Question about Sewing Machines
The thread balling up after a few stitches. What needs to be adjusted?
    Top Expert:
  • Sewing Machines Master
  • 49,327 Answers
Balling up under material ( birdnesting) is from the needle thread tension not tight enough
using scrap material keep adjusting until the threads meet at the center of the materials
may need to be readjusted for different thread thicknesses, materials and needle eye sizes
Posted on Apr 15, 2017
I can sew a few stitches did it all balls up at
Thread balling up in the bobbin case usually indicates that the TOP thread is mis-threaded (usually at the take up lever). Check with your manual for proper threading path.
Sep 02, 2014 | Sewing Machines
How do I get the stitch length to be consistent? It changes with speed
consistent stitch length depends primarily on tension settings. there are 2 different tension settings on all machines. 1. upper thread tension. 2. bobbin thread tension. since these work together to create the correct stitch length+width, having either of these adjusted inappropriately can significantly impair stitch quality. "knowing' your machine has a lot to do with knowing how tight or loose the tension should be for BOTH settings. the settings will be different for each type of stitch, for each type of needle used, and for each type of thread used, meaning tensions will need to be re-adjusted after each change. in other words, the setting for a medium-width zig-zag with a size 10 needle using mercerized cotton thread to sew light-weight canvas will be completely different than the settings for a regular straight stitch using a size 8 ball tip needle using polyester thread to sew silky lingerie material.
Jun 14, 2014 | Brother PC-420
Singer 534 skipping stitches
Most sewing machines will sew well on sturdy woven fabrics without being perfectly adjusted. However, because knit fabrics have more stretch, and have a tendency to pull the needle in one direction or another, a sewing machine has to be very well adjusted to sew on them well. You needle clearance or timing could be slightly off, and would cause the machine to skip on knits. Unless you have a reasonable amount of experience with adjusting sewing machines, it would probably be best to take your machine to a repair shop to get it adjusted. Make sure you tell them what kind of thread and material you are working with. Take some samples if you can.
Mar 19, 2014 | Janome Sewing Machines
I have a serenade, and problems from the start. It skips stitches, upper thread breaks with all tensions, or just too tight and it doesnt stitch just makes loops and tangles up. A friend of mine has had...
try a new ball poine needle. Sounds like intermittantly not picking up the bottom thread....It doesn't take much to shorten the needle just a hair to cause this, especially with sharps. Try a ball point needle...The last longer and are more durable. I sew everything with a ball point. Top Thread will also break if the top tension is too tight. Remember, when adjusting tensions, baby steps all the way...just a lil' smidgen might be just what you need. Also, always make certain the machine is level so that the settings don't vibrate out of adjustment. Dusty Tread will also brea easy. Keep threads clean and dust free. Good Luck
Sep 01, 2011 | Singer 2250 Tradition
Viking Designer 1 balleds / Birdnest / issues after repaired from Husk service center in midwest - replaced thread needle and adjusted tension .. freequilting and embroidery situations
birdsnest refers to a mess of thread on the underside of fabric when you start sewing (after a few stitches all looks good). if this is the case and it is happening during embroidery, switch off jump stitch thread cutting.
if it happens at the start of normal sewing, either hold your needle thread when you start sewing or make sure the needle thread is under the presser foot and held by the presser foot when you start sewing. this way you will have an inch or so of thread on top of your fabric which you can trim instead of a mess underneath.
if there is a mess underneath for more than first few stitches, either your check spring in the needle tension area is set incorrectly, or your needle tension is set too loose (adjustable in sevice menu by tech only) or there is foreign matter caught in tension assembly preventing proper tension.
scott
Jul 26, 2009 | Husqvarna Sewing Machines
Skipped stitches
You will need to take your machine to a dealer and have it adjusted. Machines should be cleaned and serviced at least once a year. Needles should be replaced when dull. Skipping stitches can also be from using the wrong kind of needle. When quilting on cotton, use sharp needles, when sewing on knits use a ball needle. You can use a universal needle but they aren't perfect and will cause skipping on some fabrics.
Apr 26, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
