Question about LG Washing Machines
LG front washer squeaks upon wash cycle and last till end of wash. Gets worse with each cycle. Sounds like rubber rubbing together.
  • LG Master
  • 2,355 Answers
Open door, and pull on drum/tub forward and back and see if it moves a lot. Next try to wiggle the drum/tub and see if it moves side to side, up and down. If either, then either drum bearings issue or bolt that holds drum to outer tub is loose. Let us know what you find by making a comment to this answer
Posted on Apr 17, 2017
  • 6 more comments
  • JC C. Apr 17, 2017
    YES, the drum/tub definitely moves when I tug at it. It moves side to side and up and down. Thank you. I thought I was going crazy.
  • robert Apr 17, 2017
    Well, it is most likely drum bearings and seal going bad, but it could be just the bolt that holds the inner tub to the outer tub. Take the back inspection cover off(4 screws-lift up, pull off) and try to tighten the big bolt on the middle of the motor-17mm I believe. If it is loose-kinda unlikely but maybe-you're good to go. If it is tight, then definitely it's the bearings and seal. Time consuming and hard job but doable. Check out how to videos at repairclinic.com or appliancepartspros.com. Enter your model number, find bearings in parts list and there should be a video link. Good luck.
    The machine is brand new, provided by management company of the apartment I live in. I live better have them handle since it is their property. But I wanted to be informed or at least have an idea of what the problem could be.
    Thank you so much
    Well if washer is brand new, I find it hard to believe it is the bearings. But if inner drum wiggles inside of outer drum significantly I have no other ideas
    Do you think that the sound could be because of poor installation? I assume it is brand new because the apartment was renovated and never had the washer/dryer before. The dryer works fine.
    Again, if the inner tub wiggles significantly inside the outer tub and the outer tub does not move much or at all, then it is a problem. If the inner tub and outer tub move as one and there is no wiggle between them, then that is not your issue. If the washer is brand new then it's under warranty. What is the model number?
    The model no. is WM3270C
    Model came out about 5 yrs ago. So could be new. Could be used.
amit kashyap
  • 186 Answers
SOURCE: my washer has recently started thumping and
Hi, . according to your washer problem i m writing solution ,please read and follow it:-
  1. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
  2. check out this following options one by one to locate the fault in your machine.
  3. 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.4)Clear thewater pumpfrom obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  4. you can get the required partys from
  5. www.repairclinic.com
  6. I hope this will help.
please don't forget to vote me. goodluck.......
Posted on Jan 21, 2011
  • 125 Answers
SOURCE: Frigidaire FTF530FS Front Load washer
Take off the lower panel. Inspect the shocks too see if they are damaged. If they are OK turn the wash basket by hand if the knock is heard then most likely you have a broken wash basket.
Posted on Jan 13, 2008
SOURCE: LG intellowasher (front-loading washing machine) is starting to squeak.
I suggest u buy another washing machine. This one's had it!
Posted on Apr 23, 2008
SOURCE: Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
Posted on Mar 18, 2009
  • 8 Answers
SOURCE: squeaking coming from the front end
you prolly need new bushings i have the same problem now on my 95
Posted on May 13, 2010
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Ge front loading washer drum fills with smoke at end of last rinse cycle and smells of burning rubber
THE INNER DRUM IS BAD WITCH LETS IT RUB THE FRONT SEAL OF THE WASHER YOU NEED TO SEE IF YOU CAN MOVE THE DRUM UP ARE DOWN ARE SIDE TO SIDE IF SO ONE OF THE SUPPORTS ON THE BACK BROKE AND THE GET THE SMELL OUT WASH THEM IN WHITE VINAGER
Oct 31, 2012 | Kenmore Front-Load Washing Machine 3.5...
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
Oct 07, 2017 | LG WM1812C Front Load Washer
Whenever it gets to almost the end of the cycle and usually while it is in rinse, the error message OE comes up and it won't drain the water from the tub or go any further
Had same problem last night with my LG WM1814CW but mine didnt get to the end of the cycle, it would fill and start humming when it was supposed to be draining then the OE would appear. We drained the machine through the front door hose, turned the machine on its side and removed the drain pump. Very easy access and very easy to remove the drain pump. There was a half a bobby pin against the impeller and that stopped the turning. Took the bobby pin out and put it all back together. It works like a charm now. Very nice system that LG has.
Nov 30, 2010 | LG WM-2277HW Front Load Washer
My LG TROMM model # WM1812CW has a burning rubber smell when it's on the last high speed cycle. Can you help me locate the problem?
I just ran into this same situation. The problem was that the basket has been rubbing against the tub/door gasket. In this specific case it finally wore through the tub and was a hole through it. It si looking to be approx a $600 repair.
Sep 03, 2010 | LG WM1812C Front Load Washer
GE Profile Harmony Washer has loud squeak when filling
Based on your description, it sounds like the water inlet valve is making noise, since you hear a squeaking noise during the filling of the washer. If it sounds like a constant squeak or squealing noise, i'd say it's caused by either the water inlet valve not being pulled all the way open, or because the water supply shut off valve at the house end isn't open all the way. Try opening the water supply shut off valves all the way open, (check to see that they are).
What is interesting is that the squeaking comes back during the draining of the water. Is this while the tub is spinning or only at the very end of the cycle? Again, it could be the water inlet valve, since the washer will "spray" some fresh water into the washer during the final spin cycle to help remove any soap residue, etc.
The part ins't cheap at around $123.00 for this valve, so unless it's really annoying you to no end, I'd wait for the valve to stop working before getting the repair done, unless you want to do the repair yourself, which isn't difficult, with some basic tools and time.
If you wait and let this go until it fails, you'll notice the water in the tub might not fill all the way for the level set, or the valve will start getting even more as it gets worse.
Here's a drawing that shows your washer and the part I'm talking about.
pd_0026_363_wh13x10017?$pddetailsth$ Part #WH13X10017 $123.49 @ searspartsdirect.com
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WPGT9360E0PL&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00001&componentDescription=CONTROLS,%20BACKSPLASH%20&%20TOP%20PANEL&documentId=G0901083&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Weird rubbing or mild grinding noise when in spin cycle.
It sounds like the bearings on your tub are going. This is an expensive and difficult job to do. (approx $450 parts and labour and you may do more damage trying to take it apart)
Feb 07, 2009 | Kenmore HE2 Plus Front Load Washer
Nov 08, 2008 | Washing Machines
Squeak on wash cycle
Try some anti-sqeek stuff on the belt, or just rub some soap on the belt.
Jun 29, 2006 | Admiral AW22 Top Load Washer
Washing Machines Logo
132 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
