Question about Kubota Garden
Kubota tractor model M900 hydraulic pressure is way high. How do I adjust? Ever hose on loader has busted plus hose pressure line to loader
csmock132
  • 4669 Answers
SOURCE: power steering
Go to a parts store and tell them you want power steering return hose or transmission cooler hose. It comes in bulk, they can just cut off how much you need.
Posted on Mar 25, 2009
ButtFuzz
  • 463 Answers
SOURCE: IJohn Deere whinning noise
Is the device that lowers or raises the loader a hydraulic piston type device, or more of a hydrostatic type device? Whining noises are not uncommon with hydrostatic devices...
Posted on Mar 26, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Ford 770A loader hydraulics lift cylinder shaft won't move.
Hello there:
when you dissconnected the hoses did you turn the cylinder upside down and let it drain cause some hydraulic lift assybelies have a small chamber in the head of them that retain fluid and with out removing the fluid it will do a hydraulic lock and wont be able to move untill you losen the bleeder screw if it has one ok please let me know how this goes for you
Posted on Sep 10, 2009
  • 62 Answers
SOURCE: Headlamps quit on L4200 kubota tractor, Wireing
CHECK THE FUSES
Posted on Sep 25, 2009
housejess
  • 317 Answers
SOURCE: Ford TRactor 1710 hydraulic problem
raise front loader....loosen hyd. line a little lower loader till all air is released and only fluid is coming out and retighten.....its like bleedig brakes on a car
Posted on Nov 17, 2009
I just replace hydr. pump on a bx2200 Kubota tractor but it keeps blowing the filters apart . can you help me ?
connected the pipes to the pump incorrectly
filters go on the return lines or suction lines not the high pressure side of the pump
they are only good for a pressure of 30psi not 2000psi
Sep 02, 2017 | Kubota Garden
I have a kubota L355ss tractor the power steering went out can you tell me how to fix it
I am not familiar with the model. The steering is probably hydraulically assisted steering or power assisted steering rather than pure power steering. In the case of a pure power steering failure the tractor would be impossible to steer while a failure of power assistance means the vehicle steering is still connected to the wheels and it is possible to steer, if the driver's arms are strong enough.
Power steering is mostly reserved for larger industrial vehicles while almost everything these days is equipped with power assisted steering.
There are several ways a steering system can be given power assistance and there isn't space or time to discuss those here but regardless of the method, all except the very unlikely possibility of electrically assisted steering and the equally unlikelihood of compressed air assistance, will require a good supply of air-free hydraulic oil under high pressure, typically 500 - 1000 lb sq inch.
The first part of diagnosing the problem is to ensure there is an adequate supply of oil, that it is clean and there are no leaks and it is being delivered to the steering gear or ram with sufficient pressure and volume to provide the required power assistance. Once the visual checks have been carried out the safest method of checking further will be to use a hydraulic test rig.
It is most important during work on hydraulic systems that utmost cleanliness is observed to prevent dirt or water entering the system...
May 05, 2017 | Kubota Garden
1640A Kubota tractor front end loader or bush hog will not lift
I would say you have air in the hydraulic system or you are low on Hydraulic fluid, I am not sure of the procedure on this make to bleed the air out but a dealer may help you if you ask nice.
Sep 22, 2016 | Cars & Trucks
Rear link arms wont lift under load. what can I do to fix this?
you didn't mention make or model; rear links are hydraulic?
If so did your "mechanic" put a high pressure gauge on the ram hose(s) and see what pressure there was? Problem could be in controller for link.
Jun 06, 2015 | Garden
Where's dip stock for hydroloc fluid on a Kubota L3400 4x4 tractor
As a rule the Kubota L2800/L3400 do not have a dip stick for the hydraulic fluid. To check the fluid level, find the small round site glass that is on the transmission, left side, just in front of the clutch pedal. This sight glass has a level line on it. If the level is low the fluid might not show in the sight glass. If the level is below the line add fluid. The fill port for the Hydraulic fluid is on the back of the tractor just below the level of the seat.
Oct 31, 2014 | Garden
Kubota L2250 DT wiring diagram
You can download:Kubota Tractor L2250, L2550,L2850,L3250 2WD 4WD Operator Manual
This Manual Covers
1. Servicing of Tractor
2. Specifications
3. Operating New Front Mower
4. Instrument Panel and Controls
5. Lift Link and Hydraulic Control
6. Wheels, Tires and Tread
7. Operating
8. Maintenance
9.Check and Maintenance
10. Adjustments
11. Troubleshooting
12. Long-Term Storage
13. Lubricant Specifications
14.Wiring Diagram
Jul 03, 2012 | Motorcycles
Garden Logo
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
