Question about John Deere Garden
My John Deere 145 won't crank. it acts as if it is not getting gas to the carburetor. we have changed the modulator, checked the fuel lines and fuel filter. the gas is clean. can you help?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • John Deere Master
  • 969 Answers
Put a little gas in the carb and try it. if it starts for a few seconds and dies it is starving for fuel. be sure fuel is going through the fuel lines to the carb. if so the carb itself may just need cleaned.
Posted on Apr 16, 2017
John Deere 160 lawn tractor.
May have online fuel filter in line, need to check. Also could be wear in throttle shaft or housing in carburetor.
Aug 12, 2017 | John Deere Garden
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
John Deere L130 riding lawn tractor will not start what do I do?
I'm assuming the motor will crank over, but not start. Remove the air intake cover & filter off the carburetor air intake. Do you smell gas? Is gas dripping out of the carburetor? If not, spray a couple shots of starting fluid or carburetor cleaner into the carburetor air intake throat. Close the choke & crank the engine. If it starts, & stalls, repeat the process. If it won't stay running, your carburetor float jet is gummed up & needs to be cleaned. Check & clean the spark plug. Does the spark plug fire when the engine is cranked? If no, then you have an ignition problem.
Mar 05, 2016 | John Deere L100 Series
Doesn't act like it is getting gas. Cranks but wont start. Will start if I pour gas in carboretor but won't stay running. Changed gas filter and fuel pump.
Hi: I sounds like it is not getting gas, it probably need the carburetor cleaned out. but first make sure the gas is turned on, tighten the carb . I you have left it for a long time with out running the gas out it most likely needs the carb cleaned Good Luck I hope I was of some help
Dec 19, 2015 | John Deere EZtrak Z225 Zero-Turn Riding...
John deere la 105 is not getting gas to carburetor. changed pump and blew out lines
Take line off fuel filter and see if you fuel. Check the outlet in the tank and fuel cap vent.
Oct 22, 2013 | John Deere 420,1020,2010,2020,2510,2520...
LA 145 won't crank...replaced battery & fuse
Check your battery connections. Pull spark plug. A lot time the cyl. will with fuel.
Mar 03, 2012 | John Deere Garden
I have a 345 that has been running fine until it suddenly quit. I checked the spark - ok, checked to make sure the cylinders were working - ok, I haven't checked the fuel pump yet, not quite sure how...
Take the fuel line off of the carburetor and hold the line over a gas can. Crank the engine and watch for fuel to flow. Not just a dribble but but the flow should fill the fuel line and you should get about a coffee cup full in 15 or 20 seconds.
Jun 15, 2011 | John Deere A,b,g Tractor Carburetor Float...
John Deere gas 1020 that runs well when it it cold but as it warms up not so good. Seems to be a carburetor problem accoount when going over rough terrain it skips badly. After running a long time today...
needle and seat in carb probably shot thanks to the alchol in fuel.carb kit for under 20. should fix it,also install a fuel shut off in the fuel line to avoid engine flooding when not in use..
Jun 01, 2011 | John Deere Tractor 1020, 1520, 1530,...
My John Deere X320 has gas fires up, but will not start running
Alot of the X300 series mowers were shipped out of factory with interlock modules that failed often and some were on a fix-as-fail program.Not sure if this is whats wrong with yours but if it was in our shop its the first thing that gets replaced depending on you serial number.Its located just under the front side of dash with a few wires going to it.
Oct 20, 2009 | John Deere 3010,3020 Tractor Basic...
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
