Question about Hardware & Accessories
My reset timer button isnt releasing?
Tag Heuer carrera calibre 16
5 Suggested Answers
  • 58 Answers
SOURCE: TAG Heuer Carrera Calibre 16
This is a warranty issue, the watch should not lose time like this. Take it back to the supplier ASAP
Posted on Jun 22, 2009
Bob Gemmell
  • 209 Answers
SOURCE: I have a TAG HEUER Grand Carrera and the second has stopped
Are you aware that these are automatic watches and need to be moved to keep the watch going, kinetic energy winds up the movement which allows it to keep going, if it is left off your wrist and in a drawer or sat stationary it will stop. Shake it violently (without dropping it) and it will restart.
Posted on Aug 26, 2009
  • 2334 Answers
SOURCE: Tag Heuer Carrera CV2A10 date display changes at 3AM??
Unfortunately, there is not much you can do with this, as for fixing it you need very experienced watch repairers help. All I can do is just name all possible reasons why it happened. FIRST reason could be: the day wheel somehow has lifted and not sitting in correct position. This would be the easiest fault for watchmaker to repair, as only dismantling the movement, correcting the day wheel and re-assembling will be necessary, so, no serious repairs needed. SECOND reason can be: the star, which is friction fitted to the day wheel is getting loose. In this case, if watchmaker will not be able to fix the day wheel, you will have to buy new day wheel + all work previously explained. THIRD reason: the day wheel click spring is weak/bent/broke. In this case you have to buy new day wheel click spring + again all the work previously explained. FOURTH and last reason: day wheel positioning screws/borders became loose. In this case only the work explained in FIRST reason will be necessary. If you are so lucky and still have warranty for your watch - send it back to Tag Heuer and they will do repairs without charge, because this fault is covered by warranty. If warranty has expired, you do not need to find any particular Tag Heuer watch repair shop. As all watch movements are manufactured on identical basic principles, any reputable/decent watchmaker will do the job for you. Prepare yourself to pay quite a lot, because Tags are expensive to deal with and takes a lot of time and skill to fix. This is all help I can give. Wish you luck. Rate me, please, and/or write some testimonial if you have spare minute.
Posted on Mar 25, 2010
Testimonial: "Thank U so much for the enlightenment, escapement. Your points really do ease me alot. Will go to retailer/svc shops and we'll see from there. Cheers!"
  • 10865 Answers
SOURCE: i have tag heuer link calibre 16,i want to take ou...
your best bet is to take the watch to any jewelry store. They have a special tool to remove the pins that hold the link in place. With out this tool you risk ruining the band. J.
Posted on May 25, 2010
How do Iset time tag watch carrera calibre S
Very good video of this on youtube.
Good luck, as the guy on the video says it is complicated!
Oct 18, 2014 | Tag Heuer Carrera Watches
My watch stops very often its tag heuer grand carrera calibre 17 rs2 automatic one what do i need to do for continuous running of my watch
It rather depends what you mean by "very often".
An automatic watch will run for 2-3 days before stoping if it is not used.
These watches thrive on being used and are best used every day.
It could be that your watch needs cleaning (I had one that was like that when I bought it and I had it cleaned and it ran for years after that).
Jan 21, 2011 | Tag Heuer Grand Carrera 17 RS CAV511B...
My tag heuer carrera stop watch doesnt reset properly, when u reset the stopwatch it goes one minute behind and doesnt reset to zero. how do i fix this. it never resets to zero and the red hands on the sub...
Try this.
Pull the winder out fully. Then press the top right chronograph button to move the centre seconds hand on. Then push the winder back in.
on some models you should only pull the winder half way out.
good luck
Sep 23, 2010 | Tag Heuer Carrera Tachymetre CV2013.FC6206...
I have recently bought a Tag Carrera Calibre 16 and now the date will not change when i turn the knob. It was working up until this week. Seems like its stuck. Help
Take it back to the nearset dealer or service center. It will still be under warranty and they should fix any problems free of charge.
Do not attempt any repairs yourself, as it will invalidate the warranty.
Sep 06, 2010 | Tag Heuer Watches
Hi there i have bought a second hand tag heuer carrera tachymeter,i dont have a user manual,but cant seem to get the chronograph functions to work ?
Great watch! Operation should be pretty straight forward. The top button starts the chrono and stops it. The bottom button resets it. To calibrate the sweep arm into the right position pull the crown out to the first or second set position and press the start button until the sweep arm is in the start position you desire. This is typically 12:00 or 0.
If your chrono is not working then have the battery checked. If the battery has been recently replaced then make sure the watch doesn't need to be cleared.
I recommend you take this to a watch maker/technician who will be familiar with the service requirements of this model including resealing and pressure testing the watch to be sure it is sealed to its marked water resistance specifications.
Sep 20, 2009 | Tag Heuer Carrera Series Chronograph Watch
Tag heuer automatic series, how do you start the watch after purchasing?
push the crown in if it is in the adjust position .then shake the watch around the auto mechanism sould start the watch
Aug 23, 2009 | Tag Heuer Automatic Chronograph Series...
Jun 21, 2009 | Tag Heuer Link Automatic Chronometer...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
