I need to put "Ready Set Learn" back on television on Discovery Channel.
My westing hous hdtv is stuck on channel 35-3 and will not switch to another channel, the remote doesn't work and neither do the buttons on the side of the tv, the power button works but won't
Try to unplug power from set for a while and plug back to reboot--immediately delete that channel from the set's memory as it may contain signal that is causing this.
Also look to see if the set has a feature to lock out the buttons and or the remote control---a few do.
Most likely something in the signal for that set caused the set to lock up.
Sep 02, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I need instructions to assemble the Discovery Toys Super Marbleworks Raceway Construction Set.
There are purposely no instructions for building Marbleworks. Any two pieces fit together, and you learn how to tweak it and improve it as you build it. Try it!! Enjoy! www.toysofdiscovery.com for more questions about Discovery Toys.
Apr 05, 2011 | Toys
I cant hook up my tv thru old vcr, what am i doing wrong, thanks
You have to make sure the tv/vcr switch is on, the way you do this is put a tape in and press play, make sure the set is set to 3 or 4 in back of VCR, then make sure your tv is program to that channel 3 or 4 it has to be programmed and to be prog,, it must see something there.
Dec 16, 2010 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
How to connect an AKAI LCD tv to an INDOOR antenna. I have set the TV from cable to "air".
Put tv on air, connect antennae to the coaxil input on back of tv.
You can also go to tv's menu and find the "autoprogram" feature and select it. Let it run thuroughly until it is done searching all available channels. Tv. may need to be on channel 3 or 4 to use the antennae/converter box
Nov 17, 2009 | Akai CFTD2011 20 in. EDTV-Ready LCD...
With a cable box connected to tv only 1-21 are comming in rest of
set box and tv both to chanel 3 reboot box by unplugging plug back in then do channel scan for digital channels see if that helps
Mar 20, 2009 | RCA F32650 32" TV
New TV doesn't register being HD ready during test TV stations do
Try going into the setup menu and make sure it is set to antenna then do a channel program. You don't need to wait for a test there are plenty of channels already there. Both digital and analog channels are still available so you will still a message that you are not receiving digital if you are putting it on an analog channel. The channel number has to have a dot(.) in it like 8.1, 24.1 If there is no dot you are on an analog channel
Mar 13, 2009 | Westinghouse Electric W1603 15.6 in. LCD...
Dts42w will not turn on ? i see a red light in back of set on
what kine of additional plug i need to plug in i am having problem learn how to trouble shooting the power in the tv also i am having problem with the tv tube i am trying to learn how to do these thing so that can help myself and my letter son i have no money ta this time is there anyway that you all can help me thank you
Dec 18, 2008 | Electrograph Systems DTS42W 42 in....
No sound on hd tv on just one station
put tv on ch 2 and locate MTS button and press it till the sound comes back min English
Electrode.
Nov 23, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Channel changes to channel 1 when your turn set off
Did you ever get a solution for this? I have a very similar problem. And yes, I realize this was posted 5 years ago. :) just a shot in the dark. Can't find a solution anywhere else.
Nov 01, 2007 | Philips 42PF9966 42 in. HD-Ready Plasma...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
