Question about The Audio Players & Recorders
GETTING THE ALARM TO SOUND ON A ULTRONIC TOUNCH SCREEN MODEL552 ALARM CLOCK. SETS OK, BUT DOES NOT SOUND WHEN TIME IS REACHED. ALSO, HOW DO YOU GET THE KEY TONES TO SOUND?
  • 3 Answers
SOURCE: ultronic lcd clock with a stylus tucked in back of clock
This thing set under my bed, lifeless til I was looking for something else and decided it was time to get this clock working!
(Use the stylus pen for best results) After putting in two fresh batteries (or hit the reset button if your batteries are fresh). This will reset the clock and the 'clock' icon in the upper lefthand corner will be blinking. Now press and hold the display area where the hour of the day is displayed. The entire time will start blinking. Now start tapping on the blinking hours to increment the clock slowly to the correct hours (it will cycle all the way thru military time and regular time, so choose what you desire). Press and hold with the stylus to increment quickly. Do the same with the minutes, that are blinking too. When time is correct, tap the 'clock' icon once. The 'clock' icon will still blink, which I believe is correct operation.
To set the date, tap on 3rd icon down from the top left (it looks like a little calendar). This will put you into the date section of the clock (if you do nothing, it will cycle back to the clock, after ten seconds, as a default). Before it cycles back to the clock, press and hold with the stylus pen right below the word 'DATE', until the the entire displayed date starts blinking. Tap the first two digits of the year to go down in years and tap the right two numbers of the year to go up in years. Tap on the month number to increment; do the same with the date number. When all date entries are correct, either tap the 'calendar' icon, or let the clock sit for ten seconds: it will cycle back to the clock.
I guess you can set the alarm in a similar method.
Hopes this helps!
ExitKC
Posted on Feb 28, 2009
SOURCE: I cant find the alarm clock on N79? I have looked
Go into your phones menu, press applications, then press clock and there, your alarm menu is hiding. Hope this helps.
Posted on Mar 17, 2009
SOURCE: Timex T301B
Time zone 7 is Hawaii. They don't do daylight savings. I think I fixed the clock by changing it to time zone 7 and then resetting the time so it was correct in my own time zone.
I'll know for sure next daylight savings day (by the old schedule).
Posted on Apr 03, 2010
SOURCE: Need to set an Ultronic clock
Press the time (current time - numbers) to get to the date mode. Then hold-press "SET" to set it.
Posted on Aug 22, 2010
SOURCE: ultronic WS-9 radio/clock/calculator is there a light?
need a manual for a Ultronic clock radio calculator model WS-9
Posted on Jun 24, 2011
Setting an ultronic touch screen alarm clock
TD00552: 12 hr--military time toggle= tap time set button. Set time= hold down time set button till up & down arrows show on r & l sides; set hour, tap time set button, then set minutes, repeat, seconds, repeat. Date change= tap hour if needed to show day & month; then hold set button on left till up & down buttons show at edges of screen. Up/down buttons to set year on lower right screen, tap set again to change # day of month, tap set again to change month, and the day will correct itself. Change temp c° -- f°= tap alarm button if needed to display temp b them tap set button next to it to change temp scale. Alarm- off/on= tap screen button if needed to show alarm time; tap alarm set button next to it- it will toggle on/off. To set= with alarm time showering, hold down alarm set button till up/down buttons show; follow same process as above.
You are all welcome ??
Jul 01, 2017 | Televison & Video
Where can i purchase an ultronic weather=clock
You can purchase them on ebay or amazon,
you can get them on www.alibaba.com -see the link
Ultronic Weather Station Clock Ultronic Weather Station Clock Suppliers
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/bryan_4d4c18793378ea97
Dec 12, 2015 | Audio Players & Recorders
How do i set the Barbie Glamtastic alarm clock radio
Barbie Glamtastic Alarm Clock Radio 11765268
There are four (4) buttons on the back:
  • Mode
  • Set
  • Scan
  • Reset
Everything regarding setting dates and times is done starting with the Mode button, and using the Set button to adjust various settings.
