Question about Craftsman Garden
Craftsman 7.25 platinum never change oil model. cut most of yard, then it just died. pull cord, starts for a second then dies. no clue
    Loyalty:
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 1,303 Answers
First remove spark plug if it looks good spray gas in the hole put spark plug backpull cord if it fires coil is good your problem is in the carb or fuel filter has to be one of these
Posted on Jan 01, 2018
fixincars
  • 335 Answers
SOURCE: 1991 Chevy Lumina 3.1 Sedan Starting/Dying Problems
Ok this was all after the car was all warmed up how far can you go from a cold start until it "dies:?
I want to suspect a crank sensor or ignition module just because of the symptoms if nothing happens until the egine gets hot ,typical of a failing crank sensor andignition module, always replace them togother.
But there is one more culprit, the catalytic Converter, see they break up inside and over time the catalyist bounces around and becomes a ball, on acceleration the presssure of the exhaust pushes the "ball' of caytlist into the exhaust pipe opening restricting it until it shuts off the car. You pull over the pressure goes away the "ball" falls back into the cat, you start again and it starts all over again. I would hve the cat tested and you can do a test yourself hit the cat on the bottom with a hammer and if you hear some rattling inside when you hit it yhe catalist is broken and is likely your problem.
If this information help you please leave me a good rating
www.aceautomotive1.com
Please contact me if I can be of any further help in tis matter
the above website is my own experiences in my automotive diagnostic shop for 14 years check out the FAQ and BLOG I believe your symptoms are listed there
Posted on Aug 11, 2008
  • 8 Answers
SOURCE: Mower starts up great and then dies
If it's a briggs engine, sounds like you have water / debris in your carb fuel bowl. Using spray carb cleaner will only work if you remove the bowl and clean the carb jets. Also, you could have water in the gas tank as well. First, remove your air filter, then remove the 3 screws that attach your filter bracket to your carburator and mower. Take off your fuel line at the carb and drain all your gas into a clear jar. If it looks very yellow, cloudy, or see water in the bottom of the jug, change your gas. Using a half inch socket wrench, after gas line is disconnected, remove the fuel bowl and clean with carb cleaner. Also, examine the bolt you just removed. There are 2 jets in the side and one at the end. Using the carb cleaner, make sure they are clean as well. Use the carb cleaner extension tube to spray up inside the bottom center of the carb, where the bolt threads, to clean that area as well. After all this make sure ur float assembly is intact and reassemblt the bowl to the carb and reattach the the fuel line. finish bt reattaching the air filter support bracket makinf sure the gasket between the carb and the bracket isn't damaged.
Posted on May 25, 2009
SeaDaddy46
SOURCE: Craftsman GT5000: Dies when switch is pulled to engage blades
I have the same tractor. If you have the transmission in <reverse> this will happen every time. It's a safety feature. Be sure the tractor is in <neutral> or one of the 6 forward gears.
Jim Romines
Posted on Jul 31, 2009
SOURCE: Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
Posted on Aug 28, 2009
RonInFla
  • 86 Answers
SOURCE: STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Posted on Apr 18, 2010
Testimonial: "Haven't tried the suggested solution but makes sense."
Craftsman 22" self propelled platinum series lawnmower died while pushing it. wont restart. ????
A good place to start is taking the air filter off. Then try stArtingvit again. Often a dirty air filter will not allow a mower to stay running. If that does not help. Remove the cover under the carburetor looking for dirt in the cover. Also well the cover is off remover the small pin that holds the float in place. Pull the neddle valve out cleaning it and the other parts with a carburetor cleaner then reassemble
Jul 21, 2014 | Briggs & Stratton Garden
My Craftsman PYT9000 garden tractor starts and then dies
There is a fuel cut off solenoid located on the carburetor fuel bowl. This can fail sometimes and stop the fuel from entering the Carb. Also check for pinched fuel line, clogged fuel filter. Some models have a second reserve tank. Check for tank selection valve. Hope this helps.
Sep 14, 2013 | Craftsman PYT 9000 26 HP 48" Yard Tractor
My kia 2001 starts pulling and dies slowly
Try a new or used mass air flow censer. You can get one for about $20.00 at any good wracking yard. Good luck!
Aug 04, 2012 | 2001 Kia Sportage
Mower dies when put in gear
have you checked the mower bed to see if its free to turn over,,if the bearings have sezed up or are tight this loads up the mower engine
Jul 05, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Apr 18, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Mower won't start, pull cord now locked up
when you say it's full of oil you don't mean it's all the way to the top of the dipstick. because if that is the caes you will have to drain most of the oil out until the oil o nly goes to the full mark on the dipstick.that would explain why you can't pull on the starter rope there is no where for the internal parts to move to it's being blocked by all the oil...good luck
Apr 09, 2010 | Garden
I have a craftsman zts 7500 zero turning radius 26 hp with a pull knob over elec.To turn on the blades.It also has an elec.raised deck.When I pull the knob to turn on the blades the engine dies.And when I...
i going to assume that yr tractor does have the hydrolic p.t.o. that controls the drive and cutting mechanism's???... if so you might start with checking the hydrolic fluid in the resevior. or you might check into replacing the hydrolic p.t.o. pump , if you ran the tractor in heavy work without any hydrolic fluid in the p.t.o. pump the pump is probably burnt up. if so im sure you can beat the cost of a new pump by rebuilding it yrself with a kit.
Jun 24, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
48 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
