Question about Everlast Exercise & Fitness
I need an User Manual Book on my Everlast Ultra Auto Tension Exercise Bike. Can you maybe help? It is a 12 Program Bike
SOURCE: missing power cord/adaptor
You just need to go to Radio shack, and get a DC9V Adapter at 500mA and the correct polarity of (-) on the outside and (+) in the center. Original was a AHEAD AC Adapter Model ADB-0900500
Good Luck
Posted on May 16, 2009
SOURCE: edge 491 exercise bike monitor panel dead
http://www.academy.com/images/pdf/Fitness_Quest/Edge_Recumbent_Bike_491r.pdf
Mine went dead last Spring. I ordered a replacement part from Fitness Quest. I think the link is above. Actually, while I was waiting for the part, I reconnected all the wires on the whole bike and the panel worked. So I actually have an extra new working panel if Fitness Quest doesn't have the part for some reason and u want mine. Double check ALL the connections of the wires first. They come loose easily.
Nancy
Posted on Aug 10, 2009
bargainbox
  • 1388 Answers
SOURCE: Kenmore Ultra Stitch 12 model 1595280. Tension
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Bargain Box
Posted on Sep 06, 2009
SOURCE: Need Manual for Vital Fitness Exercise Bike RB26S
I have a manual for this model. I can not tell you how to find one, I have looked all over the net for additional info. on this model and can't find anything. Would be glad to scan and send you a copy if you still need it.
Posted on Jan 09, 2010
SOURCE: Manual wanted for Kettler Corsa Exercise Bike
http://www.fahrrad-kaiser.de/downloads/1236948801_Kettler_Corsa_02_03.pdf
for free
Posted on Jun 11, 2010
Exercycle manuals
Google (everlast)(820)(manual) without parens OR contact Everlast.
Jun 30, 2018 | Everlast Exercise & Fitness
Feels like pedals slip once in a while. How do I repair this please?
replace the spring, maybe it has lost some of the loading and become "tired".
Jul 03, 2015 | Cybex Cyclone 530c Upright Exercise Bike...
Need to download owners manual for everlast 5000 exercise bike
I don't have the complete manual, but I do have a PDF of the page that explains how to input info into the computer, if that would help you. What I need is info about the power cord for this bike since I didn't get one when I was given the bike.
Jan 15, 2013 | Exercise & Fitness
Instruction book for everlast EV 410 exercise bike
my everlast bike is grating solution please
Nov 21, 2012 | Exercise & Fitness
Where can I find a power cord for an Everlast System 5000 electromagnetic exercise bike? The bike is older and no longer made. Is there a universal cord that can be used? I'm unable to locate a manual...
I found my plug, it reads System 5000
Plug In Class 2 Transformer
UL Listed 25Z4
E112794
Model No:AM-61000
Input:120VAC 60 Hz 15W
Output:6VDC 1000mA
Jun 06, 2011 | Exercise & Fitness
NEED A MANUAL FOR A VITAMASTER EXERCISE BIKE I also need a manual for a Triple Action Airwaves Vitamaster exercise bike.
I own this particular Old Fashioned bike -lol - its a hardy one thou and I dont think you can find the original book but the book that came with it came from the company Roadmaster Corp. which is now named Roadmaster Industries, Inc - 250 Spring Street NW - Atlanta, Georgia 30303 -- phone number -- (404) 586-9000. I hope this helps ya. My resource came from the website that tells all about the cpy.
http://www.fundinguniverse.com/company-histories/Roadmaster-Industries-Inc-Company-History.html
So good luck in finding your manual. I am pretty sure that they can help after all they made this bike originally in 1992,
May 04, 2009 | Cycling
The tension on the recumbent exercise bike does not get hard
If your bike has magnetic resistance and you changed the batteries this should make your tension work properly. Since it did not I believe that there are magnets somewhere on your bike that are wearing out. Or it could be a computer part. Your manual should tell what part you need to order and replace. I hope this information has been helpful.
Also make sure the batteries that you put in your bike are really new ones. Sometimes you can purchase new batteries at a store and they are actually a little weak. I had this problem with an elyptical trainer and I went and got other batteries and this fixed the problem.
Mar 14, 2009 | Cycling
Exercise & Fitness Logo
Top Everlast Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Everlast Exercise and Fitnes Expert? Answer questions, earn points and help others
