Question about The Office Equipment & Supplies
When I press on the * key, it rounds out the number. How do I get it to be exact?
How to reset date on royal cash register model alpha 710ml
Page 7
To set the date
1 At the prompt, use the rounded Number keys to enter the last 2 digits of
the year. For example, for 2006, press 06. Press the Amount Tend Total
<Enter> key.
2 Use the rounded Number keys to enter the 2 digits of the month. For
example, for February, press 02. Press the Amount Tend Total <Enter>
key.
3 Use the rounded Number keys to enter the 2 digits of the day. For
example, 24. Press the Amount Tend Total <Enter> key.
4 Use the rounded Number keys to enter the 2 digit hour. For example,
09. Use military, or 24 hour, time for hours after 12 noon. For example,
if you want to enter 8pm, press 20. Press the Amount Tend Total
<Enter> key.
5 Use the rounded Number keys to enter the 2 digits of the minutes. For
example, 54. Press the Amount Tend Total <Enter> key.
Using the information in this example, the date and time are set to
02-24-06 8:54pm.
http://www.royalsupplies.com/cashreg/Instruction%20Manual%20A710ML%20Eng%20ver11%20GOLD3.pdf
Sep 17, 2014 | Royal alpha 710ml thermal cash register,...
How to stop the caculator from rounding off decimals. |t doesn't give any accurate answers. e.. 0.789 will become 1
Two choices: Press the MODE key a number of times until you get to the "Fix Sci Norm" screen, press 3 to select "Norm" and then press 1 or 2 to select one of the norm modes.
Press the MODE key a number of times until you get to the "Fix Sci Norm" screen, press 1 to select "Fix" and then press a digit specifying the number of digits you want after the decimal point.
If you need a manual you may download a copy here. The display modes are discussed on page E-15.
Dec 23, 2012 | Casio FX82MS Scientific Calculator
How can i stop my calculator from rounding up
The calculator is a finite device so it has to round off most numbers somewhere. However you have some control over where this rounding occurs.
Press the MODE key. Cursor down to the second row and select the number of digits you want after the decimal point (or select "Float" to let the calculator decide, then press ENTER. Press 2nd QUIT to exit the mode screen.
Mar 29, 2012 | Texas Instruments TI-84 Plus Calculator
How do you get it to not round up
I have a problem with my Sharp EL-531WH Scientific Calculator. It rounds off the answer. In my Chemistry class, we need exact answers. For example, an answer of 0.234 must be the answer if that's the...
Press the [SET UP] key, followed by the 0 key to bring up the display menu. You can select "FIX" followed by the number of digits to the right of the decimal point, or press cursor-down and select one of the NORM modes. Press [ON/C] to exit the menu.
Be aware that some numbers cannot be displayed exactly. For example, 1/3 is a 0.3 followed by an infinite number of 3s.
Jun 25, 2011 | Office Equipment & Supplies
Can't find a manual online. What does 5/4 mean, and how do I turn it off? Same for E. My biggest problem is that when I add up numbers with the print function on (for depositing large batches of...
The manual for the Canon P1-DHV is online at http://www.usa.canon.com/app/pdf/calculator/P1-DHV_G_USA_HWB.pdf>.
When the display shows "5/4", the calculator is doing 5/4 rounding which means: 5 or above round up, 4 or below round down. To control rounding press the "5/4" key.
When the display shows "E" the calculator could not complete a calculation. It can be because of dividing by 0, or because the total exceeded 1 trillion, or because the operator entered calculations faster than the calculator could complete them. Press the CI/C key to clear it.
I can't explain why you are not getting a total on the tape. Try the following example from the manual exactly as shown, and let me know if your tape shows the total.
  1. Clear the calculator (press [CI/C])
  2. Choose 5/4 rounding (press [5/4] until "5/4" displays)
  3. Choose add mode (press [DEC] until "A" displays)
  4. Choose cost-sell-margin mode (press [B-T] until "B" displays)
  5. Turn printer on (press [PRINT] until "PRINT" displays)
  6. To calculate: $12.55 + $15.75 - $5.30
  7. Key in: 1255 [+] 1575 [-] 530 [=]
  8. Tape shows: [0. C] ... [12.55 +] ... [15.75 -] ... [5.30 =] ... [23.00 *]
Apr 07, 2011 | Office Equipment & Supplies
How to get a Casio out of rounding mode
Press the MODE key a certain number of times, until you reach a screen that displays FIX SCI NORM and numbers 1, 2, and 3 under them. Press 1 key to select the FIX display format, then enter a number between 0 and 9 to set the number of decimal digits you want to keep in your result. In your case the calculator is already rounding so you should select a reasonable number of digits say 2 to 3.
MODE (a certain number of times ....) 1 (FIX) 3 will keep three decimal digits in the results.
Sep 14, 2010 | Casio FX-300MS Calculator
My TI-83 Plus Calculator automatically round off my answers. How do I turn it off.
Press [MODE]. Use arrow down to go to second line Float. Use left arrow key to move cursor to a number other than zero and press [ENTER]. If you highlight 2 your results will have 2 decimal digits, but if 0 is highlighted all results will be integers (no decimals).
Hope it helps.
Nov 18, 2009 | Texas Instruments TI-83 Plus Calculator
ROYAL ALPHA 587 CASH REGISTER
Try this, for example june 30 2004 =
Put the mode key in PRG position In round number keys press 063002 then press #/ST/NS key
If that works to set the time in round number keys press 1100 then press Qty/Date or 1305 for one 05 pm. I have a 587 cx and can't fiqure out how to print my reports X Z
Aug 21, 2008 | Office Equipment & Supplies
Rounding off numbers
To stop numbers from rounding off; Press the DEC key.
Mar 07, 2008 | Texas Instruments TI-5019 Calculator
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
