Question about Homelite Expand-It Recon Blower Attachment
Need to replace gas filter on the Ut08120 leaf blower
  • 130 Answers
Make a hook out of closehanger then look in gastank see filter fish out filter with hook.then
ones out pull in your fingers pull filter off hose
and then push the other one on.let me know if this help you please
Posted on Jul 25, 2009
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
Why want my leaf blower get gas it will crinc but then it just shuts right back down why
Bend a hook on a piece of wire and fish out the filter in the fuel tank. Check the gas line and remove the filter and see if you can blow through it. You should be able to blow through it fairly easy. If not replace the filter. Luck.
Nov 19, 2015 | Garden
Echo pb 251 leaf blower leaks oil
You need to check your gas line and the primer ball itself and make sure you don't have a split in the lines or in the ball, also check the fuel filter in the gas line to ensure it is not plugged up.
Apr 24, 2014 | Echo Pb-251 Leaf Blowers
I need the fuel line size on Homelite gas blower. Is the fuel filter a washable/cleanable filter?
i think they are 1/8 in hoses on them and if it is a foam filter they are washable,mild soap and then a light coating of oil
Dec 24, 2009 | Homelite 'Yard Broom' Leaf Blower
Leaf blower will crank only when spark plug is dipped in gas and re-inserted
fuel system needs to be cleaned, carburetor diaphragms and gaskets replaced, check fuel lines, filters, primer bulbs
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 07, 2009 | Homelite 'Yard Broom' Leaf Blower
Ryobi gas leaf blower starts but will not stay running
carburetor & fuel system needs to be cleaned and carburetor diaphragms and gaskets need to be replaced, inspection of fuel lines and filter
Nov 07, 2009 | Ryobi Garden
Won't start --has gas--has spark craftsman leaf bower
most likely the air filter is clogged, take it out blow it out or spray water through it and allow it to dry completely.
alterinavely, just pouring a small amount of gas onto the filter should make it work, i would do that even if you do clean it properly.
this method works for cars too!
Nov 07, 2009 | Craftsman 4 Cycle Blower/Vac
Weed Eater Lightweight 1500 Leaf Blower Fuel Line Repair. There is something in my gas tank, which I assume is a filter of some sort and I need help getting one replaced and onto which fuel line it should...
there are two lines going into the tank one is short which just goes in the for pressure from the primer bulb the other line goes to the filter which goes to the carburator
Itsman
Nov 03, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Leaf blower problems
You may have a dirty fuel filter, or carb needs cleaned.
Mar 19, 2009 | Craftsman Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Homelite Expand-It Recon Blower Attachment Logo
151 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
