Question about The Audio Players & Recorders
Combined power and speaker input pins layout
I have Xline Chrome subwoofer which has some weird 8 pin power and speaker input. i do dont have the proper connector so i would like to know the pin layout so i can connect it directly to the battery
SOURCE: need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Posted on Jan 07, 2009
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
lil_smurf
  • 7 Answers
SOURCE: JBL Media 100 Speaker power?
Buy a power adapter from radio shack or similar place. You need a 1000mA 12 volt dapter. Just make sure it is rated @ or above 1000mA to avoid the adapter heating up and possibly burning. The whole setup is rated @ 850mA wich 1A(1000mA) should handle with enough head room. But it might run you about $15-20. I would just buy a cheap radio with rca inputs/aux input and use that. I got one from Walmart for around $40 and it plays CD's & AM/FM.
Posted on Jun 09, 2009
SOURCE: Dell GX270 SATA front panel 34 pin layout
Link to GX system board layout: http://support.dell.com/support/edocs/systems/opgx270/en/ug/index.htm It's all on a small board and control panel, both of which connect via ribbon cables. Have you removed the power switch, etc from theseboards?
Dan
Posted on Jul 18, 2009
dunnbiker
  • 8546 Answers
SOURCE: how to start a Bose acoustimass 9 powered subwoofer
The Bose cube systems are SYTEMS for a very good reason. They're made for people who want good sound but don't want to manipulate the hardware much. The speakers and amps are designed for each other ONLY, not only electrically but through soundshaping to provide the smooth final result. The design is for you to feed the electronics a Line Level source and the magic and distribution happens internally. These are NOT mix 'n' match components. The special connectors are a clue. The 'different' amplifier will probably blow them up.
Posted on Dec 28, 2009
Need help with a VGA cord
I dont know, but I do know it is a proprietary cord, it is meant to work only with that model of unit
Jul 28, 2013 | Audio Players & Recorders
Tip
DELL A425 SUBWOFFER PINOUT
CABLE PIN OUT
PIN 1 SPEAKER 1 PIN 5 SPEAKER 2 PIN 3 INPUT 1
PIN 4 INPUT 2 PIN 8 EXTERNAL VOLUME CONTROL PIN 2-5-7-9 GRD
PIN 8 MUST TO GROUNDED FOR MAXIMUM VOLUME OUTPUT
on Jun 25, 2014 | Dell Zylux Powered Subwoofer - P/n A425
Wireing diagram for Dell A525 Zylux Multimedia Computer Pc Speaker System W/subwoofer 2.1
pin 1-G
pin 2-R in
pin 3-L in
pin 4-PG
pin 5-R out
pin 6-ST BY
pin 7-VC
pin 8-L out
pin 9-PG
Sep 26, 2012 | Dell A525 Zylux Multimedia Computer Pc...
Is there a way to use the Altec Lansing VS4121 Subwoofer as a stand alone?
Normally these low end systems components that depend on each other and cannot be interchangeable from other system. So if one of the components (sub woofer or right control satellite speaker) breaks or gets lost the whole system is unusable...
I was in the same situation. Got a sub woofer from VS4121 without original satellite speakers. I acquired satellite speakers from Altec Lansing 251 which used same connectors but the internal wiring was different and incompatible out of the box. Speakers are also glued together so it is impossible to open without damaging it. Not to mention there is no service documentation anywhere..
But if you like electronics you can try to make something based on the information bellow:
Altec Lansing VS4121 connector pinout
If you take the male connector (from right satellite speaker) and look at the pins and number them first row from left to right pins 1-3, second row pins 4-7, the bottom row pins 8-9 and the circle enclosure as 0
0 - Ground
1 - Speaker Right
2 - Treble (seems just like voltage control but may need to be confirmed: Min=0V; Max=voltage from Volume control Pin 9)
3 - Head Set Right
4 - Bass signal (not sure what the exact original design is as I have not opened the speaker) But seems like they use 50K potentiometer and some sort of RC low pass filter configuration. When potentiometer is set to Min it is shorted with ground. When set to Max it is taking signal from Right and Left Head Set (pins 3 and 5) combined through some larger resistors and low pass filter.
