Question about Garden
Jd 265 wont start changed seat switch not the prob and it has new batterie
  • 376 Answers
SOURCE: the mower will not start, already check start, is
OK, I left the part out that the light should light up whether or not the solenoid is good. There should be power going to that wire whenever the ign. switch is turned to start, assuming the brake is locked down and the blades are disengaged. Since it doesn't light up, it means the problem is further back up the line. Unplug the ignition switch and look at the condition of the post on the back. If they are too rusty and/or corroded, you may need a new switch. Try cleaning the post and the connectors on the harness plug.
Posted on Jun 08, 2009
  • 1033 Answers
SOURCE: car wont start when warm
Sounds like the timing is off and valves need adjustments.
Posted on Feb 03, 2010
  • 712 Answers
SOURCE: car starts first time when cold but wont start or
Check your coolant level. Also make sure that your engine cooling system is all right.
Posted on Feb 05, 2010
  • 235 Answers
SOURCE: JD model # 135 wont start -
yes.. you need to be sitting on the seat to start the engine as you have to have the brake peddle depress as well
Posted on Apr 10, 2010
  • 2702 Answers
SOURCE: yamaha atv wont start new battery was working
first check the starter relay it could be faulty,,,then check the starter motor,,that could also be the fault,,,my gess is its the motor?
Posted on Jun 03, 2010
Battery ok, but nothing when I turn the key. Does this model have a fuse under the seat
ALL JD Tractors have a seat switch. But you have several other safety switches as well. Neutral safety switch, Mower clutch off switch. Pedal Switch. On the back of the key switch there are several wires. you should see two yellow wires. Put a jumper across these two wires and try again to start it. If that solves your problem one of your safety switches is bad. But I would start with the seat switch. Unplug it and install a jumper across the wires going to the frame. Then try to start it. 9-10 times its that switch that goes bad.
Apr 17, 2016 | John Deere Riding Lawn Mower. D170 54 in....
JD X595 4x4 mower - Starts OK, BUT, as soon as the brake is released, the motor cuts out.
I would try bypassing the seat switch and the brake switch. Do this one at a time to determine if the switch is bad. Also buy some Sta-bil fuel stabilizer and gel remover. I recommend this for any seasonal equipment. Often the engine is not getting enough fuel and will stall when the pto is engaged. Sta-bil often rectifies this problem.
Mar 06, 2015 | Light Garden
Jun 13, 2013 | Jonway Motorcycles
JD 855 the idle spring broke and th hydrostatic pedals would not return to their neturel position . before I new what had happene I pushed the reverse and the tractor lunged backward then I pushed the...
Yes there is a safety switch.And this safety switch has to be engaged.If its not engaged then the JD tractor will not start. On JD 855 the safty switch is located under the seat, There is a rod that must be depressed before engage Somehow that rod is bent or its not pressing the switch to the point that the seat would not fully engage the safty switch.In some cases the switch itself is faulty.It has to be checked . Thanks. keep updated for any more can rate this solution and show your appreciation.
Jul 20, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere f525 mower, wont start, battery good, ignitor good, coil good, no positive power to ignition switch, electric on off switch for cutter looks tampered with, and a safety switch below frunt of...
The front mount mower has a safety switch on the park brake linkage and the seat belt linkage as well as on under the seat which is for the PTO,The one under the seat on the linkage just behind the battery is a culprit that needs adjusting to get the PTO to engage but it sounds like you need to deal with the seat switch circuit or replace the seat switch.
Jul 08, 2010 | John Deere Garden
Apr 05, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My garmin won't turn on. I have tried the plug in
it does have an internal battery, but that normally wont prevent it
from turning on unless the battery is defective.
plug it in to the usb cable on your computer for a while (normally it will start right up) then slide to power switch to the on position for about ten seconds.
if that fails, press and hold the lower right corner of the screen and then slide the power switch to the on position while holding the lower right corner of the screen and follow the directions once it starts
i can give you something else to try before you go and spend money on a battery...a battery should be the last thing to do, even though it will more often then not fix the problem thats tempory..
if it turns out you think you need a battery, i will point you to one with instructions on how to change it.
Mar 12, 2010 | Garmin nuvi 265 Car GPS Receiver
Car wont start when warm
Feb 03, 2010 | 1995 Volkswagen Golf
I have trouble starting my 316 JD tractor. When I
I do not have answer I will like to have an answer for my 316 JD no power no lights on dash battery new and was running shot off and wont stared again.Thank You
Aug 15, 2009 | John Deere New Tractor Starter w/ 317...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
