Question about Garden
The rope pull will not go back in on our new wood maxx wood chipper.
  • Garden Master
  • 3,044 Answers
Hello Angie Rogers,
If it is INDEED new...
Promptly RETURN it for a DECENT ONE...
The return spring likely being broken ... it is not something that generally heals itself (sorry).
Carnac the Magnificent
Posted on Apr 15, 2017
  • 83 Answers
SOURCE: my chipper is throwing long chunks of unchiped
Either your blades are dull or the gap between the intake tray by the blades is too far or is rounded off. Many chippers have a plate on the intake by the blades that can be flipped around when it rounds off. Also some have a edge on the other side of the blade so it can be reversed and give you a fresh edge. Be sure to unplug the sparkplugs and remove the key when going into your chipper to ensure no one can start it when your in it. There is usually a lock bar to keep the blades from moving.
Posted on Mar 31, 2009
  • 6 Answers
SOURCE: Wood Chipper how to
Great input tina783. I have just one thing to add. Try to shred the branches within a reasonable amount of time. I found out that with my shredder, if I put older, dried up branches in, it tends to take a lot more time, as well as tosses chips back out at you. With newly cut branches, this wasn't nearly as much as an issue.
Posted on Apr 29, 2009
  • 9 Answers
SOURCE: Cannot pull the pull rope. Feels like motor is
Posted on Sep 08, 2009
Testimonial: "dallascuz was right on the money. It was oil in cylinder. Thanks a lot for the info. Harold"
SOURCE: looking for manual for troy-Bilt super tomahawk wood chipper
here is the link to the manuals for the 47266
enjoy :)
Posted on Sep 13, 2009
SOURCE: ineed to sharpen my wood chipper blades on my
It takes me about 5 minutes to Remove, Sharpen, and Re-install my chipper blade for my Bolens mc2500. First, If your using a screen or rollers in the discharge, then remove them. Look underneath, and you will see the thick flywheel. Make sure the spark pug wire is disconnected, then slowly turn the flywheel by hand until you see the two hex head bolts that hold the chipper blade to the flywheel. Also remember which way you take it off, so it goes back together the same way. using an open end or combination wrench remove the two hex bolts. Now to sharpen, I use a medium/ coarse honing tool made for lawnmower blades. I clamp the blade to the top edge of my Bolens with a pair of visegrips, then a little oil, and the sharpening tool, and I'm done sharpening in about 2 minutes, and then re-installing, reversing the removel process. I hope this helps.
Posted on Sep 01, 2010
Hard pulling starter rope
You say Pull rope mechanism is ok, How do you know that? Ive's seen them get the rope a little off and gets caught being wedged into a small clearance. Is the rope wearing? I bet if you take it apart put a new nylon rope and some wd-40 in rubbing surfaces including the ratchet area it will be good as new. Crank bearing has to get really bad to effect pull. How is the spark?
Mar 13, 2015 | Troy-Bilt Troy Bilt Chipper Vac Plus Parts...
How do I put a new pull rope on my 5hp MTD Chipper?
pull the starter cover pull rope out to length lock the housing the rope is in, in place with a tool pull out rope. reinsert new rope into retaining hoe tie a not and cut off excess rope. put ropr through handle hole reattach handle and remove tool you used to hold the rope housing. This is if your spring and starter assembly are ok. Or you could stop being a cheap and let a shop do it for 5 minutes labor.
Jun 29, 2014 | Husqvarna Chain Saw 20" Bar
Ho do I replace the pull cord on my snowblower? I've removed the housing, removintg the 4 rivets, replaced the cord,however the tension on the cord is not taut. any suggestions? Thanks Ed
take the rope out with the starter on the table turn counter clock wise about 6 to 7 turns. lining up the holes, stick a screw drive throw the holes to hold. feed the rope throw tie off pull the screw driver out let the starter pull the rope in tie to handle.
Oct 13, 2009 | Briggs & Stratton Heavy Machinery
Need to replace the recoil rope and handle on a tecumseh hm80 155481 p 8hp horazontal shaft motor. never done one before so any suggestions would be great
take the 4 bolt out of the starter housing, lay on table take the old rope out. turn the center rope pulley counter clock 6 to 7 full rotation's so the center pulley hole lines up with out housing hole(steck a screw drive throw to hold pulley in places). feed the rope from outer throw the center tie off. let the pulley dr ow the rope in. pull the rope out a Little tie off to handle
Oct 08, 2009 | Yard Machines Heavy Machinery
The impeller does not rotate.
Sounds like you probably have a large piece jamming the impeller. Look for an inspection cover somewhere on the outside of it. remove the cover and try to turn the impeller backward with a pry bar of some sort to free it up. DISCONNECT THE SPARK PLUG BEFORE BEGINNING!!
Jun 27, 2009 | Heavy Machinery
Pull-start rope won't pull
This has happened several times for me and is usually caused by a peice of word jamed in the input hopper and half cut by the blades. Always make sure there is no wood in the input chute before stopping motor. remove the collector bag and use a long pry bar to reverse the flywheel. if this moves backwards you may then be able to remove the peice of wood jammed in the blades thru the input chute. Long Skinny arms is required to reach down the chute. Use a Flashlight to see if this is your problem.
Jun 26, 2009 | Troy-Bilt Chipper Shredder
10 hp Troy Built chipper pull start frozen
If a branch was already being chipped when it ran out of must clear the hopper of any chunks of wood in it. Pull the plug wire and use a metal pry bar to dislodge any pieces of wood. when the flywheel runs free, put the plug wire back on and the choke on. Try it now!!!
Jun 14, 2009 | Troy-Bilt® Briggs and Stratton Chipper
5 hp briggs & stratton on a chipper/shreader
if the starter rope fails to retract, then you need to either fix a broken spring, or put a new one in. You'll have to take the engine cover off, and you'll be able to see how to take apart the retractor assembly. Often times, just the end of the spring will break off, and if you have a grinder, you can grind the correct shape in it again, and reinstall it as is.
Jun 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
What is a chipper?
Most of our industry refers to chippers or chipper-shredders as pieces of equipment that can handle both wood and leaves. These machines have both a chipping device and a leaf-shredding mechanism. This mechanism is basically a hammer mill, cylinder or drum with a series of pivoting flail-type knives. The chipper-shredder usually is a smaller machine and may include a vacuum to clean up leaves. These machines can be self-propelled or stationary. Most chippers are disc-type, consisting of a large, heavy, rotating disc with knives mounted to it and are for chipping wood only.
Aug 27, 2008 | PDP Systems 1.5 Horsepower Electric Wood...
Wood Chipper how to
Aug 27, 2008 | AMANA TOOL 658060 PRESTIGE FINE DADO SET...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
