Question about General Computers & Internet
Inspiring duo convertible won't load after factory reset
Its asking for general location questions & says applying settings
3 Suggested Answers
mace1mace
  • 1138 Answers
SOURCE: dir-300 dlink router asking to reset to factory after installatio
there's an easy way to reset your router back to its factory setting... inspect the physical appearance of your router... there should be s small hole.... inside that small hole is a reset button
How to reset? ..... while the router is on...Using a small pointing object, much better if you use a paper clip..... insert the paper clip to the hole... press and hold the reset button for 10 seconds...
That's it your router will restart itself and the settings is back to its factory settings...
Hope that help you..
Much appreciated if you rate this help... thanks
Posted on May 22, 2010
  • 16243 Answers
SOURCE: Hp pavillion won't reset to factory settings
What is the reason that you want to reset it? What is the model number
Posted on Mar 16, 2013
I dont know how to find the reset button on a iphone 6s
that is because there isn't one. Resets are done from Settings or from a computer running the iTunes program.
Click Comment under this post if you need further info. I am 3GS, 4S, 6 and 7 :>)
Mar 13, 2017 | Cell Phones
How u do reset a iphone 4
If you mean to restart the phone, just press Power Button and the Home Button together until you see an Apple Logo in white on the Screen
Now, if you are looking to apply in full a Factory Reset, go to Settings, then General, scroll down and tap on Reset, then choose the option for Erase All Content and Settings. Remember your iCloud information since it will be asked to you. Anything, let me know.
Dec 29, 2015 | Apple Iphone 4s I Phone 4 S Factory...
How do I factory reset my phone?
IF it's a Iphone go to settings look under General scroll all the way down and you will see Reset it will ask you these types of questions.
1.reset all settings
2.Erase all content and settings
3.reset network
4.reset keybored dictionary
5. reset home screen layout
6.reset location & Privacy!! Hope i helped you any:) " GOODLUCK"
Apr 17, 2015 | Samsung Cell Phones
How do I reset my I-pAD back to original factory settings
1. On the Home screen, tap "Settings" to bring up the Settings screen. 2. Tap "General"
3. And then tap "Reset". This brings up the Reset screen which will give you the following options. a. Reset All Settings - this resets all your settings back to factory default but does not erase your content data. b. Erase All Content and Settings - this resets all your settings and erase all your content data. You might want to do a sync with iTunes before performing this erase if you want to keep any music or apps that you have downloaded. c. Reset Network Settings - this deletes your Wi-Fi network settings. d. Reset Keyboard Dictionary - this clears any history in the dictionary such as the history of the keyboard suggestions that you've rejected or accepted previously. e. Reset Home Screen Layout - this simply resets your Home screen icons back to the original default layout. f. Reset Location Warnings - this erases any location preferences that was set for your apps. For example, GPS-aware apps often popup a location warning asking if you want the app to be aware of your current location. Your answers to these questions are stored by your iPad for each app. This reset will erase these answers so that the app may popup the prompt asking for your location permission again the next time you use it.
4. After selecting one of the above options, the iPad will ask for confirmation that you really want to perform the reset. If yes, confirm by tapping "Reset".
Jul 16, 2014 | Apple Ipad I-pad
Android System Recovery
Obvious question is what the tablet had been doing during its' last use.
Was something newly installed, was system or apps updated, etc. ?
Were all the APPs and or system shut down properly ?
Did update or installation recommend restarting system, prior to use ? Were multiple installations / updates performed ?
Your device appears to be in a recovery boot-loop.
As stupid as this may sound ...
Is the power adapter connected ? Let battery charge for at least 30 minutes and try again.
If battery is low, it may not complete the reset. - you should have seen something on the screen, denoting " wipe and reset " procedure and completion - prior to (#1) Rebooting device
Per your post, you have already (#4) wiped the data and instructed the device to reset to factory settings, then (#1) Reboot system.
That is the generally accepted reset method
This problem is not all that uncommon, it generally results when attempting reset, internal boot commands error for what ever reason. ( can not find the factory restore / recovery file set ).
This problem is more common when "fixes ", Specialty " Roots " or "mods" have been installed by the user - making changes to the boot program and commands OR when manufacturer files have been deleted / moved from system access. - Common suggestion is to work backwards through the mod processes and / or attempt to re-install mod or follow the special mod recovery method.
Without having available the proper ROM " flash " update / installation file(s), and you may " brick " the device.
I recommend you go to manufacturer site and check for available ROM files, reset / reinstallation processes ( memory card method ? )
You state the tablet is less than six months old. You may want to contact manufacturer for possible warranty service.
They will most likely ask the referenced obvious questions, to better understand the cause / nature of the device failure and recommend the best immediate possible solution.
This may not be what you seek, I hope it will provide better direction.
Apr 20, 2014 | Hannspree SN10T1 101 Tablet
Its asking for a eight number code
It is asking for your security key. If you do not have it, you will need to reset the router:
How to reset D-Link router to the Factory Default Settings
In general, to reset the D-Link to the Factory Default Settings, please follow these steps:
1. Turn off the router
2. Locate the Reset button on the back of the router.
3. Use a paper clip to press the Reset button and power on.
4. Hold for about 5 seconds (don't hold too long) and then release. (Or, release when M1 and M2 flash at the same time.)
Sep 13, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Hey thanks for answering my previous question.i have an LG p500.i downloaded adobe flash player from some site and it didn't work on my phone so i deleted it.since then the internet on the phone is not...
You may have to reset your phone to factory settings, ring up your service provider and they will give you a hard reset number. Good luck. Dont forget feedback please
Jun 05, 2011 | LG Cell Phones
I have downloaded few themes for sony ericsion w302 but i coludn't apply. help me?
Hello :
At the links below you will be able to find thousands of themes and download them free of charge. just look for your device in the pages and you will find what you are looking for .
http://www.mobile88.com or www.zedge.net
If the problem is with applying the themes in general , then you need to restore default factory settings for your device .
Here is how to reset your device : Go to restore factory settings and when it asks for the code , just enter 0000
good luck .
please rate !
Mar 28, 2010 | Sony Ericsson W302 Silver +512MB by Fedex...
Nokia N96 Reset Default Settings
Yes i can help go onto your main menu and click onto TOOLS...then click SETTINGS .. then GENERAL.. go down and it will say Factory settings click FACTORY SETTINGS.. it will then ask you for a code teh reset code is 12345! hope this helps :) your phone will automaticly re start but may take a few minuits to re start dont panic just let it load and it sould be fine howere avoid doin this to often x
Apr 02, 2009 | Nokia N96 Smartphone
Computers & Internet Logo
Top General Computers & Internet Experts
Dan Shibata
Dan Shibata
R.A. Ellis
R.A. Ellis
Vladimir Frolov
Are you a General Computer and Internet Expert? Answer questions, earn points and help others
