Erroe 12533 oc? plotwave300 - Computers & Internet
What is the error 8510 for OCE PlotWave300-WPD2?
I believe it means a failure of one of the heater temperature sensors (NTC), most likely the second from the left when facing the machine.
Jun 28, 2017 | The Office Equipment & Supplies
Suzuki forenza 2005 what is b1446 mean
short answer, Occupant controls failure. Passenger seat.
medium answer , air bags ,seat sensors and or seat belt systems failure.
Long answer.
no engine of the 5, are stated. nor country,
This is covered 100% in the book called FSM.
the factory service manual, on all cars. they have one
read it.? or at alldata.com and here
just $4 to read it.
https://suzukipitstopplus.com/
my best guess, is air bags (and ARE a danger to all mechanics that fail to read the FSM warnings, !!!)
the module is not communicating , due to power loss is the clue.
in case you dont know, error codes never tell you what part is bad
it at the least tells you what signal is dead, bad or a sensor not responding
what a tech,does, is do more test to ISOLATE the true cause.
others guess, and go broke fast $$$$$$
the Forenza is this Suzuki with Daewoo body and GM enigne,
are real pistol to work on,,,
rule 2, is the code is unique to suzuki, no other cars.
B1446 (i roll dice and guess)
2.0L engine, automatic.
out of FSM it states
but what does , OC mean,
its short, (not nice huh)
for
e Occupant Classification System (OCS)
Trouble Code: B1446 (2.0L L4 VIN - Auto)
OC Passenger Short to Power (Battery) or No Response
Trouble Code Conditions:
The OC sensor wiring is shorted to the battery wiring
Possible Causes:
  • Circuit
  • Sensor
OC rules before PLAYING around. a short excerpt.
If the vehicle is equipped with the Occupant Classification System (OCS), do not connect the battery negative cable before performing the OCS Verification Test using the scan tool and the appropriate diagnostic information. Personal injury or death may result if the system test is not performed properly.
Never replace both the Occupant Restraint Controller (ORC) and the Occupant Classification Module (OCM) at the same time. If both require replacement, replace one, then perform the Airbag System test before replacing the other.
Both the ORC and the OCM store Occupant Classification System (OCS) calibration data, which they transfer to one another when one of them is replaced. If both are replaced at the same time, an irreversible fault will be set in both modules and the OCS may malfunction and cause personal injury or death.
If equipped with OCS, the Seat Weight Sensor is a sensitive, calibrated unit and must be handled carefully. Do not drop or handle roughly. If dropped or damaged, replace with another sensor. Failure to do so may result in occupant injury or death.
If equipped with OCS, the front passenger seat must be handled carefully as well. When removing the seat, be careful when setting on floor not to drop. If dropped, the sensor may be inoperative, could result in occupant injury, or possibly death.
If equipped with OCS, when the passenger front seat is on the floor, no one should sit in the front passenger seat. This uneven force may damage the sensing ability of the seat weight sensors. If sat on and damaged, the sensor may be inoperative, could result in occupant injury, or possibly death.
Oct 20, 2014 | 2005 Suzuki Forenza
Error 15 in DFX 9000 printer
Error Code 15: OC Driver Error
This error occurs when the Mechanism Control ASIC detects that a
single phase of the OC Motor was energized for longer than the allowed period of time. This indicates a malfunction of either the HCPP motor, or ROM Board driver circuitry (TA10: STA485A), or both.
1. Check OC motor connector CNO/C on the Sensor Board.
2. Check both the OC motor and the OC motor driver circuitry on the
ROM Board. To replace the ROM BOARD If necessary, replace the OC MOTOR
Jul 27, 2014 | Epson DFX-9000 Matrix Printer
Oce plotwave 8510
for OCE PlotWave300-WPD2-error8510
May 26, 2014 | Office Equipment & Supplies
Gigabyte geforce gtx 650 oc 1gig
GEFORCE GTX OC.
THE OC STANDS FOR OVERCLOCKED.
Jun 23, 2013 | Computers & Internet
OC failure after changing power supply
oc failure computer.
oc failure boot.
oc failure error.
oc failure bios.
oc pc failure.
oc power failure.
your description don't have so many details.
GOOGLE IT.
Jun 11, 2013 | Gigabyte Computers & Internet
I HAVE A PIONEER MODEL XV-DV151 AND HAS OC ERROR
while stad by bottan pressing oc error coming on display
Jan 19, 2013 | Pioneer Televison & Video
Need k'nex mechwarrior 12533 instructions
I recently made a good majority of the KNEX 'Mech line into pdf's here's the link:
http://www.4shared.com/u/KpLjxBMX/clanknexer.html?sId=U59BYGtUoz4W0nmC
Sep 18, 2009 | Toys
Something worng with it. it shows OC on the temperture number ?
Typically the "OC" indicates your compass is out of calibration.
If you check your owners manual it will tell you how to re-calibrate the compass.
Let me know.
Regards,
Apr 25, 2009 | Chevrolet Blazer Cars & Trucks
Computers & Internet Logo
David Payne
David Payne
