Question about Elna Sewing Machines
Bobbin not turning when winding on, please help. It is an Elna 3800FA model. thanks.
  • Elna Master
  • 12,031 Answers
There are stand-alone bobbin winders, one brand called the Sidewinder, available at JoAnn's Fabrics or online for ~$30. Just be sure to verify that your machine bobbins are compatible as some Singer bobbins are not. This bobbin winder is a nice accessory to have as it saves wear-n-tear on your machine and you can also wind multiple bobbins without unthreading your machine.
Posted on Apr 17, 2017
  • Elna Master
  • 662 Answers
Here is a good place to watch to see if you have been doing this right to begin with.
https://www.youtube.com/watch?v=usl9t7ijJ6o
If you don't accomplish winding here is a possible fix. On the top of the machine there are screws to hold it on. Once you remove the top look where the winder comes out. Look and see the tire (rubber round piece). If it is worn replace it. To replace just remove and replace like a rubber band. There is a spring that holds the arm to the right. The spring must be connected and strong enough to cause tension of the tire to the hand wheel. Always make sure the bobbin is the right size also.
Posted on Apr 16, 2017
SOURCE: Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Posted on Aug 23, 2008
SOURCE: Elna 6003Q Sewing Machine won't snap out of bobbin winding mode
I had the same problem and fixed it myself. Remove the portion of the housing that coincides with the bobbin winder. You will need to remove two screws to do this--one is just to the upper left of the bobbin winder itself, and one is hidden under the handle on the left side of the machine (lift the handle, and look on the machine on the left side.) It takes some coaxing to remove the housing, but it can be done--be gentle. If you need to, remove the housing on the left side of the machine that covers the needle assembly. This will make it a bit easier, but still, be gentle.)
After removing the housing, you will see a black metal piece with a elongated slot and a screw adjacent to the bobbin winder mechanism. Unscrew the screw a turn or two, and slide the piece to the other side. Tighten gently. Turn your machine on, and move your bobbin winder back and forth and watch the screen change from bobbin winding to the main straight stitch screen. Now, do a brief Dance of Joy. I hope this helps.
Posted on Jan 23, 2009
SOURCE: Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Posted on Mar 14, 2009
Zenqi
  • 208 Answers
SOURCE: winding bobbin- elna
The bobbinwinder spindle is on the top of the machine on the right.
Try to turn the spindle with your fingers. If it is turning easily, good. If not, see below.
Push the spindle to the right and it should turn when the handwheel turns.
If the spindle does not turn properly, remove the two screws that hold the top cover on. DO NOT REMOVE THE SCREW THAT IS ON THE SMALL BLOCK NEXT TO THE BOBBINWINDER SPINDLE.
The top cover will not remove because of the handle. While lifting up the cover, peer under to make sure that there is a small rubber tire on the under side of the bobbinwinder spindle.
If the tire is there, place a small drop of oil on the spindle and turn it until it frees up. Try not to get oil on the tire, it will make it slip. Wipe it off if it gets oily.
Replace the top and retry.
Posted on Jul 26, 2009
SOURCE: finding a manual for elna lotus 1000
I have the same problem! Did you find a solution?
Posted on Jan 27, 2011
My elna 7000 sewing machine does not want to wind the cotton
Not sure of the particular bobbin winding problem you are experiencing. However, frequently the bobbin winder "tire" becomes worn and needs to be replaced.
Elna 7000 Parts
What is the correct way to wind and insert bobbin in elna machine
Jul 20, 2016 | Elna Sewing Machines
Why does display read "WINDING BOBBIN" and won't clear?
This video may help:
Winding an Elna bobbin
Perhaps the bobbin winding mechanism has not been released. (She unsnaps the bobbin when finished winding.)
Aug 31, 2015 | Elna Quilter's Dream 6003Q
How to wind a bobbin on a 2004 elna sewing machine?
1 - Look in your book.
2 - Ask a sewer to show you.
