Question about Health & Beauty
Charged unit overnight in am unpluged charger move foot then quit all light went out not sitting in middle of room , is it a battery or fuse problem, if it's a fuse what size and where is it located.
Where can I get a merits vision super manual
  • 42 Answers
SOURCE: My boys have not rode
The battery went bad inside the bike. I would take it out and go to batterys plus and they will help you pick out a new one
Posted on Jan 08, 2009
  • 60 Answers
SOURCE: peg perego 12v charger question
The green light means it is ready to use. If the battery is bad though, the light will still be green.
Posted on Mar 11, 2009
  • 634 Answers
SOURCE: need to diagnose and repair hoveround battery charger
check current output of charger to see if it makes info on back mostlikely charger went bad
Posted on Jul 06, 2009
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Posted on Jul 19, 2009
  • 3 Answers
SOURCE: vz800 starter turns slow
Worn carbon brushes and dirty commutator on starter motor.
Posted on Mar 26, 2010
I'm using a Makita DC18RA rapid battery charger with my BL1815 Li-Ion battery. I cant' seem to get the batteries to charge. How can I isolate the issue and fix the problem?
You batteries may be dead. Any battery can only take so much charging before they quit on you. If your charger shows that it is charging and it still has not charged overnight, it is the battery. You can search on YouTube how to "recharge" Makita batteries when this happens. The Makita battery charge has built in diagnostics that will tell you if a battery is bad or not, but will not tell you if the battery no longer has the ability to charge.
Nov 29, 2017 | The Health & Beauty
Is there fuses in the M91 Pronto Onboard charger
I had this exact same problem after having my M91 in the shop. The repair man said that the onboard charger was bad, so he sold me an offboard charger to charge through the arm. That didn't change anything. I finally took it apart myself and discovered that there was a cord leading from the onboard charger to the batteries that the repair person had left unplugged when he installed my new batteries.
What I'd thought was "fast draining" of the batteries was actually the batteries self-charging overnight (which they will do a little bit if you let them sit). Of course, this might not be your problem, but I'd say at least look at it as a possibility.
Aug 23, 2012 | Invacare Supply Group Invacare Pronto M91...
Went to start it, lights came on hit starter then all went off and nothing now
How good is battery, is it fully charged, else battery charger to charge it overnight first before trying again to start the bike. Cheers
Dec 19, 2010 | Yamaha Royal Star Venture Motorcycles
Nuvi 660 ~5yrs old. With auto charger connected the unit powers off quickly with low battery indication. However if charged overnight on a USB cable the unit operates fine and indicates the battery is...
You probable have a blown fuse in the cigarette lighter adapter.... Unscrew the silver tip of plug and check fuse..... be careful its spring loaded..
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
We ran our Platinum Series 18 volt hand vac until it stopped -- charged the battery overnight but it did not charge. is there a problem with the battery charger or what could cause this?
Most problems with what you have stated have to do with bad contacts between the hand held unit and the battery charger. With the charger unplugged, make sure the contacts on both the charger and hand held unit are clean and not bent. Check to see what the "Light Indicator" should be when charging and reinsert the unit into the charger. If the light does not show what it is supposed to show, move the hand held unit around a bit to see if you can make the connection better.
If this does not do the job, depending on the age of the unit, might be time to replace the battery.
Oct 06, 2010 | Black & Decker CHV1500 Bagless Handheld...
Have a p103 battery that was in the p113 charger overnight and don't think it ever got out of the testing phase. The only difference was that the red light would flash about 5 or 6 times then stay on...
If you are sure your charger is working properly then your one battery may be shot.. i even had a new battery quit charging and had to replace it. they do not come cheap.
Apr 10, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
New charger
it may not be the charger on most occations have the battery checked out at your nearest cellphone tech. to find out if you need a replacment battery
Jun 15, 2009 | Duracell AAA NiMH Battery Charger with 4...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
