Question about Kenmore Dryers
I have a stackable kenmore the dryer says clean lint but I did it still won't work it says its drying but it isnt
    Top Expert:
  • Kenmore Master
  • 76,846 Answers
Did you clean the air exhaust tube at the back of the dryer, do that as well, it may be plugged.
Posted on Apr 15, 2017
jsrock516
  • 5911 Answers
SOURCE: Kenmore dryer...How to remove toe panel to clean lint out.
Insert a putty knife into the seam where it meets the front panel about 2 inches in from each side. There is a small retainer clip that you will need top depress in order for the panel to release. If you go to searspartsdirect.com and enter your model number, you can find a helpful illustration under the "Cabinet" heading. The clips I mention are listed as item 46 just ot give you a perspective. I would also strongly recommend that you UNPLUG the dryer before cleaning the interior cabinet. There are live voltages present even with the dryer turned off. Particulary around the heating circuits. I hope you find this information helpful.
Posted on Oct 29, 2008
rylee_smith
  • 8619 Answers
SOURCE: Kenmore stackable washer/dryer...dryer making
Hi
If your dryer is noisy, check these:
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Posted on Mar 18, 2009
  • 88 Answers
SOURCE: ''clean lint filter'' light is on- dryer will not work
is the door trigger working properly if its faulty then the dryer will not work
Posted on Jun 05, 2009
jsrock516
  • 5911 Answers
SOURCE: Our Kenmore 80 series gas dryer won't dry clothes.
Have you checked the entire run of the exhaust vent ducting? Cleaning the lint trap is not nearly enough to keep a dryer running efficiently.
A simple test you can try is to remove the exhaust vent hose from the back of the dryer and attempt to dry a load as you normally would. With the hose removed and the dryer running, the air leaving the exhaust of the dryer should be forceful and warm (about 140 degrees). If the air flow is weak or non-existent, you have a clog INTERNAL to the dryer. You will have to inspect the air blower fan housing and ducting inside the dryer to ensure the blower fan is not obstructed in any way. If the air flow is normal and the clothes dry like they should, you have a clog somewhere in the DUCTING from the point where it leaves the dryer to where it exits your home. You will need to inspect the exhaust ventilation for any clogs or kinks.
If you can see the heating element glowing, you probably don't have a problem with the heating circuitry. If you haven't checked the dryer ventilation recently, now might be a good time to do so. Leaving a dryer in a clogged, or poorly ventilated condition can cause the dryer heating circuits to over heat to the point of failure. In addition, this can also create a fire hazard.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 01, 2009
jsrock516
  • 5911 Answers
SOURCE: Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
Posted on Sep 29, 2009
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
Kenmore Elite Smartheat Quiet Pak 9 gas dryer HE 4T won't start
does it heat up, when it works does it dry right.
Mar 03, 2012 | Kenmore Dryers
My Kemore stackable dryer does not work properly. I have to run the dryer 3 or 4 times to dry a load. Does feel hot at times when I open the dryer and feel the clothes.
Perhaps you have an air restriction of some sort. Cleaning the dryer and checking the vent can greatly increase efficiency. I recently replaced the glides and belt on one of these and made some repair photos. The dryer was plum full of lint all over the controls and everywhere. I took a shop vac to it before I snapped the pictures later that day. I have included a manual also HERE.
Dec 27, 2010 | Kenmore 98702 Stacked Washer/Dryer
Takes three cycles to dry
you may need to take apart the dryer and make sure that the exaust line isnt clogged up with lint,paper,ect.
May 15, 2009 | Roper REX3614KW Electric Dryer
It takes a long time to dry a load of clothes
sounds as if you may have an issue with a blocked/clogged ventin, perhaps wher it leaves the home, a unit that is not able to expell the heat will tend to not dry the clothes properly, 2-3x to dry a good sign of venting issue
Jan 14, 2009 | Kenmore 98702 Stacked Washer/Dryer
Heating problem with stackable washer/dryer combo
check the duct work going out of the house if it is clogged the clothes wont dry. Birds love to build nest in a open dryer vent and if you have any bends lint will build up get these clean and it should get you drying again
let me know what you find
bill
Jan 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Extreme heat, electrical smell
there could be lint on the heater also. clean if ve t-statso. you could also have a defecti
Feb 18, 2007 | Kenmore 84152 Electric Dryer
Dryers Logo
26 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
