Question about AMP Car Audio & Video
What mite be my problem.I had someone hooking up a amp from to my 2006 skyline .he use the door speaker and somthing gone wrong an blow my raido fast as i stick a new one in it blowing
  • 71 Answers
Might have a pinched wire creating a shot circuit which in turn blows the fuse?
Or maybe there is a dodgy/unprotected wire connection/solder creating a short?
Posted on Apr 28, 2017
  • 432 Answers
SOURCE: always blows fuses
I would get a volt/ohm/continuity meter to test the connections. You have a short somewhere. You can take it Car Auto or Tweeter and they can check it for you. Some of these places charge a $35.00 diagnostic fee. If you have a schematic diagram, you can test where the short might be.
Posted on Apr 09, 2008
SOURCE: JBL Creature 2 Blowing Fuse
I think you made a mistake with your fuse.
With my JBL i can see 9,5A 41FU.
Posted on Sep 08, 2008
  • 578 Answers
SOURCE: is my amp getting burnt out, it keeps blowing fuses
sound like you have a a bad spkr connect the spk one by one to amp and play the system and you will know and make sure the spk can handle the load from the amp too''
Posted on Jun 26, 2009
  • 653 Answers
SOURCE: 2006 f150 keeps blowing turn signal fuse
It sounds like the fuse is doing what it is supposed to do, and burning out when there is a short circuit. Check the wiring from the fuse block back to the lights and pay special attention to the trailer connection.
Posted on Oct 09, 2009
  • 6927 Answers
SOURCE: I have a 2002 Mitsu Lancer , the Battery light
Make sure that is the correct amp fuse for that ,the alternator,also,check the large wire on the alternator,make sure it is not touching anything.
Posted on Apr 04, 2010
My factory car amp does not allow the front door speakers to play highs can I connect those two speakers directly to the head unit connection and have the rest of the door speakers run through the amp ?
That will not work. The reason is frequency response. There are high and low pass filters installed on speaker systems. The reason is that no one speaker can handle all sound ranges. The other thing is that high range speakers are not high wattage speakers because they don't have to be. If you hook the high range to the straight feed from the amp, you will blow them out really fast.
Jan 23, 2015 | Car Audio & Video
ok im assuming your putting this in a door so remove the door panel then with that gone you should see a speaker just take it out the factory speakers may have a clip just cut it off and figure out witch one is positive and witch one is negative and if you hook it up wrong it wont hurt the speaker
Apr 03, 2010 | Swiss Audio SAK400 Car Speaker
I got a protection light on in my amp and low pass filter cuts out rear speakers even when hooked up front inputs to rear speakers im using the high level inputs as i only have one rca set
Try unplugging all the speakers and then powering the amp up, plug in one at a time to determine when the amp cuts out to protection. Chances are you may have touching wires or a speaker that is about to blow or at worst a amp going/gone bad
Oct 26, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
2000ford winstar
This sounds as the saftey nutral switch mounted on the steering colume has come loose or gone faulty , check the mounting bolts or replace the switch . this kills power to the sorces .
Sep 03, 2009 | 2000 Ford Windstar
Problem with subs and amp
I would first suggest un-hooking the subs, and hooking them up to another known good radio other than the one its hooked to now. Just to make sure you didnt blow the speakers. What is the wattage of the subs? Then if the speakers do work I would hook them up bypassing the amp just to see if the problem exist before or after. Come back after doing this. Thanks
Jul 05, 2009 | Car Audio & Video
I HOOKED UP MY SUB AND NOW ITS MAKING A loud squelching noise i cant figure it out please help
try taking out your rca leads and turning the amp on. if it stil makes the noise try using a diffrent sub 2 see if the sub is gone. mite be broken leads.
Dec 27, 2008 | Car Audio & Video
Altec lansing iM3
Could be somthing wrong with the speaker.. Get a hair dryer and blow the air into the speaker its self. ods are you have gotten water or some liquid into the speaker its self and messed it up ... I would advise getting a new speaker for it or somthing =)
Aug 11, 2007 | Altec Lansing iM3 Computer Speakers
Cordless phone, no power
Amps now have protection circuits on them now to protect them from blowing the electronics. Speakers dont usualy have any protection and can blow quite easy. Usualy when they blow they short out or short to ground and then the amp overheats and kicks off. What you can do is un hook both speakers and turn the power on if it stays on then plug each speaker back in one at a time. If it shuts off again without the speakers then it has to be somthing internal already damaged. Bass and volume are the #2 killers of systems. If when its up loud and the woofer speaker is moving in and out pretty far its on the edge of blowing.
Apr 14, 2006 | Creek 5350SE Amplifier
Car Audio & Video Logo
59 people viewed this question
Top AMP Car Audio & Video Experts
Billy McCain
Billy McCain
Level 1 Expert
Len Jeffrey
Are you an AMP Car Audio and Video Expert? Answer questions, earn points and help others
