Question about Sanyo Televison & Video
I have a Sanyo tv work perfectly fine until one day it just turn off a friend told me it was the power supply board I bought installed it but nothing happened
  • 1074 Answers
SOURCE: tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Posted on Apr 04, 2007
SOURCE: Aiptek won't turn on
Try taking the battery out and putting it back in. I don't know why, but it worked for me. Good luck!
Posted on Jan 16, 2009
  • 17 Answers
SOURCE: Have a friend who owns a 50 in Sanyo plasma tv.
If you have a part number for the board this place could carry it. They sell thousands of parts for tv's. check it out
Posted on May 08, 2009
  • 1779 Answers
SOURCE: power supply bad on Sharp Aquos LC - bad board - schematic to ID?
Buy the green light going on means Standby is ok. Next, would be to locate the plug coming from the main board to the power supply and find the post that says PO which means power on. With your meter on that post, press the power button as see if the reading goes High, if it does then the main board is able to turn on the power supply. Next, find the plug on the power supply that goes to the inverter( the long board on the side) remove it and see if you have 24 volts coming out of the power supply when you press the power. If you do, then the inverter board is bad, if you don't have 24 v, then the power supply is bad. There are NO diagrams available for these set other than a flow chart if you can find one. A regular svc tech does'nt need a manual for these anyway.
Let me know how you do Kathy ?
Posted on May 17, 2009
SOURCE: no picture
Had the same problem, Insignia 32 would click on then go off. About 6 months ago I found (somewhere on the net) a guy who explained that he changed blown capacitors. As I recall he even posted a picture. I found the blown capacitors and replaced them with larger capacitors (less than $20) problem solved...
But now my screen image is showing only half a picture and is pulsing on a off.
I think I'm going to make a Wii commercial......GL
Posted on Jun 03, 2009
Sanyo tv won't turn on after a lightning strike.
Ask friend if broken when given to you. If not I would suspect the power supply is fubar..
Sep 16, 2017 | Sanyo Televison & Video
My Sanyo HD TV power light comes on but no picture and no sound.
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jul 28, 2015 | Sanyo DP19647 19 in. LCD TV
Help new power supply will not power up.
if you had a surge, it could have damaged more than just the power supply. When you plug in the unit, does the power indicator light up??? your main board could also have damage. The main board sends a signal to wake up the power supply thus turning on the TV. If you have to replace the main board as well, it probably won' t be economical to repair the set.
May 19, 2012 | Polaroid FLM-3734B 37 in. LCD HDTV
I have a Sanyo DP50747 (May 2007) it has worked perfectly fine for 4 yrs and then one day while on it shut off and will not power back on. No light - no nothing - as if it is unplugged. Any ideas? I am...
Tries tv unplug,replug it back like about an hour later.The tv should resetting itself back to the factory setting.Now,the tv should be working again.If tv have the same result,the tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Try website like to buy a refurbish power supply board for the replacement.
Mar 21, 2011 | Sanyo DP50747 50 in. Plasma TV
I have 46 in sanyo I purchased from walmart in late 2007. The tv will come on for just a second and then cuts off again. I don't know what to do I can't get it to come on
Try unplug,replug tv an hour later.Tv should reset it self back to factory setting.Should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like, to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | Sanyo DP46848 LCD TV
I have a 1 year old sanyo 42" lcd tv, model DP42849, The tv was running perfect till one day watching a movie, the screen went black and audio went all strange, i shut it off and on, and nothing, the power...
You need to find out if the power supply is putting out 24vdc for the backlight inverter board, it can be that the inverter board has short circuits which will cause the 24vdc to go into shutdown to protect itself, you can disconnect the power cables to the inverter board to see if you will get the 24vdc back.
Aug 05, 2010 | Sanyo DP42849 42 in. HDTV
50 inch Sanyo Vizon Plasma TV. Has sound but no picture for last few days. 2 years old
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Sep 06, 2009 | Sanyo Televison & Video
Televison & Video Logo
26 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
