Question about The Audio Players & Recorders
What mite be my problem.I had someone hooking up a amp to my 2006 skyline .he use the door speaker and somthing gone wrong an blow my raido fuse.now fast as i stick a new one in it blo wing
  • 113 Answers
SOURCE: MTX Thunder 8302 Car Audio Amplifier
could be bad mosfets or outputs, needs replace
Posted on Aug 08, 2007
MikeMaierTV
  • 206 Answers
SOURCE: Z-5300 blown fuse
When fuses blow theres a problem, now how it blows help you find out where the problem is, If the fuse flashes and turns black the second you turn it on or plug it in there is a massive short in the power supply, If it blows but is clear the surge was not a dead short but a overload, Either way best to run it down to the shop and get it looked at
Posted on Feb 14, 2008
CompuGuy44
  • 432 Answers
SOURCE: always blows fuses
I would get a volt/ohm/continuity meter to test the connections. You have a short somewhere. You can take it Car Auto or Tweeter and they can check it for you. Some of these places charge a $35.00 diagnostic fee. If you have a schematic diagram, you can test where the short might be.
Posted on Apr 09, 2008
bmw_tech_38
  • 113 Answers
SOURCE: X5 wing mirrors wont stay retracted
the micro swithes inside the mirror unit(s) have probably broken inside
Posted on Jun 14, 2009
SOURCE: LG LFC23760ST Side by Side Bottom - Slow Blow or fast blow fuse?
slow
Posted on Aug 13, 2010
What mite be my problem.I had someone hooking up a amp from to my 2006 skyline .he use the door speaker and somthing gone wrong an blow my raido fuse.now fast as i stick a new one in it blowing
Might have a pinched wire creating a shot circuit which in turn blows the fuse?
Or maybe there is a dodgy/unprotected wire connection/solder creating a short?
Apr 15, 2017 | AMP Car Audio & Video
05 monte carlo no sound from speakers but raido shows its on and fine
If you have an extra speaker lying around you could wire it in by unplugging one speaker and seeing if it works. You have a fuse on passenger side fuse box for the amplifier. Check to see if its blown. A thumbs up would be greatly appreciated if this answer is helpful to you.
Dec 19, 2014 | 2005 Chevrolet Monte Carlo
External Speaker hookup problem. I hooked up 2 external speakers (8 ohm, 160 watt) into my Marshall AVT 50 amp (tag on back says 4 ohm minimum). Everything worked fine, then I shut it down and now (next...
If you are competent with electronics, open it up and check the fuse(s). Especially if no lights come on. If you get voltage, then check the jacks you plugged into- they may have dirty interrupt contacts. When you plug the jack in- it opens those contacts that otherwise are closed making the circuit to the cabinet's built in speaker. Contact cleaner should clean them up if that is the issue.
While it is possible there is a power supply issue, you can see that quick with a voltmeter, it is not likely you did much more than blow a fuse.- very possible if you unplugged speakers with the amp operating..
If you think you killed it- you usually still get distorted noise.
Mar 29, 2012 | Marshall Amplification Music
I hook up my amp with no speakers on it but keeps blowing the fuses on main fuse block coming off batt. what could it be and how much to fix
Fuses blow like that when there's an overload. This is often caused by a semiconductor device that is acting like it is a piece of wire. The most common fault in amps is the devices on the heatsink, that power the speakers. The cost will depend on how much the devices are and how many have gone.
Jun 12, 2011 | Rockford Fosgate Punch 1000W Class BD Mono...
Morning i have a 2001 mpv and i hooked the jumper cables backwards. Now the radio,door locks,and the interior lights don't work at all. I checked all of the fuses inside and outside the van.Is there a...
recheck the high amp fuses ie 100 amp as sometimes they blow but look ok best test with a multimeter with fuse out and twist contacts as you test them....
Sep 16, 2010 | 2001 Mazda MPV
Jvc KD-G210
Did you know there is a fuse on the back of the radio and one on the amp? Have you checked them? If the radio is working and no ssound it could be the radio, speakers or wiring. In your case it sounds like either the radio or speakers.
Sep 22, 2009 | Car Audio & Video
Problem with subs and amp
I would first suggest un-hooking the subs, and hooking them up to another known good radio other than the one its hooked to now. Just to make sure you didnt blow the speakers. What is the wattage of the subs? Then if the speakers do work I would hook them up bypassing the amp just to see if the problem exist before or after. Come back after doing this. Thanks
Jul 05, 2009 | Car Audio & Video
Avr 3802 can i hook up 2 sets of front speakers
well depending on the wattage of the speakers your trying to hook up to the amp if they exeed the maximum wattage then theres a chance u *could* blow a fuse nothing more then that, a fuse protects more expsinsive devices in ur amp, an if ur system keeps blowing fuses after doing that add up the watts 2 all ur speakers,
and remove the less needed
Hope you find this usfull
Feb 10, 2009 | Denon AVR-3801 Receiver
Message
Try disconnecting the speaker that you added. If the sound comes back, then you're ok. Just don't add any more speakers. If not, then it's possible the amp is blown.
Too many speakers connected together to one output can cause an overload and either blow a fuse or trigger the protection circuitry. If the protection is triggered or blows a fuse with all speakers disconnected, then your amp is shot.
Hopefully, that's not the case. Try disconnecting all the speakers and see what happens. If you still get the error, then the amp is gone.
Hope this helps, and please rate my advice.
Thank you, and good luck!!
Jan 20, 2008 | Audio Players & Recorders
Top The Audio Players & Recorders Experts
ctlimey
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
