Machine not washing but spin drying - Washing Machines
  • Washing Mach... Master
  • 5,323 Answers
No agitation?
first use a multi meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( If No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Another test u can make with a multi meter is by testing the prongs individually.
# 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch.
(where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open.
If both check ok then next CHECK the motor coupler (a bad couplercan be checked by looking under the machine and taking note if there is a black residue on floor, look at coupler located between the motor and tranny, and see if it is broken up or missing any parts? Try to turn shaft by hand and notice if it does not engage tub? )
or belt if belt driven. Check for loose, broken or worn belt .
Then check the door switch with a multi meter for continuity OHMS when door closed and infinity when door is opened , and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Also check THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
Remember to check the agitator spline as well. for worn broken teeth
By the way my advice is free cuz God is good!
Posted on Apr 17, 2017
We have an Ultima washing machine and creases the cloths very badly any suggestions please
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
Dec 28, 2015 | Hotpoint Washing Machines
The spin dry of the above mentioned washing machine spin dry not working properly cuts off what parts are required to fix this ?.
If a machine is out of balance when spinning it will shut down---there's an unbalance switch that controls this---also on some machines if not properly set level or feet not touching the floor causing the machine to rock---it will shut down---the remedy for that is to redistribute the clothes then is should resume spinning----another issue could be the timer----out of sequence or jumping ahead during that cycle---has the timer/control ever been wet as this will cause some issues---this is my thoughts on this--good luck
Mar 16, 2015 | Washing Machines
Spin dry
I have washer Model # XQB60-91BF It do all functions eccept spinning when it comes on spinning drum does't rotate. I replaced drain pump but does't spin. Can you guide me about trouble.
Thanks. email: khansaleemuddin@hotmail.com
Jan 20, 2013 | Haier XQB60-91BF 1.92 cu.ft. Portable...
Washing machine is washing but not spin drying
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 11, 2011 | Washing Machines
Does not spin dry after rinse cycle; it drains, but the clothes are not spun dry
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 18, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Washer will not spin dry
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
heatman101
May 19, 2010 | Frigidaire GLTF1670A Front Load Washer
Does not spin dry
heatman101
May 20, 2010 | Haier XQBM22-C Top Load Washer
The Washing Machine is not drying
heatman101
Dec 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
LG Washing Machine All-in-One
Some magic happened today!
I got the thing (wd-12331ad) to dry without having to run a wash first!
Also, I seemed to get it to do a spin only run...
The way to get it to dry :
(for a set time - I've not managed to get any of the auto-dry settings to work)
from machine being off:
> press the power button.
> press the "Dry" button 'til "Time" lights up
>>> press "Dry" again to get the desired duration
> press the spin button 'til the spin speed shows blank/ the RPM light goes out.
> press "Start/Pause"
It will then dry for the number of minutes specified!
Not perfect, I know but that's serious progress from where I was before; having to re-run a wash cycle to get it to dry anything...
Something to note:
- The machine worryingly sounds like it's starting to fill with water when you start the "Just Dry" program which scared me at first. BUT it stops after a second or so (I think it's just cleaning out the detergent tray so it doesn't bake any leftover powder)
For "spin only" from machine being off:
>>> if you press "Start/Pause" now you get a 13 minute 1200 spin cycle
>>> press the spin button again and then "Start/Pause", it seems to drain itself for 1 minute
>>> pressing spin repeatedly, cycles through the spin speeds.
Things I don't know:
- I don't know if you can combine spin and heat.
- I don't know whether the auto-dry programs are available
- I don't know what other programs are available from the "Dry"/"Spin" buttons
...So if anyone does any experimenting, please let us know the results, you never know, we might end up with a half way useful set of instructions! I'm starting to think the machine's not half as bad as it seems when following the manual alone.
Hope that helps.
Will
Jan 03, 2008 | LG WD-12126RD Front Load Washer / Dryer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
