Question about Refrigerators
The evaporator fan motor makes a high pitched whine when it comes on. This issue does not occur with the other fridges of the same model that we have.
  • Refrigerators Master
  • 2,937 Answers
Hello Ron Rommelfanger,
BINGO...!
That's why they sell replacement motors...!!
Use your make & model to look for the best price on a replacement. Video guides are available on some sites.
All parts houses pretty much sell the SAME PART...
Take good photographs of the way everything is currently wired...
Properly restore all the wires and make sure to secure them as the were
(away from the FAN BLADE)...
You will be proud.
USA market search will yeild
applianceparts
Search Over 2 1 Million Appliance Parts
partsselect
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Posted on Apr 15, 2017
SOURCE: Ge side by side - high low humming noise from freezer section
I have a hotpoint HSS25GFPJWW fridg. The coil that opens the flapper door for the ice was bad so i replaced it . Now when i push the leaver in to get ice the fridge shut's down like ther is a large power drain. This was doing this before i replaced the coil but the flapper door was not opening then now it opens. It evens shut's the compressor off.
Posted on Apr 22, 2008
  • 311 Answers
SOURCE: Whining noise from freezer
Fan motor is bad and needs to be replaced.
Posted on Nov 28, 2008
  • 115 Answers
SOURCE: Decreased suction and high pitch whine in motor
clean out suction tubes ther is something caught in them
Posted on Dec 13, 2009
espressonist
  • 1711 Answers
SOURCE: fridge is whistling
We have summarised all possible problem for this case here to this link
http://www.fixya.com/support/r6008187-side_side_refrigerator_whistling_sound
Posted on Sep 15, 2010
bobjohns
  • 51 Answers
SOURCE: I have a GE model GSL25JFTA BS that was making a
Sounds like the evap motor and can be found at appliance parts pro part # AP3875639 $44.36/ the mother board if you would like to know is part #AP4436216 $134.95 but i would not waste the money.
Posted on Sep 28, 2010
Intertherm furnace model m3rl060abw blower makes high pitched whine when running. why? how can i fix it?
not familiar with that specific model, but if it's high pitched, it is likely the induced air blower causing it. sometimes it is possible to disassemble the motor and clean and lubricate it, but the repair that most service personell will do is to replace the motor. often it comes as an assembly which includes the motor and fan.it's the easiest, longest lasting, and quickest solution.
it is possible that it is the circulating blower with a seized bearing causing the whine. if so, the bearings (and shaft) can be replaced.
Jan 27, 2013 | Heating & Cooling
Kenmore refrigerator making high pitch noise top front
could be the ice maker or the evaporator fan motor.you can try lifting the arm up on the ice maker and see if it stops,this will shut off the ice maker.also when you open the freezer door to lift the arm on the ice maker the evap fan motor should start when you open the door,you should hear it blowing around,is this the noise you hear?these are the two things i can think of that could make a noise up top,if not it could be the compressor or the condenser fan motor but these are down the bottom back of machine but still could be the problem,if the ice maker and evap fan motor both in the freezer are ok pull out the machine and remove the bottom back panel and check to see if the noise is coming from there where the condenser fan motor and compressor are,you're going to have to do some detective work to find the noise,hope this helps you out.
Aug 19, 2012 | Refrigerators
GE fridge: a motor whine that comes and goes, and the fan is pulsing
THE WHINING NOISE IS DUE TO THE FAN RAMPING UP AND DOWN IN SPEED. THIS CAN BE EITHER A PROBLEM WITH THE EVAPORATOR FAN MOTOR ITSELF OR THE MAIN CONTROL BOARD ON THE BACK OF THE UNIT. MOST OF THE TIME IT IS THE CONTROL BOARD BUT IF YOU WANTED TO FIX IT ON THE FIRST SHOT I WOULD REPLACE BOTH THE CONTROL AND FAN MOTOR. MAKE SURE YOU FOLLOW THE INSTRUCTIONS THAT COME WITH THE CONTROL BOARD VERY CAREFULLY.
Jun 15, 2011 | GE Refrigerators
I have a GE model GSL25JFTA BS that was making a high pitch whining noise coming from where I believe was the freezer area. If I shut off the power it stops, but after a short period of time it returns. A...
Sep 28, 2010 | GE Refrigerators
The fan in the freezer makes a high pitched whistle when it is on. Also, the ice maker seems to overfill which causes the cubes to stay all stuck together and are breaking the plastic thing that moves the...
Thi over filling ice maker is cause but the ice maker water valve laking water by when it is supposed to be closed. The only remedy for this is to change the water valve. The water valve is item 800 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5131037&diagram_id=22223831#d22223831
close up view:
http://www.appliancepartspros.com/part_details.aspx?part_id=3192626
The high pitched wine from the evaporator fan can either be the fan bearing or ice build up. If your not noticing the freezer temps warm up I would suspect the fan bearings. If you notice things like soft ice cream then you may have an automatic defrost problem. To isolate the possibilty of an automatic defrosting problem and post procedure fan test perform the following manual defrosting steps:
1. Unit unplugged
2. Remove freezer contents
3. Place a fan blowing into the freezer compartment for 2 hours
(Messy - rags and mop required)
4. Wipe residual water in freezer compartment
5. Plug in unit
6. Reload freezer contents
Check for fan whine and normal temps in 4 hours.
If the fan is no longer whining you probably have an automatic defrosting problem. If it still whines you can try lubricating the fan motor bearings with "Zoom Spout" oiler (Any Appliance parts source carrys this for under $3.00) Do not use regular oil! It will cause the fan motor to sieze in about 1 month.
Worst case the evaporator fan motor would have to be changed:
Item 610 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5131037&diagram_id=22223826#d22223826
^- Note there are 2 types of fan motor. One with thermistor and one without. Both are listed under item 610.
Replacement plastic parts for the ice maker can be found here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5131037&diagram_id=22223828#d22223828
There are several internet sources for all of the parts above. Links are provided for reference.
Thanks for choosing FixYa.
Kelly
Sep 18, 2010 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
NEW HIGH SPEED EVAPORATOR FAN MOTOR TOO LOUD Repair technician told me there were problems with the original evaporator motor and replaced it with a new high speed one. Now the fridge is too loud. Before...
It's the rotors making the noise not the motors! I replaced the motor, still made noise, I took off rotor blade sanded it down around each blade, no more high pitched hum!
Jan 12, 2010 | Frigidaire FRS26H5AS Side by Side...
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
Nov 26, 2008 | Refrigerators
GE FRIG Model GSL25JFPJBS
my ge fridge has a hi pitch sound.
I hate it
Aug 14, 2008 | GE Refrigerators
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