Set Year
  1. Press Mode until the date appears.
  2. Press Set. The year will begin to flash.
  3. Press Mode until the correct year is reached.
  4. Press Set.
Set Date
  1. Press Mode until a date appears in the form of MM-DD.
  2. Press Set. The year may flash first. Press Set again. The month (MM format) will begin to flash.
  3. Press Mode until the correct month is reached.
  4. Press Set. The day (DD format) will begin to flash.
  5. Press Mode until the correct day is reached.
  6. Press Set.
Set Time
  1. Press Mode until the time displays.
  2. Press Set. The hour will begin to flash.
  3. Press Mode until the correct hour is reached. Keep in mind the AM/PM indicator in the far left of the screen. Make sure that the hour to be selected is with the correct AM/PM indicator.
  4. Press Set. The minutes will begin to flash.
  5. Press Mode until the correct minute is reached.
  6. Press Set button.
Set Alarm
  1. Press Mode until the the Alarm screen displays. The Alarm screen has an AL in the far right of the screen.
  2. Follow steps 2-6 above under Set Time (these same steps are just being done on the Alarm screen).
Turning Alarm On and Off
The left side of the radio has an On/Off dial (for the radio) at the top, and a slide selector button (for turning the alarm on and off) at the bottom.
  • Sliding the selector to the far left will result in Barbie's voice as the alarm.
  • Sliding the selector to the far right will result in a piercing noise as the alarm.
  • Sliding the selector to the middle slot will result in the muting of the alarm.
There are graphics on the left side of the clock that denote each result above.
Mar 28, 2014 | Barbie Glamtastic Alarm Clock Radio...
Accidently activated the alarm clock on Gigaset phone A400/A400A and now I cant work out how to deactivate it. Sorry cant understand manual it doesn't seem very clear to me. I am a 67 year old pensioner so...
Hello
This tells you how to set it, but not how to turn it off, so my guess is that once set, and the alarm goes off, it is then turned off. Or, there is a toggle on it, so press OK to Set, and OK again to Disable. The sequence is
Menu ₪ Alarm Clock ₪ OK ₪ Activation ₪ OK and I reckon OK a second time to switch OFF
Setting the alarm clock
Activating/deactivating the alarm clock
Menu
Alarm Clock
OK
Activation
OK
= activated)
If activated
Enter wake-up time
OK
When the alarm clock rings, press any key to switch it off for 24
hours. If the alarm clock is set, the wake-up icon will appear on the screen and the wake-up time will be displayed instead of the date.Entering/changing the wake-up time
Menu
Alarm Clock
OK
Wakeup time
OK
Enter the wake-up time in hours and minutes, then press
OK
. The alarm clock is automatically activated after the wake-up time is entered/changed.
It is easier to read on Page12 of the manual.
Good luck
Andrew, age 65 (almost)
http://gse.gigaset.com/fileadmin/legacy-assets/A31008-M2201-L101-2-7619_en_UK.pdf
Dec 10, 2017 | Lands Phones
Ultronic td552
Press upper right box 'alarm' until alarm time shows, then press 'set' button and it will toggle between 'off' and 'on' for the alarm.
Jul 01, 2013 | Audio Players & Recorders
Have a new ULTRonic Global clock. Came in a box, well packed but apparently no setup instructions. Have been able to set the clock after much guess work. Temperature, Humidity and trend seem to work....
This is for Ultronic LCD clock/weather gadget.
keywords (from display)
Ultronic forecast week day humidity temperature trend comfort level
- DOWN = toggles F/C temp
- UP = toggles alarm
- MODE = selects date/time display
- hold down MODE to enter "set" mode for data currently displayed
- use momentary MODE to choose target item
- use UP/DOWN to change item
Nov 01, 2011 | Watches
Ultronic Touch Screen Thermo Alarm Clock TD552 Desktop Model
This may be helpful, it's how I set mine.
1) Remove battery cover
2) Remove batteries
3) "Set" the clock and battery cover into the trash can.
There you go. No more problem !
Mar 15, 2010 | Computers & Internet
Ultronic WS-9 radio/clock/calculator is there a light?
Dec 15, 2009 | Audio Players & Recorders
Feb 19, 2009 | RIM BlackBerry Pearl 8100
20 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
