I am trying to cut an image on vinyl that has several colors. How do I separate the colors to cut the image
  • 1030 Answers
SOURCE: Toshiba 42 inch rear projection T.V.
this sounds like a convergence loss... the most likely cause of this is what is known as stk's or convergenc ic(chips) have gone bad.. also it cound be the output resistors. most likely need replaced
Posted on May 12, 2008
  • 16 Answers
SOURCE: Color is separating (red and Green double images
try to reset the convergence on the TV if the convergence reset wont work, need to call a technician to check the color gun
Posted on Sep 20, 2009
johnnydiode
  • 647 Answers
SOURCE: The colors are separated. Images are blurry and
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Posted on Oct 24, 2009
Ecollier2012
  • 3459 Answers
SOURCE: GREEN IMAGE AND RED IMAGE DO NOT LINE UP ON
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Feb 20, 2010
  • 321 Answers
SOURCE: Watching our Hitachi Ultravision 57
yes that is always the same problem.,
that is the convergence module where you have two
ic call stk /but you can try the magic focus button if it work for a while and come back you will have to replace the ic.
hope that give you an idea
have a nice day
Posted on Apr 22, 2010
How to transfer vinyl to cd-simply-I have manual but very confusing-simple step by step needed-thank you-Al B
The popular recording software known as Audacity is a good choice for getting all sorts of sounds saved in a digital format. The easy-to-use features of this program will help you to create complex musical compositions, or just record incoming audio streams. One of the basic things you can do with Audacity is to record sound from vinyl records. Many people still keep vinyls on hand, though the production of this medium has diminished. Here are the basic steps that will help you to use Audacity to record vinyl.
Steps
  1. Get your phonograph or record player. Assemble your collection of records and make sure that your record player is in good functioning condition.
  2. Use a cable to connect your record player to the computer with Audacity installed on it. In order to record from vinyl, you'll need to make sure you have accurately connected your record player as an incoming audio stream into the microphone jack of your computer.
    • Use hardware adapters to secure your cable connection. Many older record players utilize a 1/4-sized input jack. The modern laptop computer, as well as many desktop models, use a smaller, 1/8-sized input jack. You can buy simple adapters at your local electronics store to fix this problem.
    • Make sure that your cables and adapters support stereo.
  3. Open the Audacity program on your computer. You will see the signature Audacity screen, with controls at the top, and an empty space to accommodate created tracks.
  4. Start playing the record on your record player.
  5. Hit the red circle that represents the "record" button in Audacity.
  6. Observe the sound coming into Audacity. You should see the track being populated with sound, represented by a fluctuating line as the cursor moves along.
  7. Hit "Stop" to stop the recording.
  8. Stop the record player.
  9. Repeat this process with the entire track. Reset the record player, start playing and hit the Audacity "Record" button again, allowing the entire track to populate with the sound of the vinyl record.
  10. Save your project in your desired format. Audacity supports a number of file formats for the finished product. You can select one of these when you have recorded the entire track. Make every song its own track, or simply record the entire side of the record on one track.
Aug 26, 2015 | Audio Players & Recorders
How to fix holes in vinyl siding
You don't you put another piece of the same color over top, or replace the damaged one.If you're not too fussy about matching etc., just fill it with same color ecterior caulking.
Aug 14, 2014 | Washing Machines
Cricut expression 2
Cricket is hung up on the first small cut and keeps repeating that same cut over and over
Aug 09, 2012 | Toys
Watching our Hitachi Ultravision 57" and the colors seemed to separate, seeing several images, each in it's own color. Ghost-like...any ideas?
have a nice day
Apr 22, 2010 | Televison & Video
GREEN IMAGE AND RED IMAGE DO NOT LINE UP ON SCREEN. SEPARATED BY SEVERAL INCHES.TRIED
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Feb 19, 2010 | Akai PT5598HD 55" Rear Projection...
I am trying to use my DGI Cutting Plotter and when i try to start up the program Omega Cut Pro it comes up with a message to say 'Protection Failed, Please Check Your Dongle' I am unsure what this means...
Ok this means that to use this software you MUST have a licence and along with this you get a "Dongle" a device that plugs into either the Serial, Parallel or USB port, and has a "Code" in it, that is "Read" by the software. You simply cannot use it without this "Dongle" & Licence.
Feb 10, 2010 | Computers & Internet
Oct 24, 2009 | Sony KP-51WS500 51" Rear Projection...
Yes everything is repairable.....
The problem is in the Croma section of the TV
some times it ma happen due to 99% of moisture.........
Try Hot air Blow drying for 1 HR in side the TV i.e on the circute and blow clean if any dust partical are there
and then re check
if the problem prestis....contact the TV repai expert or the service centre....
May the Croma chip needs replacement....
Regards
Sep 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Photoshop, separating gray shades
I'd select the different levels of gray, and cut the color out of the picture, then paste it into a new document, using the exact same document and canvas sizes each time, so that you end up with three or four new documents, each with a different level of grey. If you're familiar enough with PS, you can do so by adding four new layers, and simply copy and paste the colors to four separate layers, and just hide all layers except the one you're printing currently. PS will ignore all layers that are invisible when printing. Click the 'eye' icon on each layer so that all of them are hidden except the one you want to print.
Hope this will FixYa!!!
Jun 01, 2008 | Adobe FC Photoshop CS V8.0 for mac
May 12, 2008 | Toshiba 42H83 42" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
