Question about Saeco Coffee Makers & Espresso Machines
My Saeco Talea espresso machine had a blinking red light and I tried to turn it off. Now it won't work at all :(
  • 8 Answers
SOURCE: saeco odeo giro and the red squiggly light
This is the descaling indicator.
If it flashing your machine needs descaling.
Posted on Jun 24, 2009
EsWorld
  • 1618 Answers
SOURCE: Brew light blinking
It is telling you that the temp on the machine is too low. It is possible that one of the thermostats on the boiler is damaged.
Posted on Sep 17, 2009
SOURCE: out of service 16 message on a Saeco 8P espresso vending machine
Data Problem. hold reset button on inside of door while switching machine on. keep holding button down until it asks for a password(0000) or says system management.
Posted on Nov 01, 2010
SOURCE: i have a saeco Talea giro espresso maker, all the
Any solutions, Because I'm experiencing the exact same problem.
Posted on Nov 29, 2010
  • 4 Answers
SOURCE: Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Posted on Apr 17, 2011
Saeco talea giro flashing red exclamation point
take out the coffee waste bin, on the side facing into the machine, there's a little metal bit, it's a kind of sensor.
Clean it if it's dirty with a screwdriver or some wire wool.
Have you cleaned the brew group lately?
Sep 06, 2014 | Saeco Talea Giro Espresso Machine
My SAECO Talea Giro is not working. I have cleaned it properly and coffee beans and water is filled up. The red exclamation mark and the warm water lights are flashing. I can produce steam without a...
The thing that comes to mind is the brew unit is blocked and or the grind is too fine. Remove the brew unit and clean the screen under the red o-ring.
Aug 06, 2011 | Saeco Talea Giro Espresso Maker -...
Saeco Talea Giro Plus, descaling following instructions step by step. In step 12 the descaling light did not turn off. The warning light came on as indicated. In step 15, pressing the descaling button...
Try doing another rinse cycle until water tank empties. I had to do that a couple of times, then the red exclamation mark came on. Then I turned knob to off position, refilled water tank, pressed the descale button for 6 seconds, green light came back on and it did its priming.
Mar 26, 2011 | Saeco Talea Giro Espresso Machine
Hi, I have a Saeco Talea Giro Plus machine and have only used it a few times. Now the alarm light is permanently on, but the machine has enough coffee and water and the drip tray and dregdrawer are empty....
Hi Natasja, try pull out the driptray and dreg draw while the machine is on and wait about 10 secs. When the red light start flashing, put the parts back. The red light should dissappear. Good luck.
Jul 03, 2010 | Saeco Talea Giro Espresso Machine
I have a Talea Giro and the red alarm light keeps flashing. I have refilled water and coffee and cleaned the brewer. Sometimes it will work after turning off and on again. Sometimes heats up and is ready...
Checklist:
  • Water tank full
  • Remove dregdraw for at least 10 seconds then re-insert
  • Beans in hopper
  • Beans lid correctly inserted
  • Steam knob Exactly in off position
Feb 25, 2010 | Saeco Talea Giro Espresso Maker -...
My Saeco Talea Giro have the wave like symbol with three parallel lines is flahing red. What is wrong and what can I do to fix it.
It is saying..it's time to descale the machine. If you want to get rid of it, just press the water button and hold it for 5 secs.
Jan 30, 2010 | Saeco Talea Giro Espresso Machine
Saeco Talkeo Giro
indicates that descaling needs to be carried out. To cancel Press and hold the hot water button until indicator light goes off (about 6 seconds)
Mar 01, 2009 | Saeco Talea Giro Espresso Maker -...
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