5 - Head Set Left
6 - Ground for Head set (grounds 0 and 6 seems to be connected in the subwofer but within the right satelite speaker they seem to be isolated with separate leads to sub)
7 - Power ON/OFF. When OFF or head set jack plugged = 0V; When ON and head set jack unplugged = 5V
8 - 5V Power in
9 - Volume (min=0V; max=5V). It seems they use 50K potentiometer but probably anything >10k should work.
At minimum for standalone sub woofer you will need to implement:
- Power On.Off (switch between pins 8,7)
- Volume control (50k potentiometer (probably anything beteen 10k and 50k will do)between pin 7 and 0 with variable output to pin 9
- Bass control - join two resistors R (I used 7k) and lets call this join point A. Attach other ends of the resistors to pins 3 and 5 respectively. Attach 50k potentiometer (I used 10k) between point A and ground 0. Attach Variable pin of the potentiometer to pin 4 (Bass input signal). Attach capacitor C between Pin 4 and Ground pin 0 (I used Electrolytic 1uF with negative end to ground) . Resistor R and capacitor C should make simple passive low pass filter (Google for formula) that should bypass anf frequency higher than 80-120Hz to ground and feed frequencies lower than 80-120Hz to pin 4.
PS: I managed to hack 251 control satellite speaker to somewhat work with VS 4121 Subwoofer but that is another subject. All electronic parts were salvaged from old broken TV so total cost was $0 but took several days of tinkering for speakers that I could buy used for $10-20 :)
Jun 25, 2012 | Altec Lansing VS4121 Speaker
I have an older Pioneer TS-LX100 powered car subwoofer. It is missing the power plug, which is used to connect the 12v+, remote, ground, and speaker level inputs. It is an 8-pin connector. I have a power...
You can splice one wire at a time instead of cutting them all at once. Just cut one wire, splice the same wire from the old connecter to the new one. You can identify which pin is which by using a multimeter to find 12 volts and use it set to continuity to see what pin is connected to the wire you just cut.
Oct 01, 2010 | Pioneer Car Audio & Video
JVC DVD players
Use a sling for multiconnection to connect 8 pin input;
Sling Media - Slingbox
Jul 19, 2008 | Audio Players & Recorders
I have a Pioneer HTV-C2 center channel virtual surround speaker system with a powered subwoofer.When i plug everything in and power it up i get a quick 3 second burst of sound and then it stops,but the...
i have a Pioneer HTV-C2 center channel virtual surround speaker system with a powered subwoofer.Lost the cables, can somebody help me, dont know where to get them???......original cable part # are
ADX-7239 this is the system cable A and (rectangle connector)
ADE-7023 this is the subwoofer cable B.....(round connector) 8 pins both
is there any compatible cable....thanx apprecieate ur help!!!
Jun 30, 2008 | Audio Players & Recorders
Need wiring and 9pin connector diagram
Pin 8 = Power A
Pin 9 = Power B
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Yamaha YST-SW150 Subwoofer
hi, is it a humming noise ??? check if the connector is plugged in properly,check the earthing, if its a three pin mains plug, if its a two pin, then the CPU SMPShave a proper eathing. let me know
Jan 10, 2008 | Yamaha YST-SW150 Speaker
Lose wire with 6Wires connector... need diagrams of pin out
(There are different versions of the ba-200, so I'm assuming they al use the same wiring/pinout...) if you look at the amp on the enclosure(right-side up... so the writin goes left->right): The top left pin is #1, beside it is #2, then #3. The bottom left pin is #4, beside it is #5, then #6. #1 Right speaker positive input #2 Empty #3 12 Volt Constant Power #4 Left speaker positive input #5 Remote turn on / Acc power input #6 Ground Now there's supposed to be a 15-amp fuse on pin #3 (12v constan power).
Aug 22, 2006 | Audiovox BA200 Car Subwoofer
24 people viewed this question
Top The Audio Players & Recorders Experts
ctlimey
Level 1 Expert
D. E. Hev
JOHN TOPLISS
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
