Question about Electrolux Microwave Ovens
I have a 5 year old Zanussi Electrolux cooker. Door refitting problem.
I have had to remove the doors to clean them-the bar that holds the double doors in is pop riveted. I can't get the serial number, as it's been worn off. The main oven door is on hinges with torx screws. That's not the problem-the upper oven has door hinges that I can't re-install-they keep snapping back! No YouTube videos help. Edit-do0ne it. Lever the hinges back, then move the locking clip back into the door. Push the door into the cooker in a shut position, so the hingtes locate. Open. Push forward locking clips.
MicrowaveSvc
  • 9098 Answers
SOURCE: Removing the microwave door
In many cases, microwave door panels are held together by hidden hooks or catches that ave to be separated by a thin, strong tool such as a putty knife. I've attached a photo that should serve as a good example.
Posted on Apr 17, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken Door Catch Now oven won't work
You can order parts online by entering your full model number (without dashes) here: http://www.pasc.panasonic.com/epartr Chances are the panels separate as shown in the photo I have attached below. Panel replacement can usually be done without removing the door from the microwave. In cases where it is felt that door removal is necessary, I recommend detaching the door from the hinges. I generally do not advise removing the hinges from the microwave. Whenever the hinges are removed, great care must be taken to put them back in the very same position they were in. Failure to do so can cause microwave leakage, which can cause risk of skin burns, fire, and disruption nearby electronic devices. If you still have questions, please feel free to follow up. I appreciate your thoughtful ratings to my reply.
Posted on Oct 05, 2007
gwshaw71
  • 83 Answers
SOURCE: bottom screw on handle loose
open the door and you will have to peel and pry apart door.It is abot a 1-2" frame around inside door.that peels off it just snaps in.
Posted on Nov 25, 2007
jfpogie
  • 104 Answers
SOURCE: I can't remove the door handle.
thanks
Posted on Feb 14, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: How to remove the vent above the door for cleaning
Sometimes they may be dirty and will respond to cleaning, but in some cases, the actual plastic may yellow and the only remedy is to replace it.
The manual just says to take the two screws out, but doesn't refer to their being anything unusual. I would assume they're small Philips.
But if you're unsure of what kind of tool to use, can you post a photo of the screw head and maybe we can tell.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
318279620a electrolux I need to replace my
When you say stays on , is the magnetron still running ? The door switches need replacement or cleaning or timing went out.
Oct 14, 2013 | Microwave Ovens
I have a frigidaire Electrolux gallery series glmv168cqi microwave. The timer counts down, but the oven doesn't turn on. Sometimes when you open the door the fan turns on.
That would be a failing bottom door switch, or its mount.
My help file on door switches is here:
http://031d26d.namesecurehost.com/mwd/doorsw.txt
There's a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once the control panel has been removed, you can access the door switches for testing and possible replacement.
There should be a technical manual hidden behind the controller or grille, too.
If you need further part ordering help, contact Electrolux:
USA
800•944•9044
Electrolux Home Products
North America
P.O. Box 212378
Augusta, GA 30917
Canada
866•213•9397 (English)
866•294•9911 (French)
North America
6150 McLaughlin Road
Mississauga, Ontario, Canada
L5R 4C2
Apr 22, 2013 | Microwave Ovens
Microwave door wont stay closed
replace the door hooks and door release button.
if this is broken the switch will not close very well, and NOT start the microwave.
God bless you
Jul 19, 2012 | Samsung SMH9187 Microwave Oven
My JE1590 BH 02 is only 5 years old and we are having door issues. The door will not open, unless while pushing the door button you also hit the door. It seems the latch is not functioning correctly. ...
Door catches.
One of the latches may be bent/misaligned and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Feb 22, 2011 | GE JE1590 Convection / Microwave Oven
Spider in microwave oven door
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order any needed parts by entering your full model number here.
May 24, 2010 | Electrolux EI30MH55GS Microwave Oven
Panasonic microwave model NN-2959: can't open door.
Hi! if the parts is to much expensive i think it is not worth it. considering the years it has serve you.
Sep 11, 2009 | Microwave Ovens
Microwave on w/light but fan and heat not working
The problem is the door switch is defective. I'm on my third new switch in 3 years. The part number is 5304440026.
Mar 29, 2009 | Electrolux Microwave Ovens
I have a Sanyo microwave oven Model EM-C8787B UK2. I purchased it on May 23rd 2008. At first I used only the microwave element and whilst I found the door didn't open easily I managed it. However I...
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Aug 04, 2008 | Sanyo Microwave Ovens
Microwave Ovens Logo
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
