Question about Dacor Microwave Ovens
When i open the microwave door the machine turns on and keep on until i close the door. Dacor Built In Model DMT2420 S
  • Dacor Master
  • 9,098 Answers
It may be a shorting relay on the the control board, or a problem with one of the door switches or its mount.
I regularly repair these microwave controllers and details are here.
It's best to follow up with me directly. (FixYa does not notify us directly when follow-ups are posted, so we have to log in to the site to see them.)
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Posted on May 25, 2017
Dacor DMT2420. Light and Display work fine, and you can type in time for cooking, but when you hit start, it does not make the buzz of it's normal sound, and the turntable doesn't spin.
On the DMT2420, that's a bad bottom door switch, or possibly that switch's mount.
The service manual is here and the parts list is here.
You can order Dacor parts by part number from the Pros here.
Jul 22, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
We have a new 24"Dacor
That mesh is the door screen which prevents microwave leakage.
It must be intact or replaced, or a fire hazard exists.
Feb 26, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
Door won't open
That's probably the door open lever or door open button, and there may be grease where the button passes through the control panel frame.
Feb 12, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
Closing the door on my microwave no longer activates the Start. It seems like the door won't close tight.
youll need to replace the latch on the door. you can buy the parts and do this yourself or you can hire a repairman.
Feb 11, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
My microwave no longer starts when the door is closed. You have to hold the door tight for it to work. Door is not shutting tightly enough.
The service manual is here and the parts list is here. You can order Dacor parts by part number from the Pros here.
Door won't open
Feb 07, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
I opened the door on our Dacor microwave after heating food and the interior light, which was on for about a second, blinked off. The light will no longer come on when the door is open and the microwave...
Oct 21, 2010 | Dacor DMT2420SS Microwave Oven
My Dacor DMT2420 fan, light and turtable motor run continuously when the door is open. I have unplugged the unit to reset it with no help, another on-line forum expert suggested checking the door switches...
If the cooling fan, light and turntable run continuously when the door is open, but not when it is closed, your secondary interlock (bottom door switch) is shorted (always on).
Even if it's shorted, the actuator button (usually red) will still move up and down when you open and close the door.
It will need a new door switch.
See the service manual here. See our file on door switches here.
Jan 04, 2010 | Dacor DMT2420SS Microwave Oven
Door won't open
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be
removed.
If yours is a DMT2420 or other counter top model that is built into a cubbly hole and surrounded by a metal grille (built-in kit), the kit will have to be removed, then the oven will slide out of the opening.
Once it's out, you can remove the outer cover and you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
The model tag will either be on the back or around the door frame or control panel frame, or maybe inside the cooking cavity.
We have several Dacor microwave service manuals at our site:
It's a pain, but for Dacor the parts list are separate:
Once you have the part number of the part you need, you can order by part number here.
(This site does not list Dacor by model number, only by part number)
Aug 03, 2009 | Dacor DMT2420SS Microwave Oven
Need help with DACOR Microwave model PCOR30S, w/the minute timer
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models (and Sharp models made for Dacor) stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
We have a very close service manual and have uploaded it to our site here to help you.
You will need the
free Adobe Reader to view or print it.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
If your model is PCOR30, and you need a new motor, the part number is 66756 and you can order it here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 19, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Microwave Ovens Logo
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
