Question about LG Cell Phones
How to set repeat notifications on LG K7. I am deaf have the the flash set on, but I need it to repeat more than once.
Lg k7 will not turn on just stays black
RIKKI, Check the attached links,instruction and guides on getting your device back and running. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fix Android device wont turn on problem
LG K7 How to Hard Reset my phone HardReset info
LG K7 Hard Reset For Metro Pcs mobile
My phone wont turn on
Jul 06, 2016 | LG K7 4G LTE with 8GB Memory Cell Phone
How do I get and send MMS on my new LG K7?
Reviews are not good on that phone!
http://www.gsmarena.com/lg_k7-7848.php
Mixed reviews here. I certainly does texts SMS!
http://www.t-mobile.com/cell-phones/lg-k7.html
So then I did a chat with a T-Mobile agent!
You: Does the LG K7 have MMS Multimedia Messaging System capability?
Darwin: Thank you for the opportunity to assist you today.
You:
Come on Darwin. Time is money :>) Darwin: Yes, this supports MMS! Darwin: I am sorry about the late reply. Darwin: The LG K7 definitely has MMS capability. Darwin: This is a great Android smartphone to start with. You: Thank you. This is a question that has been asked on Fixya.com. I will reply. Thanks I was only joking. How does the consumer bring up the MMS interface? Darwin: This found on Settings under Text Messaging option. You: Thanks, you are a star!
LG K7 Read Reviews Tech Specs Price More Mobile
May 05, 2016 | LG Cell Phones
Forgot pattern unlock code on LG K7
Throw it away, but a new one and don't set a simple pass lock pattern or code. Once you try 10 times the phone is disabled and locked at firmware level.
Apr 03, 2016 | LG K7 4G LTE with 8GB Memory Cell Phone
How do I set my samsung S111 to repeat the notification of an incoming text until I answer it?
Click on "messging" like you're about to read a text, then click on left hand side and a few options should come up, click on the "settings", scroll down until you find the "notification settings", then click on "message alert repetition", you should be able to change it to either "once, every 2 minutes or every 10 minutes"... hope that helped
Sep 24, 2014 | Samsung Cell Phones
How do I set my samsung S111phone to repeat the notification of a text until I answer it?
Kindly follow the steps listed below to do so:
  1. Go to Apps through Home screen.
  2. Tap Messaging.
  3. Tap the Menu key.
  4. On pop up menu select Settings.
  5. Scroll to Notification settings section then tap Message alert repetition.
  6. Here you can see three options available on pop up menu. They are:
    • Once: Choose this option if you want your phone ring the tone just once when receiving an incoming messages.
    • Every 2 minutes: Choose this option if you want your phone ring the tone every 2 minutes until you open the message.
    • every 10 minutes: Choose this option if you want your phone ring the tone every 10 minutes until you open the message.
  7. Tap the required message alert repetition option you wish to use. When the dot indicator next to the option shows green means the option is selected.
  8. Tap Home button to return to the standby mode.
By adjusting message alert repetition just once or more than once, now your phone will notify you when receiving new message and repeating the tone according to the settings you've just done. So, what's the option you use on your phone?
I brought a LG L20 phone & cant find the
The notifications area should be under settings.
Other locations: for message notifications for texts, open text app, click the options button, and click settings.
Email settings would be located in the apps you use for your emails. Simply click the options icon once the email app is opened, and then settings.
Other settings should be under the settings app in the phone itself.
Sep 18, 2014 | Cell Phones
My blackberry curve red LED light wont stop flashing even if i dont have a notification.
f you set Repeat Notification to NONE in your Profiles, you won't get the LED flashing. Do that for EACH message type in your active profile, as well as in and out of holster settings.
The Messages > Options > General Options > Display New Message Indicator setting refers to the "star" that appears on the folder when new mail arrives.
Mar 11, 2011 | RIM BlackBerry Bold Smartphone
Duplicate alarms
I may be off base but might the problem be as simple as the frequency being set for the alarm. What I mean to say is, might the default reminder time for the alarm be set to such a low setting like sec's or minutes leaving the unit to repeat the alarm rapidly prior to your being able to dismiss/snooze. Good luck.
Sep 14, 2005 | HP Jornada 548 Pocket PC
Cell Phones Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
