Question about Sony Audio Players & Recorders
Can eq work with a sony 2channel model str 130
dunnbiker
  • 8546 Answers
SOURCE: Looking to hook up an older model fisher EQ
Typically you would place an EQ or any processor2_bing.gif in a Tape Loop:
MD/Tape (or Video1) Rec/Out to EQ In; EQ Out to MD/Tape Play (or Video1) /In on the amp. Select MD/Tape (or Video1) on the receiver to place the EQ in-line with whatever source you're playing. Use it's ability to modify the sound sparingly.
Be advised, use of an external processor will only work for analog stereo sources and will likely DISable anything digital as soon as you activate the switch that puts it in the signal path.
Posted on Feb 23, 2010
dunnbiker
  • 8546 Answers
SOURCE: can I hook up a fisher (EQ-961) to a sony
Yes, see the other request you posted:
http://www.fixya.com/PostComment.aspx?thid=4196867&prdid=0&ctgid=109
dunnbiker
  • 8546 Answers
SOURCE: Can't get subwoofer working with sony model STR-DE845 receiver
read the manual
http://www.retrevo.com/support/Sony-STR-DE845-Receivers-manual/id/387ci973/t/2/
First, it must be a self-powered subwoofer, then you've got some settings to select in the receiver.
Posted on Jan 21, 2011
jerry_kramer
  • 3904 Answers
SOURCE: Can you hook up a kenwood stereo control amp- eq KC-105 to Sony str de105 receiver
Yes you can.
Posted on Nov 29, 2015
emissionwiz
  • 79189 Answers
SOURCE: can you use a eq tape deck ,cd with a sony receiver model str-dh130
I don't see why not.
Posted on Nov 24, 2016
How do I adjust the treble and bass on sony str-dh520?
See EQ Mode on page 59 of the owners manual to set the bass and treble for the front speakers, presumably for 2 channel mode. For multi-channel mode there are several pre-programmed audio modes listed starting on page 43 and music mode starting on page 44.
https://docs.sony.com/release/STRDH520.pdf
Mar 02, 2015 | Sony STR-DH520 A/V Receiver
Using an equalizer with a Sony STR-DE 475
I think I must have missed something. Where does the EQ get hooked up to on the Sony STRDE 475? Thanks, Nicolas
Nov 22, 2012 | Audio Players & Recorders
How to hook up external equalizer to Sony STR-DA 2000 ES. Equalizer is a Denon
you need a empty in/out tape slot (jacks in back of Sony, if tape deck is connected you can use "Y" connectors) connect jacks to EQ tape in & out.... (press EQ button Bypass)
Nov 13, 2010 | Sony STR-DA2000ES Receiver
How to connect kenwood GE 52 graphic equalizer to my sony str-DE345 any idea , please help me.thanks.I tried many combination but didnt work.
An EQ usually plugged between a preamp and an amplifier. You have a receiver. There's no connections that will let you do that. The only thing you can do is between a source(ie: CD) and the receiver. The CD will go in the eq and out of eq to cd input on the receiver
Sep 03, 2010 | Audio Players & Recorders
HOW CAN I HOOK UP CAVILIER 200A POWER AMP TO A sony str av 770x f
You can pull the Left and Right stereo program from either MD/Tape or Video 2 Audio OUTputs. Run a pair of RCA cables to the Active EQ's Line IN; then the EQ's Line OUT to the Cavalier's Line IN.
If the Tape output you're borrowing the program from is already connected to something, use RCA-cable splitters.
Remember to NEVER activate the monitor for that Tape function during playback of any digital audio source - it disables the digital input; or if the 901's are being used - it will remove the signal to the Cavalier.
Now if you wanted to use the 901's in your movie listening this will work with two limitations
Your receiver doesn't have preamp outputs for Front Left and Right out so you'd be extracting only the mixed-down 2-channel version of whatever the Sony is processing.
You'll have to manually control the Cavalier's volume because the pre-out you're using is BEFORE the Sony's volume control.
It might still be an improvement over what you have now.
Mar 21, 2010 | Sony STR-DE675 Receiver
Looking to hook up an older model fisher EQ (EQ-961) to a newer Sony amplifier (STR-697).
Feb 23, 2010 | Audio Players & Recorders
Can I hook up a fisher (EQ-961) to a sony
Cant get equalizer to work with my receiver
This might work fish76, The EQ needs a in & out source to operate correctly? If you have audio device connected to an aux input disconnect that & connect the EQ to that audio device & then plug the EQ to the Sony receiver AUX input. The tape monitor is the most important source for hooking up an EQ device, so you are very limited on a total receiver or amp tonal connection source. The bottom line is you can only use the EQ if another audio source to plug into it & the EQ plugs to your pre-amp input on the back of your rec or amp
Feb 03, 2009 | Sony Audio Players & Recorders
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
