How do I get the time from 24 to 12 hour on the remote
    Top Expert:
  • Televison & ... Master
  • 74,999 Answers
Cut the 24 format to exactly two.
Posted on Apr 15, 2017
How do I set the time on my little old Thomson CS86M mini Hi-Fi?
If you have a remote version here is how it works.
Press timer menu, hours should flash, then press up an down arrows until you get to clock set. Press enter on remote.
press up an down arrows to set hours, then press enter. Minutes now flash, press up an down to set, press enter on remote clock starts.
Jan 28, 2015 | Thomson Audio Players & Recorders
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
Only one of my my k-9 mundial keyless work the other seems fine but wont activate.
Try to reprogram the remotes to the alarm. Have your vehicle key and both remotes ready. The way to do this is as follows:
1. Turn ignition key to run position.
2. Within ten seconds push the valet button 5 times.
3. The siren will give a chirp, indicating that you are in programming mode.
4. Press the large button on the first remote. A chirp will be given as confirmation.
5. Press the large button on the second remote. A chirp will be given as confirmation.
6. Turn off ignition and remove key. Alarm will give long chirp indicating exiting program.
7. Try remotes. Both should be working.
For the next 48 hours, every time the vehicle is starting the siren will chirp indicating that remotes have been programmed. After 48 hours this feature will turn itself off. Also keep an eye on the alarm light as it will also blink the number of times as remotes are programmed every time the ignition is turn on.
Hope this information helps. Please rate. Thank you.
Mar 04, 2010 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
How do i set the time on the remote
Setting the clock
To set the clock press and hold F for five seconds, the transceiver will chirp twice and the hour selection will
start flashing. Immediately press Aux to advance the hour selection or star to reverse the hour selection.
Once the correct hour is displayed press F again and the minute selection will start flashing. Then press Aux to advance the minute selection or Star to reverse the minute selection. Once the correct time is displayed simply stop pressing all buttons for 15 seconds and the transceiver will automatically exit the clock mode.
Dec 23, 2009 | AviStart 5303 2-Way Security / Remote...
I've already replaced the bulb on my Panasonic television model number PT52LCX66, but I can not get the message of the screen that tells me to reset the hour meter lamp. How do I reset the the hour meter...
Turn off tv. Hold vol- on tv and tv/video button on remote same time for 5 seconds. Select lamp time use vol- on remote to reset to zero. turn off tv to remove serv menu.
Nov 24, 2009 | Televison & Video
I do not have remote. Church inherited projector.
Thank you for using
FixYa for your problem
  1. you need to enter factory Menu.
    You do so by doing the following:
    1).Start the projector.
    2).Press keypad <Source> and <Auto> keys simultaneously, enter " Lamp Hour info" layer
    3). Press <Source> and <Auto> keys simultaneously again, then enter factor menu.
    Do not change anything till you reach Lamp Layer where lamp hour and usage hour is given. If you reset, then all data revert to default - factory reset. you may chage here or under (2).
    Let me know if this solves your problem.
  2. - Press exit for 3 seconds
    - The Menu to reset the Hours rises up
    - Folow the manual on your screen
Please rate our solutions and if you still have problems please call back for more ideas to help you
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | NEC VT460 Multimedia Projector
I need the Polaroid Remote Control RC 201 Manual The remote codes are at the end of manual
May 04, 2009 | Televison & Video
I cannot set the time, my 880 remote want allow me to set the time!
I saw these posts recently and decided I would try and figure out the time on my Harmony 880.
First, using your Logitech Harmony remote software, version 7.5.0, log on using your login ID and password.
Next, select the remote settings tab, and go to display settings. Select time/display format and check the 24 hour format. (Note: the assumption is that you have already set the 12 hour time before hand, even though is says A.M.) I made this change to my own remote when it was actually was 7:30 P.M.
My remote actually reported 7:30 A.M. at this point. Save your changes online and plug in your remote to your USB port and let the Harmony update your change. Now your remote should be in 24 hour format.
Finally, log back on using the same procedure above only this time, click the check box for 12 hour format, save your changes and update your Harmony 880 one last time. Your finished, your remote should now be displaying the correct time in 12 hour format.
Oct 14, 2008 | Logitech Harmony 880 LCD Remote Control
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
Lg rear projection model: RT52SZ60db
You need to use the original LG RT52SZ60DB remote.
  1. Press MENU buttons on the REMOTE and on the TV at exactly the same time and hold for about 3 seconds (TV buttons are just below lower left of screen)
  2. Scroll down the SERVICE MENU to No. 14 LAMP REPLACE
  3. Press VOL |> button to enter lamp hours
  4. Press OK button to RESET hours, or CANCEL/EXIT to Exit menu
Hope this helps.
Cheerz ;^)
Feb 29, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
