Question about Psi Garden
Greenworks 1700 psi starts ok, but cuts off after about 5-10 minutes. After waiting a few minutes, it will run again.
    Top Expert:
  • Psi Master
  • 77,987 Answers
Check and see if it losses ignition spark when it stalls, if it does the ignition pickup may be defective.
Posted on Apr 15, 2017
I have an electric greenworks 1700 psi pressure washer that starts then stops repeatedly how do ya fix it
Sounds like the thermal switch is shutting it down. It is either bad or something is causing the motor to run too hot.
Jul 30, 2016 | Greenworks 1700 PSI 1.4 GPM Electric...
On page 25 under trouble shooting for greenworks 1700 it states that you can turn nozzle tip to a high or low pressure position. how is that done?
The owners manual was badly written by someone in China whose English is a second language. The output pressure is set at the factory. The only thing the consumer can do is change the spray pattern by changing the nozzle. 0 for pinpoint, 25 for small fan spray pattern, 40 for large fan spray pattern, and Soap for dispersal.
Jul 08, 2016 | Greenworks 1700 PSI 1.4 GPM Electric...
Wiring diagram for replacement motor
Here is a pdf file maybe this will help.
The power cord has three wires there should be a green =ground black hot white neutral.
May 15, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
How to get detergent to feed into Greenworks 1700 psi washer
The only way that it will feed detergent is by using the correct nozzle for the detergent. It's a lower pressure tip which allows the valve for the detergent to open. It's the black tip. It's either that or if it's an older one, there is a twisting wand that controls the pressure and spray pattern, which has to be twisted to the widest pattern with lowest pressure
Nov 10, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
I need to replace the high pressure hose on my Greenworks 1700 because the one I have has developed a hole after being in storage/no use for a few months. I purchased a replacement hose at Lowe&a
Search Fixya with your question as it was answered last June.
If less than a year old contact the manufacturer. My hose burst (different brand); turns out they got a bad batch of hoses and they replaced the whole unit at no cost.
Sep 13, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
How do you take the hose reel off on a greenworks 1700 psi pressure washer?
There should be a clip that holds it in place, see link.
Jan 12, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
Cuts off in warm weather after about 10 miles
Don't rule out fuel pump. Had a 95 do the same, ran great when cool in morning then when it got hot in afternoon, it would quit. Wait 15-20 minutes & go again, sometimes got me home, other times a few more miles until it cooled down again. Luckily I had access to a fuel pressure gauge. Cool in morning had 49 psi, when it quit, 2 psi. Wait 20 minutes, 49 psi again. If you can drive it around until it starts to act up then run into a repair shop for fuel pressure test it will confirm it. If not, they may need it all day to monitor the fuel pressure & confirm it is pump. If your a gambler, change it & fuel filter. One thing I did get was trouble codes indicating a lean mixture, due to starving for fuel. Have you cycled your key to retrieve any codes yet?
May 20, 2009 | 1996 Dodge Neon
Garden Logo
Top Psi Garden Experts
John Trevino
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
