Question about Universal Power Group Schwinn S180 Battery Kit
Schwinn s180 starts but is going less than 1 mph. charging it has no effect. is this a problem with the battery or the motor?
Install battery
First make sure the scooter is off.
Unscrew and take off the deck
Unplug and remove the old battery pack
Put the new battery pack in and plug it in, using the same connection as the old batteries pack.
Screw the deck on and your done!
Oh, and make sure you give the battery a good charge(the full charging time). The first charge of a battery is the most important one.
May 16, 2010 | Mongoose Currie Schwinn Gt Izip Scooters
Schwinn 820 treadmill quit working in the middle of walk shows L-5 on screen. what is problem?
Loss signal: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
May 13, 2010 | Schwinn 820 P Treadmill Silver Service...
I'm trying to figure out what kind of battery a schwinn electric scooter takes it is a s-180
Your scooter uses dual 12-volt, 10-amp hour sealed recyclable lead acid battery.
You may want to open below link to see some examples of batteries suitable to your scooter.
http://www.batteriesplus.com/products/78-0/6069-Electric-Bike-Scooter-Battery/252604-Schwinn/S180-Electric-Scooter/1.aspx
Regards,
Jeep Brainy
Sep 11, 2009 | Transport Schwinn Rechargeable Portable ...
Schwinn S350 Scooter batteries
Schwinn batteries can be found on amazon, click here and take a look: Amazon com Schwinn S350 Scooter batteries. I hope this was helpful. Cheers
Aug 02, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
HOW DO I HOOK UP THE BATTERIES FOR SCHWINN S180 SCOOTER
eiko American Heritage Dictionary WP5402RXS
wp5402rxs.jpg Languages: English Manufacturer: Seiko List Price: $24.99 Where To Buy
Jun 19, 2009 | Transport Schwinn Rechargeable Portable ...
Schwinn s180 wont charge
hi, just plugg it in turn it on. there should be a red and green light on your charger.
Apr 08, 2009 | Transport Schwinn Rechargeable Portable ...
I charged the battery up on schwinn 180 still want go
Its likely that you just need a new battery. Batteries that are used seasonally have a shorter lifespand, especially if they are stored without being fully charged. You can find a replacement at http://www.batteryinternational.com/electric-scooter-batteries-schwinn-s180.html
Mar 08, 2009 | Transport Schwinn Rechargeable Portable ...
Schwinn S180 won't charge
NashvilleDan, this scooter has 2 12v 10 amp batteries in series, you should read over 24 volts at the charging hub if the batteries are good. I would think that if the scooter sat for over a year you have bad batteries, They can be purchased at battery plus.
Mar 19, 2008 | Transport Schwinn Rechargeable Portable ...
Universal Power Group Schwinn S180 Battery Kit Logo
Top Universal Power Group Electronics - Others Experts
Are you an Universal Power Group Electronics - Other Expert? Answer questions, earn points and help others
