Question about Garden
Wand assembly for 15 gal spot sprayer # 9583. Can this be purchased separately.
    Top Expert:
  • Garden Master
  • 80,407 Answers
We have no way to look that up. Contact a local retailer please.
Posted on Apr 15, 2017
Sprayer parts
need the hand wand were you pump up 3gal
Apr 14, 2014 | GroundWork® Pump Sprayer, Brass Wand, 3...
I have a B&K kitchen faucet (LM#203120) in my 2005 Newmar motor home. The spray wand has recently broken. The spray wand is approximately 6.5 inchs long and is connected to the water line by means...
If you are talking about the standard spray nozzel with trigger type control than replacement sprayers are reaidily available. You should be able to unscrew flex hose from nozzel at the base of nozzel where sprayer goes into holder on sink.There should be ribbed section on sprayer where flex hose goes in. Grip that section and turn upper section of sprayer counterclockwise to remove. Most hardware stores will have replacement nozzels for under ten dollars. Hope this helps. Thanks
Nov 12, 2010 | B&K Plumbing
Leaking at valve handle for broadcast
This happens a lot. Sometimes it's just the hose connection to the wand. If that appears to be the leaking spot, remove the band clamp, take off the hose, and cut off the last 1" of the rubber hose so you get a fresh end. Push the freshly cut end onto the wand, and tighten the band clamp. Did that fix it? If not, you'll need to replace the wand, but they aren't too costly. You'll find some on this page . Good luck! Please rate my solution if helpful, thanks.
Jul 17, 2010 | Northstar ATV Spot Sprayer 26 Gallon, 2.2...
Pump is presurized but no spray
Most weed killers and fertilisers either crystalise or turn to gel when left unused. Pull sprayer wand to pieces and run hot water through the hose and wand, they especially clog up at the spray tip and at the on'off control.
May 14, 2010 | H.D. Hudson 1 Gal Poly Deck Sprayer
Moultrie 25 gal spot sprayer for water sealer treatment
Yes, I've used pumpup hand sprayers to apply sealers. Is the sealer water-based? If not, cleaning up the sprayer afterwards could be a chore!
Mar 01, 2010 | Moultrie 25 Gal. Spot Sprayer
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Fimco 15 gal Sprayer, 12 volt, No power
cross the wires on the pressure switch, if it runs then, replace that switch is all!
Jul 02, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
I also have a FIMCO 15 gallon 12 v spot sprayer, won't prime
I use an emulsifier with Round-up to make it stick better to the weeds (Sticky Spreader). The emulsifier had made the solution less viscous and was not moving through the wire mesh filter that comes out of the bottom of the tank. I removed the filter and it works fine. I have a filter in the handle anyway so there is no need for two filters for my application.
Jun 05, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
