Question about Canon Office Equipment & Supplies
When I press on the * key on a Canon MP11DX, it rounds out the number. How can I get the exact number?
E appear on screen, number keys not working.what should I do.
Customer Reviews: Canon MP11DX Printing Calculator
www.amazon.com/Canon...Calculator/.../B0006HWF...
Amazon.com, Inc.The keys (i.e., numbers) get stuck almost every time I use it. I have to actually wiggle the numbers so I can enter the next number. It's not the tape on the ribbon; ...
3 Using your calculator for fractions - The Open University
www.open.edu/...calculator/content-section...
United States Open UniversityMay 3, 2012 - Early Years ยท Working with Young People .... 11 Natural logarithms and powers of e on your calculator ... The figure shows the display on a calculator screen.... If your calculator is not in Math mode, repeat the steps of Activity 1. ... arrow keysto move between the boxes when inputting the mixed number.
[PDF]Canon MP270 series / MP250 series On-screen Manual
Dec 15, 2015 | Canon P27-DH 12 Digit Mini Desktop...
When i turn on calculator it will display but no keys will work. the (+, -, etc)
haas n e 1 dropped liquid on it? open it up and clean the contacts with isoproponol alcohol. or check power lead to number pad
May 19, 2015 | Canon MP11DX Two-Color Printing Desktop...
How to change ribbon on canon mp11dx calculator
See Page 3, top right column for ribbon change instructions and images.
https://www.manualslib.com/manual/355934/Canon-Mp11dx.html
Apr 15, 2014 | Canon MP-11DX Calculator
"E" SHOWING UP IN LOWER LEFT CORNER.. HOW DO I GET RID OF THIS
You have entered something that takes more numbers than the calculator can handle...hit the clear key (C) I think...or turn it off and then on again.
Jun 28, 2013 | Canon MP11DX Two-Color Printing Desktop...
How print out total on canon mp11dx
If you are adding, use the star key "*".
Good luck,
Paul
Mar 05, 2013 | Canon MP11DX Two-Color Printing Desktop...
Can't find a manual online. What does 5/4 mean, and how do I turn it off? Same for E. My biggest problem is that when I add up numbers with the print function on (for depositing large batches of...
The manual for the Canon P1-DHV is online at http://www.usa.canon.com/app/pdf/calculator/P1-DHV_G_USA_HWB.pdf>.
When the display shows "5/4", the calculator is doing 5/4 rounding which means: 5 or above round up, 4 or below round down. To control rounding press the "5/4" key.
When the display shows "E" the calculator could not complete a calculation. It can be because of dividing by 0, or because the total exceeded 1 trillion, or because the operator entered calculations faster than the calculator could complete them. Press the CI/C key to clear it.
I can't explain why you are not getting a total on the tape. Try the following example from the manual exactly as shown, and let me know if your tape shows the total.
  1. Clear the calculator (press [CI/C])
  2. Choose 5/4 rounding (press [5/4] until "5/4" displays)
  3. Choose add mode (press [DEC] until "A" displays)
  4. Choose cost-sell-margin mode (press [B-T] until "B" displays)
  5. Turn printer on (press [PRINT] until "PRINT" displays)
  6. To calculate: $12.55 + $15.75 - $5.30
  7. Key in: 1255 [+] 1575 [-] 530 [=]
  8. Tape shows: [0. C] ... [12.55 +] ... [15.75 -] ... [5.30 =] ... [23.00 *]
Apr 07, 2011 | Office Equipment & Supplies
How do I set the date for this Canon MP11dx? I
Start by pressing down on the clock/calendar button for about 3 seconds. Then press the equal ( = ) sign to input the correct date. Same process for setting the time. then press the ce/c button to clear the data on the screen. When u want to print the date, press the calendar button. this will automatically print it. then press the ce/c button again so u can start calculating.
Enjoy!
Apr 09, 2010 | Canon MP-11DX Calculator
CANNOT SET TAX RATE ON MY CANON MP11DX
To change the tax rate on the Canon MP11DX (and most others):
Slide the "GT" button to "RATE", enter your tax rate and hit the "TAX+" button. Once changed, slide the "GT" button back to the "ON" position.
Oct 23, 2008 | Canon LS-100TS Calculator
Canon MP11DX
press the date/time button
press and hold the = button
once blinking set the date
press the = button again
once blinking set the time
the "x" button changes A / P
press the + button again
Feb 29, 2008 | Canon LS-100TS Calculator
Pritning TOTALS
Use the * key.
If this helps, Please rate me. Thanks, Patty
Dec 22, 2007 | Canon P23-DH Calculator
32 people viewed this question
old marine
old marine
