Question about HP Computers & Internet
HP Desktop 550-a114, will not turn on, though there is a green bright light on the motherboard
    Dedicated:
    Visited the website for 20 consecutive days.
  • 947 Answers
If it won't power on at all its probably a failed power supply.
Posted on Apr 15, 2017
  • HP Master
  • 2,302 Answers
Take a A+ cert course then tell this fib again.?
An LED can glow at 2vdc, tells you nothing!
only that some weak power is present, nothing more...!
learn that in electronics.
it can fail all theses ways.
good
bad.
weak
intermittent.
the PSU tests are covered here, take a volmeter
not some LED on a stick or parts glowing.
got 50 years of on the job doing this, from DC to daylight, from MIL to you name it.
http://pcdied.com/black-screen.html
Testimonial: "It can't be the power supply, when the green light on the motherboard is still on. It has to be something else. Do you know where I could get a FREE diagnostics done on my HP Pavilion Desktop?"
  • Anonymous May 31, 2017
    never say can't to any fully certified tech
    I can sell you 10 bad PSUs, all that are BAD
    and glow that LED
    cheap, cheaper than DIRT.
    http://pcdied.com/power.html
    that last link shows real intel mobo. schematic
    so you can learn what is there.
    if the fans are dead. the PSU is bad
    if the PSU is ok then the MOBO, power logic
    is bad, or even the power switch wires fell off the MOBO. (saw 2 bad switches in 32 years on PC)
    in a real shop, we jumper the switch jack wires
    omg, it turns on, leaving what>? bad switch.
    if the Fans do run that means only 12vdc is good.. after all its just a 12v fan.
    not the other 9 power supply lines bad ?
    all must be good.
    all in the PSU and all regulators on the MOBO
    must work and guess what, they fail too.
    3million transistors there, or more, non trivial.
I HAVE A HP 610-1030F ALL IN ONE DESKTOP IT WILL NOT POWER ON AT ALL GREEN LIGHT NEAR THE POWER BUTTON IS GREEN UNTIL YOU PRESS THE POWER BUTTON DOES ANYONE HOW TO FIX THIS PROBLEM?
The HP all-in-one PC's have a video card issue, and the bad thing is that the video card is on the motherboard, so the whole thing needs to be changed. If you have warranty, then you are good, but if not, you will end up spending somewhere from $150-$300 on the repairs. One way is to look for parts and the Motherboard on ebay or craigslist, but be careful before you part with your money. I would suggest if you do not have warranty, to just go ahead buy another PC, a desktop, make sure you do not buy an all-in-one again as these are prone to these kind of malfunctions.
Mar 23, 2015 | HP Touchsmart 610-1030f 23" 3.2gI3-550 4gb...
HP Photosmart 7280 all in one. When power cord plugged in, printer will not turn on
Sounds like it could a power supply problem inside the printer or a motherboard component failure. It needs to be taken in for servicing. There is no way to tell what the problem is without an internal review.
Apr 28, 2014 | HP Photosmart C7280 Printer
My hp pavilion a430n is not turning on. even though i pressed the power button the light wont even turn on. it is truly annoying and the screen says something about the power supply and green, red, blue...
I suggest to open your computer and unplug your power supply and look for the color green and black cord which plugged from your motherboard. Then find a piece of wire and short the color green and black wire to test if your power supply is working and plug to your power socket. And check your electronic parts (capacitor) near at your processor, it might your capacitor blown out.
Nov 15, 2010 | HP Pavilion a430n PC Desktop
Computer will not turn on. green light blinking
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
May 01, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
Will not boot up after not being used for a long time. Power is getting to the board.
Fans turning? If this is an old machine you may need to check the motherboard voltages. I just had a computer with an asus board with a green light that turned out to have a bad power supply. So it is possible to have a light and still not enough power.
Check the motherboard for popped capacitors. If you see some then the motherboard is bad though probably repairable.
Mar 09, 2010 | Netier NetXpress XL1000 PC Desktop
HP Pavilion desktop. Installed new RAM, won't power up.
the power supply seems to be fine> but we can check by removing the BIG ATX white connector on the motherboard> if the light is still on then the power supply is fine>>> then
we can first remove all the RAM from the motherboard> then connect the computer to power and then see if the Computer beeps or not> if it does the motherboard is fine > if it doesnt then the motherboard need to be replaced
Oct 17, 2009 | HP Computers & Internet
My hp a6130n desktop computer won't turn on after a lightning storm. The power supply is good (the little green light in the back comes on) the switch is good - tested it, so I wonder what is wrong - is it...
i got the same problem accept it didnt involve lighting storm thunder when i turned it off then i try turning back on it would start any help seems like the motherboard is fine the lil green light on back is on also can figure the problem help plz?
Jul 06, 2009 | HP (D7580-60003) Motherboard
Wont start power supply binks
What do u mean u unplug the motherboard...?
May 27, 2009 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Computer will not power up. there is a green blinking light on the motherboard.
did you try to uplug and plug back up?
i had that problem.
it was a short(i know because i cause the short)
i had a old motherboard dell celeron 2.0ghz and i just was bored and started touching metal to metal and it started to blink so check your motherboard
May 22, 2009 | HP Pavilion a350n PC Desktop
Computer will not turn on. Power supply shows flashing green.
depending on the make of computer, a power supply cost's around $20.
Mar 12, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
Computers & Internet Logo
194 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
