Question about Cell Phones
GETTING THE ALARM TO SOUND AND ALSO THE KEY TONE TO SOUND.
2 Suggested Answers
SOURCE: i am not getting ringing sound when i get a call.
go to phone setting and then go restore factory setting and press 12345 button wait for some minutes and access it
Posted on Jul 19, 2010
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
How do i change the alarm time from pm to am? its not in the manuel.
http://www.lg.com/us/mobile-phones/LG-GT365-Aqua-Blue.jsp
Above is a link to your phones manual in case you ever need it if you lose the one that you have.
Time: Select the desired set time mode
using the navigation key. Input your desired
alarm time by specifying the hour and
minutes. If the time is in the 12 hour format,
you have to select either 'am' or 'pm' using
the Center key.(its just your select key)
(Repeat: Select the desired repeat mode
using the navigation key.)
Alarm Type: Allows you to choose an
Alarm type for your selected alarm.
Options are: Follow Profile/ Always Sound/
Always Vibrate.
Alarm Tone: Select the alarm sound to use
for the alarm using the Center key
This is actually found on page 65 of your manual.
I hope this helps you out. just select the format, am, pm or 24 hours like you would the time you want to change the hour or mins, .
I hope this helps you. please let me know
May 14, 2011 | LG Neon GT365 Cell Phone
Constant beep even while driving and when i turn it off it still beeps unless i disconect the interior lighting fuse and plug it back in fuse # 8 i believe. if i leave the fuse out it makes a wierd sound...
1995 GrCher Orvis - I have now just started with the same problem. An incessent loud high pitched alarm sound. Identical fuse, ignition on/off, and ticking issues. Can start jeep, warning sounds as normal followed by incessent tone, I can remove fuse to get quiet, but then when I close the door I get the identical alarm sound, but with a slight pause. Tone. Tone, Tone, etc. I can't figure. Tore through all components of dash: to learn that the alarm seems to emminate from the transmission floor area, and is not in the instrument panel (f up #1) nor is it behind the dashboard (f up #2). I'm stuck now... Anybody got something for me? Is it a transmission warning?
May 28, 2010 | 1995 Jeep Grand Cherokee
HOW DO U SET ALARM
To create an alarm follow the steps below:
  1. While in standby mode, press the Menu / OK button
  2. Select Tools
  3. Select Alarm Clock (9)
  4. Highlight the desired Alarm, using the navigation keys, from the following:
    • Alarm #1
    • Alarm #2
    • Alarm #3
  5. Press the Menu / OK button
  6. Set alarm to On, using the navigation keys
  7. Set alarm time, using the keypad
  8. Select either A for AM or P for PM, using the navigation keys
  9. Press Menu / OK button to choose the Ringer Type from the following:
    • Single Tones (1)
      • Tone 1 through Tone 9
    • Ring Tones (2)
      • Ring Tone 1 through Ring Tone 15
    • Melodies (3)
      • Ball (1)
      • Caribbean Cruise (2)
      • Chorus of Clocks (3)
      • Right Here (4)
      • Guitar Man (5)
      • Latin Lady (6)
      • Minuett (7)
      • Mixed up World (8)
      • Pressure (9)
      • Simply Blue (10)
    • My Content (4), for previously downloaded music
  10. Select desired Repeat frequency, using the navigation keys, from the following:
    • Daily
    • Once
    • Mon to Fri
    • Sat & Sun
  11. Select the Snooze Interval, using the navigation keys, from the following:
    • 5 Minutes
    • 10 Minutes
    • 15 Minutes
    • 20 Minutes
  12. Press the left soft key for Done to save the alarm changes
Dec 16, 2009 | Samsung SPH-M500 Cellular Phone
How do i turn off the alarm on the samsung jack
While in standby mode, press the left soft key for Start
Select Organizer
Select Alarms
From the Alarm screen, highlight Wake up alarm (1)
Press the left soft key for Edit
Press the OK key to check a box, then enter the time for the wake-up alarm, using the keypad
Press the OK key to check the boxes for the desired days of the week
Highlight Tone, using the navigation keys
Select a melody for the alarm Tone, using the navigation keys
Highlight Snooze, using the navigation keys
Select a Snooze time interval, using the navigation keys
Press the left soft key for Done to set the Wake-up alarm
Note: You can set up to 3 different wake-up alarm times, but not on the same day
Nov 26, 2009 | Samsung Jack Cell Phone
Low alarm tone
I think i can help you. The problem I'm having is that the alarm tone is too brief an too low. So brief that it doesn't come close to waking me up. Try this, Have someone send you a ring tone or some thing u want to wake up to. Within the message there is an option that will let u save the sound in your documents or ring tone folder. Try both. An hopefully when you set your alarm tone it will allow you to set the music, sound you just saved. If that doesn't work the HTC website has a trouble shooting section. I think it addresses this problem. Good luck i hope this helps
Feb 18, 2009 | HTC Touch P3450 Smartphone
Steady tone coming from ghw9150pw0
could be problem in control bd not necessarily a problem with function but something in sound circuit ck for a sound control button on keypad it may say something like alarm volume or on off try holding it down after turning power on if you notice any change in volume or tone of sound shows you're on right track only thing is solution may mean new control bd
Sep 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Feeble Alarm sound
you can Update your phone to the latest framework to solve this
Feb 08, 2008 | Sony Ericsson P990i Smartphone
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
