Hunter sc sprinkler controller reads "OFF" in all positions. Has >24VAC input, new 3v 2032 battery. Will not reset. What can I do?
  • 3 Answers
SOURCE: Hunter PGP Sprinkler Problem
For a small price, it's worth it to replace it with another Hunter PGP. Don't settle for cheaper products as the PGP is the best in the industry, bar none.
Posted on Jan 12, 2010
  • 3 Answers
SOURCE: My Hunter PGM sprinkler heads are stuck in the
Hunter has released the PGJ sprinkler, a direct replacement of the PGM series. With a rubber cover and the smaller PGP type gear drive, the PGJ series rotor should solve your issue. I would look at www.hunterindustries.com and find a wholesaler near you for costs of replacing your PGM sprinklers.
SOURCE: The Homedics SC 380 scale said low battery. After
The same happened with me, but here is what I did and it worked. I took the new battery out and set the setting on the bottom of the scale to Stone, put the battery back in. Now when I put the battery back in I made sure the plus on the battery was the last part to go in, it faced the part inside the casing that needs to be pushed back when you take out the battery. Once it was in I put the setting back to LBs and it worked. Don't know how but I was just as frustrated and it worked.
Posted on Oct 03, 2010
  • 2678 Answers
SOURCE: before the boot strap two
Have a look here for further info.
Posted on Dec 24, 2010
ginko
  • 19396 Answers
SOURCE: Where does the 3V #2032 Lithium Battery go in my
It is included in the palmrest assembly. Here complete disassembly.
Posted on Jan 18, 2011
I was receiving a LO error so I replaced my battery with a brand new 3V 2032 battery . I put it in the correct way and not my scale won't read anything.
Hopefully you did put it in correctly. About the only other thing you can check is to make sure that the battery contacts are squeaky clean and that the new battery is indeed good.
Sep 04, 2017 | The Health & Beauty
How do I get my Hunter ICC irrigation control box to turn on?
Check batteries with tester. Check internal fuse (sometimes same compartment as batteries. May have have to spend the $20.00
Jan 18, 2015 | Hunter ICM-400 ICC 4 Station Sprinkler...
Www ehow com
Cmos battery is usually a 3 V button battery, there are variety of different brands so you need to open and check it.
eBay: ACER ASPIRE 7741G 334G50 MS2309 CMOS BATTERY - 476
http://www.ebay.com.au/itm/ACER-ASPIRE-7741G-334G50-MS2309-CMOS-BATTERY-476-/161408573087?pt=AU_Components&hash=item2594b35e9f&_uhb=1
2035, 2032 can be bought from any super market or hardware store. Need to open the PC, locate the battery, which is normally clipped to the mother board. Use a small screw driver and lift out. If battery is soldered to the mother board then need to access under the board and de-solder carefully without damaging the tracks.
2032: CR2032 CR 2032 5004LC 3V 3 Volt button cell lithium battery for CMOS
http://www.ebay.com.au/itm/CR2032-CR-2032-5004LC-3V-3-Volt-button-cell-lithium-battery-for-CMOS-/271586313364?pt=AU_Electronics_Batteries_Chargers&hash=item3f3bce4494&_uhb=1
solder types: SONY CR2032 3V SOLDER TAB Pin battery with soldering tag for CMOS Bios PLC new
http://www.ebay.com.au/itm/SONY-CR2032-3V-SOLDER-TAB-Pin-battery-with-soldering-tag-for-CMOS-Bios-PLC-new-/271570170168?pt=US_Single_Use_Batteries&hash=item3f3ad7f138&_uhb=1
Aug 30, 2014 | Acer Aspire Z5771-UR31P - All-in-one - 1 x...
My hunter SRC lawn sprinkler controller sprinkles t
First thing to check is the power supply. Are the batteries fresh? Most likely you need to reprogram. There is likely a previous program that is causing the errant watering. Here is a good video on how to program.
Oct 22, 2011 | Nelson Sprinkler: Traveling Tractor
Hunter XG sprinkler timer not working
https://www.hunterindustries.com/sites/default/files/OM_XC_EM.pdf
https://www.hunterindustries.com/sites/default/files/LIT-397-RevG-OM-X-CORE-EN-web.pdf
REPLACE the alkaline battery can be used to program the controller in the absence of AC power. Even without a 9-volt battery the EC will keep track of time for up to 1 month and retain the program indefinitely in the event of a power outage.
Oct 06, 2017 | Hunter Ceiling Fan Control Switch
The Homedics SC 380 scale does not work after the battery insert
ensure the battery contacts are clean, if they are corroded it wont work. You may have to buy a contact cleaning spray or brush to do it.
Jan 28, 2010 | Health & Beauty
My Hunter PGM sprinkler heads are stuck in the same position. Any way to fix this?
Jul 18, 2009 | Ace Hardware Hunter& Low Profile III...
Hunter sprinklers vs rainbow sprinklers
I work with both Hunter and Rainbird irrigation components. Both companies have good products. But, I prefer Hunter for the sprinkler heads and Rainbird for the controllers and valves.
Oct 30, 2008 | Ace Hardware Hunter& Low Profile III...
Jul 09, 2008 | Ace Hardware Hunter& Low Profile III...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
