Question about Troy Garden
Mower turns just a couple times then stops. Could it be the starter (725cc 23hp Kohler engine, troy build hourse)
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Troy Master
  • 949 Answers
Sounds like the valves are out of adjustment. not letting the compression stroke release on time.
Posted on Apr 16, 2017
Diagram of drive belt for husqvarna rz4623
Hi Willard, The link below is a web page with the diagram for your lawn mower.......CHEERS..
Diagram of drive belt for husqvarna rz4623 Google Search
Apr 17, 2016 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Was cutting and stop moving forward and back wards belt in good condition
Could have broken the shear pin in the drive pulley. If one of the pulleys turns when you put it in gear but the other pulley does not turn then the shear pin is broken or missing.
Apr 04, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
My RZ4623 will not move.
If the unit stopped moving at once. I suggest checking the belt. It is very unlikely both Hydro-Gear units would fail at the same time. check under the mower, and check on top of the transmissions, you should see the drive belt running between both transmissions and the engine.
Feb 15, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
What should I try next? My mower will not start.
When you turn the key, do you have 12V art the Starter?
If you do, then tap the starter with a small hammer. If it cranks, then your Starter is failing
Jun 25, 2014 | Snapper Husqvarna RZ4623 46" 23HP Kohler...
Mower running but when blades are engaged they stop and start back up
More than likely the issue lies somewhere in the safety switch for the reverse. On most of those mowers when you back up the blades will disengage and then reengage one no longer backing up, it probably just needs adjusted, sounds as if it is out of adjustment and over sensitive. Hope this helps
Oct 01, 2013 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
How do i get my change oil now to stop blinking after I change oil?
Unfotunatly there is no re set for the service minders, they will re set after a few hours by them selves.
May 19, 2013 | Husqvarna "RZ5424 54"" Kohler 725cc...
I have a Kohler 12.5 KW marine generator on my houseboat that has a problem I was hoping you could help me with. Specs: Kohler 12.5 KW 79 CID 23HP Mfg date 9-10-96 Gen Engine Serial # 06919 L-29-R
there are some magnets behind the flywheel to cause the battery charging system to recharge the batt. sometimes they come unbonded/loose from the flywheel and cause the engine to become hard to turn. I would start there first.
Apr 03, 2013 | Cars & Trucks
I OWN A 2006 TROY BUILT HORSE 23HP. THE PROBLEM IS THE ENGINE IS HARD TO CRANK. I REPLACED THE STARTER AND BATTERY. COME TO FIND OUT THE ONLY WAY I CAN GET IT TO CRANK IS TO TAKE THE SPARK PLUGS OUT. ITS...
You either have a problem with the wiring and its not allowing the voltage to flow freely to the start or there is some type of internal engine failure that is causing the valves to stay closed.
May 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
81 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
