Question about Emerson Televison & Video
My 32in emerson model lf320em4 a was knock off the stand,now the sound comes on the screen lights up,but you can't see anything but lines,with bubbles.,
  • 1121 Answers
SOURCE: I have a vertical green line just right of center
there is a defective LCD internal control board. Check for all inputs, the same defect. If so need to replace a LCD control board
Posted on Dec 22, 2009
SOURCE: direct tv codes wont work for my emerson tv
code for emerson plasma hdtv is 10812. for direct tv remote.
Posted on Aug 06, 2010
shane_barnha
  • 136 Answers
SOURCE: I have an emerson 32in
Not promiseing that this will fix yours but I had a similar problem with a different TV I unplugged for three or four minutes and plugged back in and worked ok after that so give that a try and see if it helps.
Thumbs UP if it did!!
Posted on Jun 21, 2011
  • 8 Answers
SOURCE: I have a 32in emerson model No LC320EM2 what kind
w mounting screws o71
Posted on Mar 02, 2012
  • 3382 Answers
SOURCE: HOW DO YOU Register an emerson TV:# LF320EM4 A
Try going to there web site.
Posted on Dec 06, 2014
What does a main control board cost for the Emerson LF320EM4 32 in cost ?
ShopJimmy lists several models for $32-$40 (compare sticker numbers on the main board, but presently all but one are out of stock. They also sell a replacement EEPROM chip for the board for $15; evidently it is a common failure point. Replacement of the EEPROM requires the equipment and soldering skills to change an SO-8 surface mount integrated circuit.
Emerson LF320EM4 TV Parts
Jul 15, 2017 | Emerson Televison & Video
My Emerson LF320em4 TV when switch on, red light blinks 4 times and immediately return to stand-by-mode. no picture no sound. can you help?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts...
Jun 26, 2017 | Emerson Televison & Video
Emerson lf320em4 a g red light blinks 3 times but wont come on
Could be an open internal fuse or power supply failure
Jul 23, 2016 | Emerson Televison & Video
What size screws fit the back of Emerson TV model LF320EM4 A for wall mounting?
Contact the authorized dealer for Emerson to get more details.
Feb 24, 2015 | Emerson Televison & Video
How do i flip the picture display on emerson lf320em4?
When in file viewer mode you can rotate pictures, this is in the manual and may be the cause.
May 04, 2014 | Emerson LF320EM4 32" 720p 60Hz Class LED...
Why is desktop green like theres way to much yellow hue
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 03, 2014 | Emerson LF320EM4 32" 720p 60Hz Class LED...
What size mounting screws emerson lf320em4f
lf320em4 takes a M4 20mm long. Beware, on the lf320em4 the mounting holes are directly in-line with the HDMI input jack.
Jan 06, 2014 | Televison & Video
Televison & Video Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
