My Singer Lightweight 132 won't work. It's stuck. I took off the front and side covers. The large belt will spin, but the rest of it won't. It wants to, but can't.
  • Washing Mach... Master
  • 5,323 Answers
A bad motor coupler?
Posted on Apr 17, 2017
BELT BURNT FRAYED THEN BROKE, SOUNDED LIKE BEARING NOISE
It may be a garment stuck in between the inner drum and the outer shell
Aug 31, 2012 | GE WBVH6240F Front Load Washer
Seat belt pasenger seat
Are you trying to say the seat belt retractor is stuck? This is in the front seat?
If it's anything like my Tahoe, you need to remove the plastic panel that covers the retractor (carefully - don't break the clips or you won't be able to put it back on). Take a large flat head screwdriver and slide it under the part where the seat belt coils up, and find a little tab - push it with the screwdriver. As long as the seat belt is not twisted up, it should retract.
Nov 30, 2011 | GMC Cars & Trucks
The back belt doesn't spin but the front belt does.
The four sprockets that the chain is resting on have gone bad. Pull the side cover off so you get access to the belt wrap and the chain itself. In the corners those sprockets need replacing. You will see they are very smooth. The drive chain may have came off so it will not spin the one side, but i doubt that.
Jun 28, 2011 | Roundup VCT-25 Toaster
Hi my mixer suddenly wont spin and im not so sure how to fix it.
if its like mine the belt or pulley wear out mine took 8 years for it wear out. i couldnt find the parts so i took of the base(make sure its unplugged) remove the belt(hold one side of belt over the large cog and turn the cog, the belt should fall off) get a large rubber band (the width of the pulley)and twist the band over the pulley a number of times until it fits tightly over the pulley, replace belt and base and it should work.
this will work if the belt or pulley teeth are worn
my wife still cant beleive it worked
Dec 19, 2010 | Kenwood Food Processors
Brush roll not spinning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=453845
Brushroll not spinning
Posted by vistaloopy on Mar 19, 2008
I have a Eureka Bagless Optima 431 Lightweight Upright that is not working. I took it apart to clean the brushroll and have tried to put it back together several times, but the brushroll will not spin anymore. Maybe I'm putting the belt in the wrong spot? Where can I find a diagram or something?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. You have only 2 choices, the belt is either side driven belt or the belt is a center driven belt and the brushroll has one side that is for the belt and the side driven brushroll and the motor pulley must be in line in order to work properly, you may want to check the bearing holders, some vacs will mark the ends with words like NEW or USED and both have to be identical in order to fit right. Once you have the brushroll out it should spin if you set it on it’s side and if that happens you are OK, then watch the ends of the brushroll. Align the end with the motor pulley, B4 install the belt place the belt on the pulley side and install the brushroll. Then once the brushroll is in and spins properly, and then you can use a belt puller and stretch the belt onto the motor pulley and then track it in a straight line. If you need further help please feel free to contact your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Mar 19, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Feb 14, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Kirby g4
first things first...take the powerhead off of the front of the kirby. If you look at where the powerhead connects to the front of the kirby and you'll see a large hook...turn the hook using the crank on the front of the powerhead so that the belt is pulled up and away from the brushes. (OFF position) The hook stretches the belt so that it can fit over the fan driveshaft (its the finger looking thing that sticks out of the front of the kirby when the powerhead is removed.)
Next, place the two "feet" of the powerhead onto the "perch" located on the front of the kirby (under the driveshaft opening)....lock it on by turning the silver lever on the top of the kirby (the one under the hood/light)
Now spin the knob on the front of the kirby from off to on. This releases the belt from that hook in the powerhead so it can rest on the driveshaft. Off means the belt is off of the drive shaft and the brushes won't spin. On means the belt is on the driveshaft and the brushes will be spinning. But remember, the belt has to be stretched open on that hook inside the power head BEFORE the powerhead is placed on the front of the kirby. Otherwise the belt won't be connected to the spinning driveshaft, and the brushes won't spin
Dec 08, 2007 | Vacuums
How to put the belt on ?
Dec 06, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
