Question about Cannon Kitchen Ranges
Cannon Oakley cooker no gas getting to hob but gas supply is getting to oven how is this fixed
  • 264 Answers
SOURCE: oven does not work
its just your heater element you will need to wright down your model number and go on ebay or go to your local appliance shop they might order you 1 there about £35 pound
Posted on Jan 07, 2008
SOURCE: Cannon Camberley 10305G (Double Oven)
trust you have set the clock as this turns the gas supply on to the ovens
Posted on Mar 18, 2008
SOURCE: converting gas hob to electric hob
If you are in the USA most codes require a seperate circuit for the oven and the cooktop. Most cooktops require 30 amps and at least #10 wire.
Posted on Jun 29, 2008
SOURCE: need to set clock on my cannon chichester oven
Go to you should find your model there. Terry.
Posted on Jan 31, 2009
SOURCE: No gas to lower oven - Cannon Camberley
Hey Stephen - try setting the clock then set the cook period. the oven will only work when that's on i think.
Posted on Jun 10, 2009
My cannon duo cooker was working one day then next day the clock doesn't work, the ignition wont work theres no gas coming through to lite oven manually whats the problem the rings work perfectly
Gas ovens invariably have a safety thermocouple to cut the gas off automatically if the flame goes out, due to an interruption in the supply for instance. The thermocouple must be temporarily over-ridden for the purpose of lighting the burner and pilot and often the override is mechanical but considering the clock and ignition has stopped working it would be reasonable to assume your oven has an electrical or electronic thermocouple override.
It would seem either the mains supply to your cooker has failed or the internal power supply has a problem. With such a sophisticated oven, even if you had been able to light it manually, it is possible the temperature control wouldn't have worked.
Mar 26, 2016 | Cannon Kitchen Ranges
Hobs all working oven not working
Hob stopped working, oven still fine on electric cooker, any ideas ...
MoneySavingExpert.comDec 25, 2010 - From this point, we'll assume that you are happy to receive all .... have a "problem" that covers the hob not working but the oven doing so. Gas Hob Ignition Not Working!
May 22, 2007
Oven not heating - Please help
Oct 14, 2006
Oven won't get hot - help please
Aug 24, 2006
More results from
How to Diagnose a Fault With an Electric Hob ' eSpares > Advice Centre
Jan 01, 2016 | Logik LFTC60W12 White 60 cm Electric...
How do i change the bulb on a cannon oakley gas cooker
Turn lamp cover anticlockwise .fitted at rear of oven
Mar 02, 2015 | Cannon Kitchen Ranges
Cannon Cambridge glass top
This would require a new hinge for the lid as they have an internal spring offering the resistance to keep the top in the up position
Apr 06, 2014 | Ovens
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
Total electrical output
Bad news really, the supply cable you have there is not going to be capable of supply to any type of electric oven and hob like you listed above. Your supply cable is possibly only 2.5mm in size, and not the required 6mm with a much higher MCB at the fuseboard. Get a registered electrician to run a new cable from the board to your cooking area. A single oven takes about 3.2Kw adding the hob rings will take way over your limit. Curry's listing of that cooker as a load of .75Kw or thereabouts is obviously incorrect.
Jan 15, 2014 | Ovens
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
Severely reduced gas supply to hobs while grill
Valve at back of cooker that isolates gas to the hobs when the lid is lowered is sticking. Move lid up and down half a dozen times or oil it to ease it.
Dec 27, 2009 | Cooktops
Oven Ignition Keeps Clicking
it is the spark generator at back of cooker they are about £65
Mar 16, 2009 | Cannon Chesterfield C60G Kitchen Range
Dec 19, 2007 | GE Profile JGS968 Gas Kitchen Range
Kitchen Ranges Logo
Top Cannon Kitchen Ranges Experts
Paul Carew
Level 1 Expert
Tom Chichester
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
