Question about Garden
I have a snapper riding lawn mower serial number 2016722750. I need to troubleshoot why it will not turn over and start.
I checked the fuse just above the new battery and it is good but i still replaced it. give me a list of other items to check. i replaced the spark plugs. checked the terminals connections,
  • yadayada
    yadayada Apr 15, 2017
    You say it will not turn over, to a tech that means the engine doesn't spin when you try to start, or do you mean the engine spins over but doesn't fire up?
SOURCE: mtd mower blows fuse when you try to start it
Pull the starter and have it bench tested. If it is ok then you may have an engine timing problem. ''Good luck. donnyb60
Posted on Mar 24, 2009
  • 1129 Answers
SOURCE: My riding lawn mower won't start. New battery
Spray starting fluid into the air box if it starts and dies out there is a fuel delivery problem if the mower has a petcock fuel shut of valve disconnect the fuel line after the petcock and hold a container under the hose turn on the valve to ensure gas flow to carb if there is no petcock valve I would still check the line to carb make sure gas flows through the hose to carb.
Posted on Jul 23, 2009
  • 88 Answers
SOURCE: no spark from spark plug in honda lawn mower
the pionts could be bad try changing them
Posted on Aug 30, 2009
  • 39 Answers
SOURCE: John Deere LT145 Automatic riding mower will not
I would check seat switch. To do this just lift the seat and you should find it there. To test if the switch is playing up, remove the two wires coming out the back of the switch and run a piece of wire between them both. This will create a closed curcuit telling the mower that you are sitting on the seat when your really not. Also look to see if the mower has the deck cutters engaged, they wont start if they're on for safety reasons. Easy to do.
Posted on Apr 06, 2010
  • 608 Answers
SOURCE: Craftsman 17hp 42" cut riding
Sounds like its not getting enough fuel. clean the fuel system and the carby. The valve clearances also need to be checked.
Posted on Apr 11, 2011
Brake system
Michael, Check the attached links, 1st link is snapper where you can get info from support,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tractor Riding Lawn Mower Products Snapper Mowers Tractors
Snapper Lawn Mower Transmission Brake Clutch Parts
Snapper Brakes
Snapper Lawn Mower Parts Lawnmower Parts Discount Online Parts
Apr 09, 2016 | Snapper Garden
Where can I get a free wiring diagram for a 1996 12.5hp snapper riding mower
Go to the Snapper Website, enter your Snapper mower serial number, the engine serial number and search manuals. If no success, google it.
Sep 21, 2015 | Snapper Garden
How long is the deck belt for a snapper riding mower LT 150H38IBV
Go to the Snapper Website, Go to Manuals/Parts lists, enter the model and serial number of the mower. Scan for the proper diagram, copy the belt serial number. Go to a belt specialty retailer, present the belt serial number. They should be able to supply the belt length, and probably the belt.
Sep 12, 2015 | Snapper Garden
48" snapper zero turn yard cruiser
ether bad check valve or pump went out check valve 100.00 if pump 300.00
Sep 07, 2014 | Snapper ZT2748 48" 27HP Zero Turn Lawn...
SR1642 Snapper rear engine, what is the fuse for?
Most the fuse is for starting. The park brake probably has a safety switch. It needed adjusted.
Jun 24, 2014 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
Snapper diagram belt replacement
Your owner's manual should have a diagram.
Jun 21, 2014 | Snapper 7800765 Riding Lawn Mower, Zero...
I have a snapper lawn mower that keeps blowing fuse when I try to start it.
Check all your wiring, I believe you have a shorted wire. GOOD LUCK FRIEND.
Apr 03, 2014 | Snapper Garden
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
