Question about Printers & Copiers
HP printer Model : V 40 , about 5 years old
I am facing a serious difficulty : -
The print outs that come out have a problem -
every alternate line is only top half printed ?
Making the print out extremely difficult to read .
Please help .
Kashyap Patel .
Das & Company ,
Das Chambers ,
25 Dalal Street , Fort ,
Bombay 400 001 .
Phones - 022 - 2267 3661 , Fax 2267 1637 .
  • 417 Answers
Re: HP printer Model : V 40 , about 5 years old
Place the original on the scan glass and do a copy from there.. If OK then clean the small strip glass to the left of the main scan glass. If not OK the open machine and check the following.
For worn marks on them.. as they both can cause this fault.
Thanks J
Posted on Jan 17, 2008
0 characters
3 Points
P2015d - Jams when printing double-sided as it pulls the sheet back into the printer for the backside print.
Check is there any paper particals jammed in duplex unit (RM1-4258-000), repalce roller face down(RL1-0527-000), if is difficulty to find out the part remove this roller files the surface of the tyre with sand paper fix it back. This activity advised for tec guys only.
Sep 23, 2011 | HP LaserJet P2015dn Printer
I've got a HP C4780 printer which I have had for around a year but only used about 5 or 6 times! Despite the ink cartridges having ink in them, the black cartridge is not printing at all. Not even a...
The ink solidifies right behind the micro printing nozzles. The only way to attempt to rectify this is to dip the print face into some warm (not hot) water for a minute or two, and dry after wards. If the cartridge recovers, Yippee, if it doesn't, replace.
Common problem. Be thankful it isn't a Canon or Epson, which entails replacing a seriously expensive 'print head'.
Jun 08, 2011 | HP PS C4780 All in One InkJet Printer
Faxing instructions do you insert paper face up or face down
If you're putting it on the glass, it goes face down. If you're talking document feeder, look for the icon of a page. It will show printing with a corner curled (face up), or a blank page with lines on the curled part (face down).
For an example of what a face up icon looks like, check out the HP instructions for an HP machine here
That's the generic answer to a non-listed model number :-)
Feb 23, 2010 | HP Printers & Copiers
Printer says "out of black ink", I replaced, still won't print.
are you sure it is a fresh cartridge? or a refilled one? because if its a refilled one it is normal that it will show that message "low on ink" but you can continue printing if your sure that it is properly refilled
Sep 06, 2009 | HP Business Inkjet 1100dtn Printer
Print is way too tiny
Set your email font to 12, 14 ,16 or larger the internet you have no choice in the matter they control that
Jul 08, 2009 | HP PhotoSmart 7350 InkJet Printer
Ink leaking on to dvd when printing label
Are you using a printable CD and telling the printer that that is what it has to print on?
Jan 30, 2009 | Epson Stylus Photo R200 InkJet Printer
Hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Nov 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Difficulty reinstalling my HP Deskjet F300
Is there a registration number on your disc?
Do you have a folder left for the printer or did everything get deleted? You might look in the folder if it is still there to see if there is an informational page left.
Otherwise you need to contact HP. You can do that from
Once you are on their site, look oor support and click on the link to chat with one of their techs online. Have all of your info ready. the model and serial number of the printer. the name and address you used to register it under, etc.
Here is the link:
Good luck to you and be sure to let us know if this solution worked for you. Thanks.
Aug 15, 2008 | HP DeskJet F380 All-In-One Printer
Ink Cartridge Alignment
On alignment sheet, do you see a line of yellow blocks?
And on next line do you see alternate block and yellow blocks?
(Without these, alignment fails)
If not, change the colour cartridge, re-print the page and repeat alignment.
Good luck...
May 26, 2008 | HP PSC 2110 All-In-One InkJet Printer
Printer not printing
if you purchased generic replacement cartridges,you may have gotton bad cartridge(this happens alot),if not you're print head may be clogged,if that's the case you will need to bring it to a repair shop to be cleaned,very messy you would not want to try to clean
Sep 16, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Printers & Copiers Logo
59 people viewed this question
Top Printers & Copiers Experts
old marine
old marine
Are you a Printer and Copier Expert? Answer questions, earn points and help others
