Question about Radio Communications
I replied the batteries but my Talkabout 5530 does not work? Help?
3 Suggested Answers
Agent Ken
  • 250 Answers
SOURCE: Will a Motorola TalkAbout T5320 transmit to a Motorola TalkAbout T5530?
Hello Blindmaster,
Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a “Privacy Code” or “Quiet Code.” The actual name of the feature may vary.) This feature encodes a low-frequency signal on your radio transmission. This signal is below the range of human hearing but can be detected by other radios. When the CTCSS feature is active your radio will ignore any signal that it receives that does not have the proper tone encoded on it.
In order for these radios to communicate, all of the radios need to be on the same channel and have the same CTCSS code programmed or the CTCSS feature must be disabled.
I suspect that CTCSS is activated on your T5530s but is not enabled on your T5320. This would result in the situation you describe.
Also take note that when using different brands / models of radios to communicate with one another that the CTCSS code numbering scheme may not necessarily be the same from radio to radio. For instance, CTCSS code “4” on the Motorola TalkAbout series actually corresponds to code “A” on the Motorola Sport models.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Posted on Apr 07, 2008
Ironfist109
  • 3018 Answers
SOURCE: need headsets for the T 5530 Talkabout radios
  • Motorola two way radios were pretty standard across the board with their accessories and chargers. If it worked in one it was pretty much guaranteed to work in a different model one. This link here http://www.ewingenter.com/accessories.htm is a great place to get aftermarket Motorola two way radio accessories. You have your choice of several types or headset/mic combos on there.
  • Hope this helps and thank you for using FixYa.
Regards,Tony
Posted on Oct 16, 2011
Need headsets for the T 5530 Talkabout radios
Regards,Tony
Oct 16, 2011 | Motorola TalkAbout T5530 2-Way Radio
Can you talk between a 5530 and 5320
Yes if they are both connected to each other
Jan 24, 2011 | Motorola TalkAbout T5530 2-Way Radio
Removing the lock code of nokia 5530 xpress music
i forget my lock code my hp 5530 how i can open this lock code?
Sep 24, 2010 | Nokia 5530 XpressMusic Smartphone
HELP ME PLZ .. MY NOKIA 5530 TURNS OFF WHILE MAKING A CALL AND WHILE RECEIVING A CALL .. CAN SOMEONE FIX THIS PROBLEM FOR ME.
The main problem is the battery is not good .
Change your battery and try it.Then it will work good
Sep 12, 2010 | Nokia 5530 XpressMusic Smartphone
I cant send a message on my nokia 5530..but i can recieve messages..what should i do?
in message settings...
under the option of sent message via, select it by "text"
and under option reply via same centre, select it "no"
Aug 12, 2010 | Nokia 5530 XpressMusic Smartphone
Telephone and Contacts shortcuts touch function not working on my Nokia 5530 home screen.The other touch functions are working fine.
such problems are mainly software but can be hardware also so the best thing u can do is take the cell to your closest Nokia care center!
to locate one center in india try this!
http://www.nokia.co.in/get-support-and-software/repair-and-recycle/care-center-locator
rate and reply me!
Jul 15, 2010 | Nokia 5530 XpressMusic Smartphone
Power
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Apr 01, 2010 | Acer TravelMate 5530-5207 Notebook
Nokia 5530 wichs keeps shutting down
my nokia 5530 powers off when i call someone.
Jan 11, 2010 | Nokia 5530 XpressMusic Smartphone
Hello Blindmaster,
Best Regards,
Agent Ken
Go Ahead. Use Us.
Mar 31, 2008 | Motorola TalkAbout T5530 2-Way Radio
Radio Communications Logo
29 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
