Question about Vacuums
Where can I buy job mate shop vacuum, filters and bags?
Numbers on shop vac 54-00116 & 6851-4112007
MakikiChris
  • 84 Answers
SOURCE: emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
Posted on Aug 02, 2007
SOURCE: shop vac
Vacuum is less than a year old and died in the middle of a use. No power... tried to plug it into 3 known, good outlets. Suggestions?
Posted on Jul 06, 2008
advacak
  • 125 Answers
SOURCE: what bags do I use for Royal canister vacuum #3004
uses a royal or dirt devil type R bag
Posted on Dec 08, 2008
  • 10 Answers
SOURCE: DEWALT DW795 Vac filters
IT looks like the part number is 429704-56 and the Dewalt site shows list price being $51.68. You should be able to order that filter at a DeWalt dealer in your area, hopefully for a discount.
Otherwise, there is here online:
http://www.ereplacementparts.com/search_result.php?osCsid=2c10ce07c62a161bca9f80f981bf690f
Posted on Feb 26, 2009
SOURCE: Can't install a bag for my Craftsman 16 gallon shop-vac
Well, good news, you don't need a bag! The trash just settles to the bottom of the bucket and you just dump it out.
I own one of these -- it has many little operational anoyances -- like wheels falling off, lid popping off, etc. If you run into these scenarios and want help on fixes, drop me a line.
Would you please rate my response. I think you'll see some icons at the bottom of the post to enter a rating.
thanks...
Charlie
Posted on May 09, 2009
Tip
Safe way to vacuum drywall dust
SAVE THAT VAC
One of the hardest things on a shop vac is drywall dust. It is so fine that it gets through the regular filter and destroys bearings/bushings and ruins the motor. Just the other day, a friend commented that he had to get a longer hose as his vac was blowing out a lot of drywall dust because the filter was slipping down!
High performance filters are available at most hardwares and box stores. They resemble the paperbag filters in carpet vacuums and catch the drywall dust so that the bag can just be thrown away when done. The bag is U-shaped to install in the shop vac and have clearance around the regular cartridge filter. The inlet has a rubber seal that pushes around the inlet on the inside of the tank. Just run the vac normally but spare it and your lungs!!!
on Mar 02, 2010 | Vacuums
Can I use shop-vac without bag 5gal5.5 hp
If you are using it for wet pick up, you would not use the bag. If you are using it for dry pick up, I would recommend using the bag to keep dust from going thru the vacuum and back into the area you are trying to vacuum.
Apr 06, 2014 | Shop-Vac Corporation Shop Vac Wet & Dry...
When using a bag inside shop vac, do I still need to cover the motor with foam & paper & ring or can I leave those off?
Keep it on. The purpose is to give you something to clean, a time or two, rather than have to replace the more expensive filter. I know it seems redundant, but all of the pieces filter better than just a bag. Also, if the bag gets any damp or wet material, it breaks and your next filters are the foam and paper filter.
Feb 28, 2011 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
I need a user manual for the Shop Vac Classic 20 (http://www.shopvacint.com/SVA0000770.asp). My main issue right now is that the 'filter' is no longer working, I'm unable to get a replacement here in the...
The bags you ordered are for the ZR 80 type. After veiwing the link you submitted for the type of dry vac you have, these bags will not work with your Classic canister Vac. The filters you need simply go over the intake area,sort of like a coffee filter upside down, the a mounting ring slides over the filter and slid down until it can not go any further,the ring holds the filter in place.(over the foam filter)
Jun 09, 2010 | Vacuums
I have a kenmore cannister vac - model 27514. Do I have to use hepa bags in it, or can I substitute another type, and which would that be?
You know, any bag made for the unit should give similar results. You can buy a cheaper bag and that number is 50558. You can get them at your local vac shop or you can let me know, I will send you some. The price per 3 pack is only 4.95. The canister vac is made in such a way that it doesn't have much leakage. It is quite efficient with or without hepa bag. If you or anyone in your family suffer from asthma, I would recommend the use of the hepa bags. tThanks, Rene(The Vacuum Doctor)
Nov 10, 2009 | Vacuums
Old shop vac
Yes there should be a filter fitted onto the top section.
For suppliers, it would be cheapest to find your nearest stockist, or buy online and have it shipped. It's still current stock - so spares should be readily available.
Sears stock it -
CRAFTSMAN FILTER
Thank you for using Fixya,
Sep 22, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
Using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Sep 16, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
There are no known vacum bags for a model wd06350 vac
This type of vacuum does not use a bag. If you are worried about clogging the filter cartridge try using a paper filter for a shop-vac. They are relatively cheap and are available at most hardware and department stores. These are made to simply wrap around the big cartridge. A rubber band will hold it in place.
Feb 09, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
I have a 6 gallon shop wet or dry vac. The dust and dirt comes out around the base of the motor fin, not around the tank top. Now what? Oh I lost the filter around the drum that holds the ball, so I...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=765231
Generic problem for all Vacuums
I have a 6 gallon
Posted by tsfroggy on Jul 10, 2008
I have a 6 gallon shop wet or dry vac. The dust and dirt comes out around the base of the motor fin, not around the tank top. Now what? Oh I lost the filter around the drum that holds the ball, so I wrapped a rag around it and made it secure. Respectively: TOM
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The bag is not going to do the job as well as the filter around the drum that hold the ball. The filter that goes under the motor does a lot of the filtering or you would have to do some type of cage filter then a foam filter and then a paper bag, I f you have a cartridge filter then the paper bag can go over the cartridge filter , B4 you do anything – id you have some type of compressor – use it to blow out the dust and dirt out of the motor, then buy a cartridge filter and then a paper bad with a rubber band to hold it on. This will do the best filtering . Check with your local vacuum cleaner dealer and bring in the top of your shop vac so that they can fix a proper cartridge / paper bag filter – or the cage frame with a foam filter with a paper bag. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp
Customer Service 570-326-0502 Phone #
Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Vacuums Logo
67 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
