more to take up the slack
Feb 11, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
How do I replace a belt for a TB515EC troy bilt lawn edger
The owners manual should have belt routing diagram, or Google Troy-Bilt, enter your model number and look at there PFD download manual.
Oct 03, 2014 | Troy Garden
Why troy bilt 609n wont start
YOU MAY HAVE A PROBLEM WITH THE CHARGING SYSTEM FOR THE BATTERY AS IT COULD BE THAT IT IS NOT CHARGING AND DOES NOT HAVE ENOUGH POWER TO RUN THE MOTOR
May 23, 2014 | Troy-Bilt Garden
Troy Bilt edger manual
To get a manual for a Troy-Bilt product, you need the model number. For some units, the serial number is also needed to obtain the correct version of the manual. The needed information is on the edger itself, in a spot that usually will not get damaged when you are using the machine. For wheeled edgers, look at the rear of the deck when you are in the operator's position. The string trimmer/edger models similarly have the plaque with the model and serial number in a spot that won't get damaged.
Start here: http://www.troybilt.com/webapp/wcs/stores/servlet/HelpView?storeId=10001&catalogId=14102&langId=-1 . Fill in the model and serial numbers and then click Find Manual.
If you add a comment with the model number, I will be glad to look up the exact location of the manual for you. This would be a link to a PDF.
I hope this helps.
Aug 02, 2011 | Troy-Bilt Garden
Troy bilt lawn mower bronco belt broke HELP!
hi try this site its called pats small engines
Apr 13, 2009 | Garden
Garden Logo
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