3 - Google
Jul 16, 2014 | Elna Sewing Machines
Winding bobbin on old elna lotus
I can help you with this, the Elna Lotus has a pretty simple bobbin winding system, the bobbin winder is top right of the machine, drop bobbin with holes to the top onto the spindle. Now Lotus have a dial on the right side which switches between bobbin winding, stitching and locked for transport, turn it to Bobbin symbol. Take the thread from the spool pin at the back across to the metal eyelet at top front (it sits inside the accessory tray when transporting so you may need to pop open the tray lid and flip this eyelet out)
24421001-h4211ohbpts0t3j0sbmab0vm-2-0.jpg Now take thread across and through a hole on top of the bobbin and holding the tail, put your foot onto the foot control to get a couple of winds onto the bobbin to hold the thread. Now place your finger or the handle of a pair of scissors onto the top of the thread spool to apply tension so that the thread winds evenly and slowly wind the bobbin until about 3/4 full, making sure it winds evenly. Tension onto the spool is the key here, Lotus doesn't have a tension device to control the thread tension as it winds so you need to do this, critical to getting a good stitch out of these lovely machines.
Hope this helps you out.
May 14, 2014 | Elna Sewing Machines
What is the correct way to wind and insert bobbin in elna machine?
You always wind the Elna 7 hole bobbin with the holes on top, and load it into the bobbin case the same way, this means when you draw the bottom thread off the bobbin, it will turn anticlockwise.
Apr 30, 2014 | Elna Sewing Machines
Where can I find the Mandal for an old portable Elna Sewing machine?
you could start at sewingpartsonline.com, they have a list of Elna models with manuals and spare parts. You will need to find the model number however, it should be on the right side panel, a little plate with Tavaro SA and a two digit code number. If its a Lotus code might be 15, 25, 35 or 36. Also, if you do have a Lotus, please go to my solutions and find mine regarding winding a bobbin. The Lotus has no tensioner on the bobbin winding so it is critical that you tension the thread by applying your hand or scissors to the top of the thread spool as the thread winds off it and use your finger to nudge the thread so it feeds onto the bobbin nice and evenly. If you bobbin has wound without tension then the thread will be loose and uneven and you will never get a good stitch from it. Also, check that you are clicking the bobbin thread into the tension spring on the bobbin case. I'll attach an image to assist.
Apr 18, 2014 | Elna Sewing Machines
I have an elna airelectronic tsp machine & cannot thread bobbin. Please help
Firstly, have you got an Elna metal bobbin? it should be solid on the bottom and have 7 holes on top. It is essential that you always use it this way, wind it with the holes on top and load it into the bobbin holder the same way.
Have a look at the image above, you need to load the bobbin in and click the thread into the tension spring so it doesn't lift back out when you pull the thread upwards. There should be an audible click as it goes in.
If you can't get it right or this image is just too small, feel free to email me and I'll send you the image and talk you through it, I have a TSP machine too. cwrogers@tpg.com.au.
Also, check my tip on bobbin winding here http://www.fixya.com/support/r10598580-winding_bobbin_correctly it is important to get a good even tension onto your bobbin as you wind the thread on, you may need to manually add some tension to the thread as it winds off the spool, as I've described in my tip. I sold these machines for Elna and customers would bring them in complaining of problems with their machine. Almost aways, it was the needle in backwards, bobbin upside down, thread/lint buildup in the bobbin race or badly wound bobbin that was the problem.
Hope this helps you Gaylene, but if not, please email, I may be able to send you the relevant manual pages.
Apr 20, 2012 | Elna Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
On my elna supermatic 722010 sewing machine, the thread makes the bobbin pop out and the thread get tangled underneath. I have had it fixed twice, which is expensive. Should I just get rid of it and buy...
not unless you can find another swiss elna, like star series su. check bobbin in right way, holes on top to wind and load. you havent bought anothet type bobbin??? go to www.arizonaexpressionz.com and download a manual for supermatic. then read bobbin winding and threading carefully and rewinf bobbin and thread up again. make sure thread goes into tension spring all the way. bobbin should turn anticlockwise when yoou pull thread. also please brush clean bobbin holder area and check for any threads caught there. now a drop of quality clear machine oil in middle hole and gently run for 30secs to work in. do this every time you get your machine out. there are several oiling points shown in manual. oil them. these machines are quality but yours may need love tlc from a elna tech especially if it has not been serviced in a while. but a well maintained elna will out stitch a new plastic machine any day in my humble opinion. if you want to join yahoo group elna heirlooms, experts who service their own and share photos info manuals and love these vintage classics.
Jun 16, 2011 | Elna Sewing Machines
Sewing Machines Logo
35 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
