How to get lettering straight - Office Equipment & Supplies
How do I make a "space" in between the lettering. How do I enlarge to do stippling.
with the lettering mode, there should be a code number you program in for each letter, number and for a space as well.
Stippling is usually done by free motion stitching with a special foot so its not actually a stitch pattern, just a straight stitch that you form into the stippled pattern by moving the item as it is stitched.
Jul 20, 2011 | Elna 7200 Computerized Sewing Machine
We lost the instructions for word rummy
Simple Word Rummy:
Deal 7 cards per player. In a turn, a player: draws 1 card from the draw or discard pile; plays one meld from the hand or adds to a meld on the table; and discards one.
Melds can be 3+ of the same letter; a straight of 3+ letters in a row; or a word of 2+ letters of the same color (unless there are 2+ of the same letter in the word). Adding to a meld can extend the set or straight, or change its type (straight ABC + S to word CABS), or even flip them to the other color and letters.
The round ends when a player empties his hand after discarding. He get the total of the numbers on all cards in hand of all opponents. Each player with a meld of 5+ cards gets 50 points bonus. Game is 500 points.
Feb 02, 2011 | Toys
When typing with my brother gx-6750 it types weird lingo is the type set messed up or can I reset them?
Your daisy wheel letters are bended not straight.
Switchoff just remove your daisy wheel & remove the daisy wheel from its cover & see all the letters should be straight.If any of them is bended jst make them straight by your fingers dont press too hard & then fix the daisy wheel back & switch on typewriter.
Jul 20, 2010 | Brother ML-100 Typewriter
Printing wavy letters instead of straight
we have similar problem. my printer is canon mp 145. straight lines become wavy and some letters are italics when printed out. it was corrected when i used print head alignment but that was true when printing from my computer and not when using the copier. when using the copier lines still comes out wavy and i cannot correct it until now. please post when you solve your problem. i hope it will help you and i hope you can help me
Jan 21, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Zanussi Washer Drier
We had same problem with same model machine - basically you have to ignore the letters behind the see through plastic window and write new ones around the dial with a permanent marker that you know are correct and correspond to what you want. It's a lot of trial and error - try and go for the simple dryer function first and mark write the corresponding letter against the dial straight away, then work out the distance between each letter on the proper dial and and you should replicate these distances and letters with your pen.
Jun 30, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
jasbo
jasbo
